Question about Lowrance LGC-3000 GPS ANTENNA FOR UNITS (042194530055)
Every time i turn on my lowrance 520c it says gps module not resp
It is intermittent it usually has a question mark blinking on the icon the gps module is a lmc 3000 and the unit is about 2 years old
I had the same problem. Sent my entire unit back to Lowrance, but they said it was fine. One year later, I find out that I did not receive or have the correct parts to hook up the GPS unit. I needed the NMEA 2000 T connector and terminator plugs. Look at your manual and hook it up the way the manual says. It will require a NMEA 2000 T and at least one 60 ohm terminator plug. Seems the GPS module sends back some kind of signal that if not absorbed by this thing will mess up your unit. Mine works since I got it hooked up correctly. HD
Posted on May 13, 2010
Lowrance X135 blows in-line fuse and won't power up? How to troubleshoot
First, follow the wire from the fuse to the unit. It may be pinched or cut somewhere between those two points. Seems simple, but this happens often. If the wires look ok, You could also try a fuse one size bigger. If it blows that fuse, then the problem is in the unit, and you will have to sent it out for repair.
Apr 10, 2014 | Lowrance Lms 520c 5" Screen Color External...
LMS 520c back light not working
the light switch is in the power up button...turn the unit on let it boot up then push power button to set light as you want it do not hold down power button that will just turn unit off.. push the power button just one time if you want light brighter push till you get the back light you want
Jan 21, 2014 | Lowrance Lms 520c 5" Screen Color External...
Flashing screen
two things can be taking place 1 you have a bad key pad 2 you have a bad transducer(short in wire )
Oct 22, 2013 | Lowrance Lms 520c 5" Screen Color External...
I have a lowrance LMS 520c and I never pick up any fish. it does show the bottom
read the book that came with it you got to understand how it works and know how to set your unit before you can understand how it works and what you need to do to make it work and to get to what settings you want ..a fish finder is like a computer you got to program it to your likings .. I have a hd 10 structure scan on mine .. .now that's a nightmare to set but the book tells you everything you need to do and how to do it and how to get what your looking for and how to get to it
Jul 28, 2013 | Lowrance Lms 520c 5" Screen Color External...
Lms 520c 5" Screen Color External Gps And 200 Khz Sonar System: I have a Lowrance LMS 520C on my boat. The GPS wi...
I have the same problem on my 520C.
I have no solution but I hope you have find some?
Best regards
Dan
May 07, 2010 | Lowrance Lms 520c 5" Screen Color External...
My lowrance 520c GPS stopped working. When I turn it on it shows the last lake I was AT. And the trail marker does not work
I have a 525... Several things and go step by step... First, make sure your getting 12v of power to your "puck"... On the Lowrance site there is a step by step guide for testing. Just because your getting power to the main unit does not mean your getting power to your the gps module. There are three different power sources on these units. Main power, sonar and gps! If your getting 12v coming out of the data port then check power to the cords, and to the T... If all that is correct the its likely your gps module. You can order a new one directly from Lowrance customer support for 50% off the normal price as a replacement. They will likely upgrade you to the 4000 series. Comes with all wiring, T connector but not the resistor cap. Best time to call Lowrance is 8:15 am central time when the phones are turned on!
Mar 04, 2010 | Boating
I purchase a lowrance LMS-520C about 18 months ago. The depth gauge cuts in and out. It works for a while then defaults to 3.3 feet while trolling. Can you point me in the right direction to find the...
Quite often those transducers go out. Not 100% sure but would bet money on it. Call Lowrance customer support and see if the offer any more advised but more importantly see if they can replace your current one as a replacement instead of you having to pay full retail price. I purchased a new gps module through customer support and saved $150 off the normal retail price. Best time to call customer service is at 8:15am central time when the lines are turned on!
Feb 28, 2010 | Lowrance Lms 520c 5" Screen Color External...
Is online training available for the LMS-520c?
Haven't found any. But the manual covers about everything
http://www.lowrance.com/upload/Lowrance/Documents/Manuals/LMS525CDF-520C_0151-461_120706.pdf
252 pages, you should be able to find answers to any problem you might have with the unit from there.
Sep 14, 2008 | Lowrance GPS
Gps module not responding
can not be fixed from home. i'll have to send it back to lowrance. tried soft reset and hard reset, gps module not responding icon still pops up on screen, thank you for the suggestions.
Jul 11, 2008 | Lowrance GlobalMap 3500C GPS Receiver
Lowrance332
had same problem with lms337. i had upgraded the unit but had not upgraded the lms2000 gps module. i was turning the isolator on in the boat which powers up gps module, if the lms337 is not powered up as well the gps unit goes to sleep. the upgrade fixes it by checking that the unit has not been turned on periodically. otherwise as soon as you power up gps module also turn on lms337. lowrance product support sorted this for me.
Mar 02, 2008 | Lowrance LMS-332C GPS Receiver
Lowrance LGC-3000 GPS ANTENNA FOR UNITS (042194530055) Logo
783 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
