Question about Car Audio & Video
How to replace front speakers in a daewoo leganza 02
How to replace front speakers in a 2002 daewoo leganza.
  • italosolari7 Jul 25, 2009
    Thank you for your help! I have the standard audio system. I need to replace 2 speakers that broke, one in the door and the other in the back. I really would apreciate your help.
    Regards
  • Lacey Simmons May 11, 2010
    Do you know if you have bose or the standard audio system ?
  • 68 Answers
You will need to either remove the door card or the speaker grill on the door card. To do this you will need a set of thin nose pliers for removing door clips, a flat head screw driver and a phillips screw driver for any cross head screws. Use the flat head screw driver to pop the grill off, if the grill is not removeable you will have to take the whole door card off. To do this you need to remove the electric windows panel as well as the door handle and lock panel, from their disconnect them from their harnesses. Then remove all clips and screws holding the panel in place. The door card should come free without too much effort, pulling upwards and away from the window. Unscrew the old speakers and disconnect the wires from them. Wire your new speaker to the same wire configuration as the old one. Screw it in. Place the door card back on and then plug the harnesses back in and place the door lock and window locking panels back in place. Do the same for the other door.
A professional installation will cost about $80 I think, I did my door speakers on my car and all I had to do was pop out the grill so it was easier than I expected.
Posted on Aug 05, 2009
Timing setting daewoo leganza
http://www.tradebit.com/filedetail.php/189127366-daewoo-leganza-service-manual
Aug 28, 2012 | 2000 Daewoo Leganza
Daewoo front crank seal leak
front seal on the timing cover? Maybe your leak is coming from another place? You might need to talk to another daewoo owner or find a forum for your car and research there. good luck.
Oct 30, 2011 | 2001 Daewoo Leganza
Where is the water pump located on a 2002 daewoo leganza se
Pump is driven by the cambelt. It is located under the cam cover in front of the engine.
Jun 21, 2010 | 2002 Daewoo Leganza
Does anyone know the part number for 2000 Daewoo leganza driver's window power window motor? I have located new motors but the seller doesn't know which motor fits the driver window? If I can get the...
www.daewoous.com has complete breakdown of Daewoo parts. Prices are competitive and they have most in stock. Their diagrams show the motors for front door, left and right as well as back door left and right. Part numbers are listed also.
Jun 19, 2010 | 2000 Daewoo Leganza
Torque spec for 2002 daewoo leganza for half shaft nut
THE LEGANZA MODELS TIGHTEN THE HALF SHAFT NUT TO 111 - 155 FT LBS .LOOSEN THE NUT RETIGHTEN TO 37 FT LBS.RETIGHTEN AN ADDITIONAL 60 DEGREES.STAKE THE NUT WITH A PUNCH AND HAMMER.THE NUT WILL NOT BE LOCKED IN PLACE UNTIL THE NUT HAS BEEN STAKED.
May 13, 2010 | 2002 Daewoo Leganza
How to replace the fuel pump in a 2000 DAEWOO LEGANZA
I found a Daewoo manual on line and found the location of fuel pump.
I removed the pump , checked it and I plan to order a replacement.
Sep 06, 2009 | 2000 Daewoo Leganza
My Daewoo dies after it warms up
1999 Daewoo Leganza Daewoo leganza stop running when I slowed down just after I noticed a hesitation while driving at a steady speed. It wouldnt start up again until I waited for awhile.
Apr 12, 2009 | 1999 Daewoo Leganza
I just need to learn about general characteristics of daewoo legansa 2.0 lt,manual gear ,such as fuel expenditure,average speed etc.
http://consumerguideauto.howstuffworks.com/2000-daewoo-leganza.htm
OR
http://www.carsurvey.org/reviews/daewoo/leganza/2000/
or
http;//www.autozone.com
Nov 25, 2008 | 2000 Daewoo Leganza
2002 Daewoo Leganza help
It has a single din radio that can be purchased anywhere for under a hundred bucks. Check the antenna connection. Window regulators can be nought from Dr. auto parts. Go on ebay they go for about 40 bucks. Frank Kent Daewoo in Fort Worth Texas has the largest supply of Daewoo parts.
Good Luck
Nov 19, 2008 | 2002 Daewoo Leganza
Daewoo leganza
if you stand in front of the car, it is on the right side of the radiator at the bottom, you can turn it with your hand
Sep 28, 2008 | 2000 Daewoo Leganza
Car Audio & Video Logo
317 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
