Question about Admiral AW22 Top Load Washer
I have an Admiral designer series washer with extra wash setting. It has been dying slowly. First all of the spin cycles quit working except one, now none work. It also won't agitate. Is there any chance it could be something easy like a coupler or belt?
SOURCE: loud noise while agitating in wash cycle
If you begin dissassembly from the tub down, you wil come to the transmission with the spindle sticking out of it. If you undo the bendable tabs all around the transmission it comes apart in two halves. Careful, its full of oil. The spindle has a plastic gear bolted to the bottom of it. It meshes with other gears in the tranny. It has sheered teath and is making the noise.
Posted on Feb 11, 2008
Yozzer6821
  • 116 Answers
SOURCE: Admiral Washer model #LNC6757 will not agitate
Possibly a loose agitator, try lifting the agitator, if it lifts then it is un secure, remove the softener cap and down inside the agitator you will see the fixing bolt,
You will need to lift out the agitator to retrieve the bolt if it has come fully un done, refit the agitator and secure using a socket and long extension bar.
Posted on Apr 18, 2008
  • 512 Answers
SOURCE: My Admiral lg capicity washer won't agitate or spin
Sounds like the belt is broken. Yes you can fix yourself. Lift top, remove front cover, belt is at bottom, not to hard to replace. If belt is not broke let me know, I will go further.
Posted on Jul 17, 2009
  • 68 Answers
SOURCE: washer stops at the spin cycle and won't drain
check your lidswitch. do you hear it clicking when you raise and lower the lid.
Posted on Dec 10, 2009
Testimonial: "Thank you so much!! I just saved the $ on going and buying a new machine. The lid switch was the problem..Merry Christmas!!"
Yozzer6821
  • 116 Answers
SOURCE: Admiral Designer Series model #LNC6759A71 Motor
Sounds like the motor capacitor or brushes. requires replacement or further investigation.
Posted on Jan 05, 2010
Washer stops at the spin cycle and won't drain
Dec 10, 2009 | Admiral AW22 Top Load Washer
The admiral washing machine works fine except on the spin cycle it wabbles wildly, like the clothes are loaded on one side. but does it even while washer is empty
At its best this washer is a beast in the spin cycle. The machine must be mounted on a cement floor. It is written in the unpacking instructions. Check all springs, machine must be level. If all checks out replace snubber ring or adjust by centering snubber ring Mounted unde the transmission base.
Jun 22, 2009 | Maytag Admiral AAV7000A
Sometimes does not spin enough to wring out water from clothes.
The spin cycle should be on a timer,and shouldn't be able to change how long it spins.The same timer that controls all the cycles of your washer.Your pump may be trying to go out,and isn't removing the water fast enough.This will keep water in the tub,and the normal spin cycle isn't long enough to let the pump get the job done.Another problem might be a clog in your drain hose.Another problem could be the drain hose is set to high above the pump,and the pump can't push it up that high (shouldn't be a problem if you are using the hose that came with the washer,and not extending it with another hose or something.)
Jun 05, 2009 | Admiral AW22 Top Load Washer
Admiral is not spinninng
i would say the simple soulation to this is get the main belt tightened.sounds loose???.hope this helps.adrian
Jan 31, 2009 | Admiral AW22 Top Load Washer
Top load washer Admiral # AAV7000AWW
I would replace the belt part # 21352320 which cost about 20 bucks. Tilt the machine back when off and empty and look for a glazed belt with maybe some cracking and wear.
Sep 01, 2008 | Admiral AAV7000A
Admiral Designer Series Super Capacity Washing Machine
This machine will rotate the motor to agitate in one direction and then reverse to activate the pump and the clutch for spin. I would remove the inspection plate and watch the motor and pump in action in both wash and spin, go to www.apdepot.com and dig around you will find parts and a wire schematic on this machine.
Jul 23, 2008 | Admiral AAV7000A
Admiral Washer not spinning
broken or slipping drive belt, ( motor) to spin pulley , losse pulley, defitive drive clutch, spin brake fails to release, or transmission is frozzen
Jul 07, 2008 | Admiral AW22 Top Load Washer
Admiral AW22 Top Load Washer Logo
71 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
