Question about Acer Computers & Internet
Acer laptop won't charge.
Grr. So, my Acer Aspire 3000 laptop has been having some really weird problems charging its battery. It used to be if you wiggled the cord around a bit, the charge light would come on, but now it's so finnicky that I have to push really hard on the part that goes into the port before I can turn it on. Is it shot? Is there some kind of fix for this?
  • 24 Answers
When you finally get the charge light to come on, does the battery get fully charged? How long can it run while not plugged in?
A junker will not charge properly, or hold a charge for a short period of time. If this is the case, time to get a new battery.
If the battery seems to charge fine and the uptime is acceptable take a look at the charger and connectors, make sure their clean and free of debris. Maybe try to locate someone with the same charger and see if the problem continues (Some computer shops may have your charger)
Posted on Jul 17, 2009
Acer aspire m5 won't charge
it sounds like one of three things:
1. Battery itself no longer functions
2. Laptop Charger has inadequate amperage
3. The motherboard is defective (most likely).
If you have another battery, or a friend with the same battery, you can try that first (and someone else's laptop charger).
If the problem is the motherboard, you can try to have it repaired but I don't trust many companies to do this kind of work. I outsource my motherboard jobs to a company called Laptop Rescue (http://www.laptoprescue.com/laptop-repair-2/). Coincidentally, they also sell laptop chargers in case that's the problem. Hopefully it's just a charger or battery issue and not a motherboard.
http://www.aurabuy.com/cheap-4400mah-battery-for-acer-travelmate-4740-4740g-4740z-4750-5335g-5335z-5340g-5542g-6495tg-8473g-8472t-tm5740-paypal.html
Apr 06, 2013 | Acer Aspire One PC Notebook
Replaced the power board on acer aspire battery will charge to 28% overnight but charge nlight doesnt lightup
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Aug 22, 2012 | Acer Aspire 4720 Notebook
Acer aspire battery critically low but not using battery, it shuts off anyhow
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Mar 04, 2012 | Acer Aspire 3610 Notebook
I have acer aspire 4741z, when I plug the battery charger, it says plugged in, not charging (6% available). how can I fix this problem? thanks a lot
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jul 07, 2011 | Acer Aspire 4730-4947 Notebook
Battery not charging
As you have tried to replace battery and still new battery is not getting charged in this case it seems there is hardware problem. Circuit which allows battery to charge is not working.
Apr 29, 2010 | Acer Aspire 3000 Notebook
Acer Aspire 3000 Dead! No Charge light no Power light Charger ok Battery new.
Hi there.
Take the battery out and try to power it up on AC power only.
please post back the results
Good luck and thanks for using Fixya!!
Feb 23, 2009 | Acer Aspire 3000 Notebook
Acer Aspire refuses to charge.
i had the same problem at first but all i did was buy a new battery and it worked fine, then when it happened again i just had to take out the battery and put it back in, then it worked, hope i helped.
Jan 18, 2009 | Acer Aspire 6920 Notebook PC
Sounds like it may be the FSB. I had the same sort of problem, though my Aspire was only a few months old and therefore covered under Acer's warranty, but I also have after sales repair insurance too. Either way, I would strongly suggest that you get an engineer to take a look
Nov 19, 2008 | Acer Aspire 3000 Notebook
Acer aspire 3000 doesn't charge
are you sure the battery is good? How old is the system and battery? Do you have any way to check voltage at the battery terminals?
Aug 29, 2007 | Acer Aspire 3000 Notebook
Computers & Internet Logo
182 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
