Question about Kenmore Oasis HE 27082 Top Load Washer
Beep.beep.beep. I can't take the beeping anymore. I have to unplug my washer when it is not in use. My model 110.27072602 totally frustrates me. My model, according to the 1-800 recall number, says my model is due for an "upgrade". Anyone been "updated" and have the beeping stop?
  • 15,935 Answers
This symptom indicates a stuck key on the user interface control board.
Replacing this control board would most likely fix this type of problem.
The part number for the user interface for this model is 8564374.
You can order this part from SearsPartsDirect.com, RepairClinic.com, PartSelect.com etc.
The procedure for replacing this control board is shown in the images below.
Before buying any parts I suggest you access the interface ribbon and disconnect it and then connect it back and see if there is any improvement.
You might also remove the interface from the console and check the console for any stuck buttons.
Remember to unplug the washer first.
http://media.fotki.com/1_p,wkgbsdrbswtkdqwxgtqsskgwtqkq,vi/ksgtwdgrtxkrrffsdss/1/1303472/5961857/image29464img-or.jpg
http://media.fotki.com/1_p,sqrbbsbrrbwrbdtxgtqsskgwtqkq,vi/kbqtdwdswxkbswddwbg/1/1303472/5961857/image23056img-or.gif
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
I just replaced the door latch on my kenmore front loader washer model 11047532601 the door locked light doesnt come on and the door locked light isnt coming on all i get is beep beep beep
You have a bad CCU. This is the control board on the top of the unit. Remove the top, three screws on the back. The board clips into the position. You can try to unplug the wires one at a time, the control will probably have to be replaced.
With the model I would be able to better assist you.
Mar 31, 2011 | Kenmore HE2 Plus Front Load Washer
I have a Kenmore Elite washer, Model 110.20096993, it starts beeping with about 10 mins left in the cycle and shuts off. Any thoughts?
I have the same model - it displays 10 minutes and keeps beeping in series of 3 (beep beep beep...... beep beep beep... etc..) ran through a cycle successfully but kept beeping like that the whole time. I unplugged it for 10 minutes but had the same symptoms after plugging it back in. I unplugged it for 24 hours, and that seems to have cleared the problem up.
Jun 12, 2010 | Kenmore Washing Machines
I have bought a fisher and paykel model DW60CSX1 second hand... i have connected all the relevant pipes and taps, the washer gets to a point in the cycle where it stops and thw 1st, 2nd and 4th lights...
My manual says that this means the drain hose is crimped or bent, or the drain hose is too high. In other words, the drain can't drain for some reason.
Dec 13, 2009 | Fisher Dishwashers
Abit nf8-v keeps beeping when turned on. no video
How is the beep sounds? Long beep and three short beep or one (-...) or all long beep?
For the first, usualy the VGA connector is not correctly seated, so the motherboard can say it has no output device and beeping.
The last is usually memory problem. Try, unplug your memory board and replug it again, make sure that it is correctly seated.
Dec 10, 2008 | Abit NF8-V Pro Motherboard
Camera beeps and shuts off
sorry to hear you are having this issue. well the problem is your lens. the len motors have locked up and are stuck the lens needs replacement. repair run any where from 75.00 and up in most cases.i repair these all of the time.let me know if i can help out any further.
Nov 02, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
My oven wont quit beeping!
It depends on the actual model number (that you didn't supply), but most Kenmore F7 errors indicate a bad keypad or bad control panel. If you unplug the ribbon cable from the keypad to the panel then plug the oven back in and it starts beeping again, it's a bad control panel, if it doesn't beep anymore, it's a bad keypad.
Please unplug the oven power with working on it.
Geno
Aug 02, 2008 | Ovens
Lights come on and it beeps
The timer may be stuck, you may have to change the timer.
Apr 15, 2008 | Frigidaire ATF6000ES Front Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
29 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
