Question about Whirlpool GMC305PRS Stainless Steel Electric Double Oven
Whirlpool double oven. fan assisted oven is not heating up fan is
Hi we have a whirlpool double oven. the normal oven is heating up but the fan assisted oven is not . the fan is working . can yoy help please
  • 491 Answers
NEEDS A NEW HEATING ELEMENT
Posted on Jul 18, 2009
OVEN DOES NOT HEAT IN FAN ASSISTED MODE but the fan works ok
I would suggest that the oven element is faulty
This is located at the rear of the innner oven compartment behind a removeable cover.
Mar 10, 2010 | Neff U1461 Double circotherm plus Electric...
I have a Whirlpool AKZ161/ix/03 double oven in which the bottom oven will no longer heat up to the required temp. I suggest it is the heating element. As a novice will I be able to change the element and...
If it is fan assisted, and the fan is working o/k, then the chances are it is the element.
This is usually located at the rear of the oven compartment behind a removeable cover.
Normally a straightforward repair
MAKE SURE POWER IS OFF !!!!
Please rate my solution.
Thankyou.
Jan 27, 2010 | Ovens
My double oven has stopped working, its only the large fan assisted oven which is producing no heat. The top oven/grill works okay. Is it an element problem ?
If the fan is working o/k, then you need to fit a new oven element, located at rear of oven behind removeable cover.
Thanks.
Nov 18, 2009 | Whirlpool RBD305PD Electric Double Oven
Whirlpool built-in double oven model# RBD305PDB12
the humming sound is coming from the "squirrel cage" fan in the back of the unit, there may be some resonance vibration from the fan this issue should be addressed by a qualified service tech, the whole wall oven needs to be pulled out, i would have him check the fan.
Aug 27, 2009 | Whirlpool RBD305PD Electric Double Oven
No heat from oven but fan and light works
Timer might be blocked on auto, you need to get it back to a manual setting.
Apr 12, 2009 | Ovens
Noise from fan when electric oven is first turned on
The fans are not normally repairable, but there is no problem obtaining replacements.
On a double oven, there are usually 2 fans fitted.
There is an external cooling fan usually fitted on the top of the oven, you would have to remove the top cover of oven to access it, and possibly the rear panel as well.
Then there is the fan fitted in the main oven compartment.
If you open the oven door as it is working, you should be able to determine if it is the fan oven or the external cooling fan that is the cause of the problem.
If you determine it is the fan in the oven that is noisy, then to undo the fan blade assy, you have unscrew the nut clockwise to remove it. as opposed to the normal way of undoing a nut.
Please rate my fixya solution.
Thanks.
Feb 09, 2009 | Whirlpool RBD305PD Electric Double Oven
Oven not heating
You need to replace the fan oven element.
access to it is by removing the rear panel in the oven, there you will see the element.
Plz rate my solution.
Thanks.
Dec 18, 2008 | Whirlpool AKZ159IX Oven
Bosch convection double oven,ovens won't heat,only broilers work
If it is fan assisted then check the fan element, it is located behind a panel at the rear of the oven compartment.
Plz rate my\solution.
Thanks.
Dec 17, 2008 | Bosch Ovens
AEG double oven- fan assisted not heating up
you oven element has failed.
it is located at the back of most electric ovens sometimes at the top,,
the insulation of the element has failed and when you come to remove it you will see visually see the damage... its easy to replace as there are only wires attached to it and only a few screws to undue to get to it..
hope this helps cheers
the washdoctor
Aug 24, 2008 | AEG B2100-4 Electric Single Oven
Whirlpool GMC305PRS Stainless Steel Electric Double Oven Logo
746 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
