Question about HP m7170n PC Desktop
Computer not starting up... Power supply green light on!
I have exactly the same problem! I don't know much about computer hardware... Which Motherboard would be a good upgrade?
  • martyrobitai Jul 17, 2009
    Ok fine, let me repeat my question: Which motherboard would be a good upgrade?
    Sniper:
  • 86 Answers
Then change yr motherboard its the easiest and they r fairly cheap
Posted on Jul 17, 2009
Computer won't start. PSU good. Amber light on mobo. What gives?
It is probabley the power supply is bad the amber light should be green Get yourself another power supply and see if that don't fix your problem
Sep 01, 2011 | Dell Dimension 4300S (Refurbished)...
I am getting nothing but a green light on my motherboard when I plug the power supply half way in to the motherboard the fan and processor start running but when I plug it all the way in it stops and...
I would need to know what all you are trying to run in your computer to offer much assistance, but hot plugging power cords in computers is a good way to fry the motherboard. It sounds like you don't have a big enough power supply for everything you are trying to power, so that when you connect enough of the power plugs, the supply shuts down from trying to draw to much current.
If you post your hardware specs, I will try to offer more assistance.
Thanks,
John Vickers
Aug 12, 2011 | ASUS P4P800-VM Motherboard
Hp m1160n Green light is flashing, went thru all of the steps listed, and the troubleshooting guide on the hp website.No dice...computer will not turn on. tested power supply = good. tested power switch =...
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this will help
don
Feb 27, 2011 | HP ATX-300-12Z (ATX30012ZBD) 300-Watt...
Green blinking light on power supply. Computer will not power on. Power supply appears to be good because I connected black and green leads from motherboard connector with a small piece of wire, and the...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
don
Feb 12, 2011 | HP ATX-300-12Z (ATX30012ZBD) 300-Watt...
Green lights...no power. HELP!
This could be a problem with your power supply. If the motherboard sees that the voltages from your power supply are low, it will turn itself back off.
You can test your power supply by unplugging all of your internal power cables, ground out the green wire on the 20-pin/24-pin ATX connector and check your yellow (12v), red (5v) and orange (3.3v) wires. If the voltages come back more than 10-15% off, you will most likely need a new power supply.
Even if you have good voltages using the test method above, it is only an indication that your voltages are good at zero load. Your power supply may still fail under normal load. If you have recently added any hardware to your computer, remove it and try again. If this still doesn't work or you haven't added any hardware recently, replace your power supply.
May 13, 2010 | Computers & Internet
Green light lit but will not start, no fans running
Without further knowledge of it's previous condition, I would say the power supply is bad. There are multiple rails of voltage in a power supply, while one may be functioning, a 2nd is not and therefore it will not pass its own pre-test and therefore will not function as a whole. I had the same exact description recently, I replaced my power supply and it was functioning perfectly. If there is another computer in the house with the same watt/voltage power supply, try swapping it out.. if the computer starts, the power supply is your problem.
Feb 08, 2010 | Abit IC7-MAX3 Motherboard
Regarding the blinking green light on power supply for hp a430n...I've had that happen as well when the computer is turned off for an extended period of time. It would not immediatly power up when plugged in to power. Hitting it and beating on the button didn't help either.
However, after calming down, I noticed that when I unplugged the computer that the light continues to blink, but gradually fades and goes out. So, I thought that since power supply holds a charge after being disconnected as can other components inside a computer that I would assume the converse: It needs to power up to "full charge" as well. In my case, I was right.
All I did was plug the computer in and leave it alone for about 20 to 30 minutes, go sit and cuss for a while. When I came back and checked it after that time, the front panel blue light was on and the green light on the power supply was glowing steady. The computer started right up! Thank goodness...stopped cussing.
If it hadn't, and I had tried all the resets listed above, I would have bought a new power supply too...but not this time!
Oct 21, 2007 | HP Pavilion a420n PC Desktop
Help needed.....
Hi Octane, If you?re not getting any beep codes then something real basic is wrong. To start off I would check the following: -check the new power supply and ensure it is designed for your motherboard. -check the power supply connections to the motherboard, the connectors should mate up exactly to the motherboard connector. -check for shorts (mounting screws against capacitor leads are common), correct grounding and so on. Any of those can cause the same symptoms. -test the power supply in another computer or if not available you can generally pickup an inexpensive tester for $10 to $15 at a computer store that sells parts. -make sure your motherboard is designed to accommodate your processor. I would expect a beep code for this but you never know. Let us know how things go and please don?t forget to rate the posting.
Jan 04, 2007 | Foxconn (865G7MC-ES) Motherboard
HP m7170n PC Desktop Logo
131 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
