I have the same problem. It work very well in inverting but when pass i charging mode burn some of mosfet transistors. I replace them and it works somehow if I insert few 470uF 63V. But although all capacitors looks good in capacitance and ESR when I solder all them it burns again some mosfet transistors in auto mode when pass from inverter in charging mode. It work as charger if the swich is in charge only. I need help with the scematics. I have replaced also the lm339 and lm393 comparators but still problem persist in auto mode.
Check if the fuse for the charger is broken
