Question about HP 1040 Plain Paper Inkjet Fax
I am having problems receiving a fax.
I can send a fax but I am unable to receive a fax. If I dial the fax number, the fax machine does not ring and the call will eventually go to voicemail. It is the HP 1040 fax machine.
  • 1,959 Answers
Check the number of rings your fax machine is set to. Chances are, the answering machine is set up for 4 rings and the fax machine is set up for 6. If this is the case, change the number of rings on your fax machine to 2 or 3 rings to ensure an incoming fax will go directily to the fax machine. If the fax doesn't recognize the call as a fax, it will go through to the answering machine.
Posted on Jul 17, 2009
  • Greg Margossian
    Greg Margossian Jul 23, 2009
    Kindly rate the solution you've been provided if you feel it answered your question. Thank you very much.
We are having issues faxing to one particular number. We think our fax goes through, but spits out a Error 345*. Nothing is sent
fax machines talk to each other before sending data to ensure that the sender/receiver are on the same format and are compatible
for one particular number to be a problem indicates a fax number problem in setting the dialed number area code , dashes etc are all specific
ring the receiving department and ask to confirm that they are having trouble receiving faxes from your number as well
Dec 14, 2016 | HP Office Equipment & Supplies
I am unable to send a fax brother intelifax 775 fax manual
go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set.
make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
Hope this helps. Please rate my response.
Thanks.
Have a good day
Dec 24, 2010 | Brother IntelliFAX 775 Plain Paper Thermal...
My faxes will not receive because of communication errors
Scenario 1
In the HP Solution Center, click Settings, point to Fax Settings & Setup,
and then click Fax Setup Wizard.
After you have connected the phone cord to the port labeled 1-LINE, run the
fax test again to make sure it passes and the HP All-in-One is ready for faxing.
Try to send or receive a test fax.
Make sure you use the phone cord that came with the HP All-in-One. If you
do not use the supplied phone cord to connect from the telephone wall jack
to the HP All-in-One, you might not be able to send or receive faxes. After
you plug in the phone cord that came with the HP All-in-One, run the fax test
again.
If you are using a phone splitter, this can cause faxing problems. (A splitter is
a two-cord connector that plugs into a telephone wall jack.) Try removing the
splitter and connecting the HP All-in-One directly to the telephone wall jack.
Scenario 2
If you are not using a distinctive ring service, check to make sure that the
Distinctive Ring feature on the HP All-in-One is set to All Rings. For
information, see Change the answer ring pattern for distinctive ringing.
? If Auto Answer is set to Off, you will need to receive faxes manually;
otherwise, the HP All-in-One will not receive the fax. For information on
receiving faxes manually, see Receive a fax manually.
? If you have a voice mail service at the same phone number you use for fax
calls, you must receive faxes manually, not automatically. This means that
you must be available to respond in person to incoming fax calls. For
information on setting up the HP All-in-One when you have a voice mail
service, see Fax setup. For information on receiving faxes manually, see
? If you have a computer dial-up modem on the same phone line with the
HP All-in-One, check to make sure that the software that came with your
modem is not set to receive faxes automatically. Modems that are set up to
receive faxes automatically take over the phone line to receive all incoming
faxes, which prevents the HP All-in-One from receiving fax calls.
124
HP Officejet 6300 All-in-One series
User Guide
Note Some digital answering machines might not retain the
recorded silence at the end of your outgoing message. Play back
your outgoing message to check.
If the HP All-in-One shares the same phone line with other types of phone
equipment, such as an answering machine, a computer dial-up modem, or a
multi-port switch box, the fax signal level might be reduced. The signal level
can also be reduced if you use a splitter or connect extra cables to extend
the length of your phone. A reduced fax signal can cause problems during
fax reception.
To find out if other equipment is causing a problem, disconnect everything
except the HP All-in-One from the phone line, and then try to receive a fax. If
you can receive faxes successfully without the other equipment, one or more
pieces of the other equipment is causing problems; try adding them back one
at a time and receiving a fax each time, until you identify which equipment is
causing the problem.
If you have a special ring pattern for your fax phone number (using a
distinctive ring service through your telephone company), make sure that the
125
If you have an answering machine on the same phone line with the HP All-in-
One, you might have one of the following problems:
- Your answering machine might not be set up properly with the HP All-in-
One.
- Your outgoing message might be too long or too loud to allow the HP All-
in-One to detect fax tones, and the sending fax machine might
disconnect.
- Your answering machine might not have enough quiet time after your
outgoing message to allow the HP All-in-One to detect fax tones. This
problem is most common with digital answering machines.
The following actions might help solve these problems:
- When you have an answering machine on the same phone line you use
for fax calls, try connecting the answering machine directly to the HP All-
in-One as described in Fax setup.
- Make sure the HP All-in-One is set to receive faxes automatically. For
information on setting up the HP All-in-One to receive faxes
automatically, see Set the answer mode.
- Make sure the Rings to Answer setting is set to a greater number of
rings than the answering machine. For more information, see Set the
number of rings before answering.
- Disconnect the answering machine and then try receiving a fax. If faxing
is successful without the answering machine, the answering machine
might be causing the problem.
- Reconnect the answering machine and record your outgoing message
again. Record a message that is approximately 10 seconds in duration.
Speak slowly and at a low volume when recording your message. Leave
at least 5 seconds of silence at the end of the voice message. There
should be no background noise when recording this silent time. Try to
receive a fax again.
Scenario 3
The HP All-in-One might be dialing too fast or too soon. You might need to
insert some pauses in the number sequence. For example, if you need to
access an outside line before dialing the phone number, insert a pause
following the access number. If your number is 95555555, and 9 accesses
an outside line, you might insert pauses as follows: 9-555-5555. To enter a
pause in the fax number you are typing, press Redial/Pause, or press the
Space (#) button repeatedly, until a dash (-) appears on the display.
You can also send the fax using monitor dialing. This enables you to listen to
the phone line as you dial. You can set the pace of your dialing and respond
to prompts as you dial. For more information, see Send a fax using monitor
dialing.
? The number you entered when sending the fax is not in the proper format or
the receiving fax machine is having problems. To check this, try calling the
fax number from a telephone and listen for fax tones. If you cannot hear fax
tones, the receiving fax machine might not be turned on or connected, or a
voice mail service could be interfering with the recipient's phone line. You
can also ask the recipient to check the receiving fax machine for any
problems
Dec 03, 2010 | HP Officejet J3680 Multifunction Printer...
Can't receive fax's......how do you set it up to receive...thank you
again.
Scenario 2
124
User Guide
fax reception.
125
One.
disconnect.
Scenario 3
dialing.
problems
Dec 03, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Unable to receive faxes. Able to send and cartridge printing OK
There can be a few things wrong lets take it step by step
1)Receive mode,your receive mode must be set correctly.If you don't have a tel connected to it, you cant use it as a Manual receive mode,it must be set on Fax only.If there is a telephone connected to it and it is set on manual mode make sure your Incomming ring is set to ON,you will find it under additional functions,RX settings,Incomming ring.
2)Make sure you have enough memory to receive a Fax.Go additional function,dataregistration,TX settings,Erase failed TX,set it to on.
3)Make sure there is enough toner and paper for the machine.
4)Tone or Pulse Dialing,depents in witch country you are make sure it is set correctly Tone or Pulse.You will find it under user settings.
5)There can be a problem at the you local exchange,you can send faxes but the exchange can be faulty and you would be able to receive faxes.
6)And then there can be a problem with you fax machine' NCU PCB board,there is to gas arresters one for send and the other for receive.If one of them are faulty you will have to replace the NCU.The gas arresters is not available as a part.
Dec 09, 2009 | Canon FAX-L360 Plain Paper Laser
Cannot send faxes on my all in one hp office jet 5610
If the recipient side is ringing, then the problem is on their end. It sounds like the receiving fax is not set for auto-answering a fax call. A receiving fax machine should pick up and start to attempt the reception even if the fax number is dialed from a normal voice-only telephone; the receiving machine has no idea if the caller is a fax or a regular phone. It should pick up regardless and start to negiotiate the fax (that's the high-pitched whistling sound at the beginning of the call).
May 15, 2009 | HP Officejet 5610 All-In-One InkJet...
Cannot receive faxes, but can send
I can send faxes from my HP Fax 1010, but cannot receive them. I can dial the number from another phone but it will keep ringing and the machine never picks up. We have tested the phone line and all seems well. Is there some setting on the fax machine itself that I need to change in order to receive? Any assistance you can provide would be greatly appreciated.
Aug 25, 2008 | HP 1010 Plain Paper Inkjet Fax
Panasonic KX-FL511 cannot receive faxes but can send
check to see if your phone line is plugged in the " L" or line slot on your fax machine if it is then press the speaker or monitor key and listen for dial tone. then you put a document into the feeder and dial your cell phone number and press send, when your cell phone rings answer and listen if you are getting a high pitched squeel. if you are then it should be working. try it the other way too by dialing from your cell and listen again for the squeel. if you still don't get the squeel you have a defective modem.
Thank You,
Mikey
Thank You,
Mikey
Apr 05, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
Cannot receive a fax
I had the same problem when i first install my fax machine and at that time I only had the black ink cartridge in the fax machine one's I installed the color ink cartridge, my fax machine started working.
Mar 03, 2008 | Lexmark X4270 All-In-One InkJet Printer
HP 1040 Plain Paper Inkjet Fax Logo
688 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
