My acer 5610 has a screen problem! The screen
My acer 5610 has a screen problem! The screen turns pink then goes dark-as in not working-in just a few seconds of start up. I conected another monitor to the laptop unit. I was able to use the unit normally, so the problem is in the screen display or the screen itself. I have contacted a repairperson and was told that this 2 year old unit would be $275 to repair and I should just replace it. I think it is about a $500.00 device. I am really dissatisfied that this would only last 2 years. Help!
My screen keeps going dark. I have replaced the
Its not the inverter, it's your backlight. Hard work to change, sorry, and it might be cheaper/quicker to replace the whole lcd panel at $100 (£65)
Jul 26, 2010 | Acer Aspire 5610-2328 Notebook
Screen turns on when powered up then goes blank.
It sounds like you are having a backlight problem with your computer. The backlight is the part of the LCD assembly that lights up behind the LCD and shines through.
Sep 09, 2009 | Acer Aspire 5610-4491 Notebook
I have acer aspire 4315 sometimes screen turn to pink but i can read but its annoying.. help pls.
Hi I have a Acer Aspire 1694wlmi, and when I start her up I get a pink colour to the screen, after 1 minute it reduces to only one corner?
Jul 15, 2009 | Acer Aspire 5610-4648 Notebook
Screen is bright neon pink!
Did you also replace the power inverter when replacing the screen???
Feb 13, 2009 | Acer Aspire 5610-4648 Notebook
Acer Travelmate LCD screen went dark
The same thing happened on my HP. I ended up buying a LCD screen off ebay. That corrected the problem. New screens cost $150+. You can get one off ebay for half the price.
Jan 16, 2009 | Acer TravelMate 270XV Notebook
White turns to pink on acer laptop
The problem is CCFL light bulb in the screen. It is starting to die :( Can be replaced but that is not an easy task (easier is to replace screen as new bulb comes with it)
Jan 12, 2009 | Acer Aspire 5630 Notebook
Acer aspire 5610 screen brightness fading
if you're not plugged in your laptop may be doing power management by lowering the brightness. If you are plugged in could you provide some more information?
Jan 07, 2009 | Acer Aspire 5610-4648 Notebook
I had the same problem but the white color became cyan.
I "solved" the problem hiting the back of the monitor. I think that is a problem of contacts between the signal of the monitor and the pc.
I have an acer 5610z.
Juan Pablo.
Jul 28, 2008 | Acer AL1916B 19" LCD Monitor
Computers & Internet Logo
127 people viewed this question
David Payne
David Payne
