Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
Husqvarna tth2148 unit dies on clutch/brake release motor runs fine wheels appear to lock up after a short very short distance also when pto switch pulled unit dies. Help please
  • 130 Answers
Sound like you have a safty switch bad
Posted on Jul 18, 2009
  • trey Oct 04, 2013
    where is it located as I can't locate the manual
Husqvarna yth2348 was cutting grass it sputtered died and now wont start just clicks
It may also have a partially short PTO clutch drawing so much power that the alternator can not supply enough power so it drains the battery until the fuel shut off solenoid kills the engine.
These PTO normally draws 5-7 amps with a resistance of about 1.7 ohms. Anything under 1.5 ohms indicates a shorted condition. I had a couple clutches that was still working but was pulling 18+ amps.
Apr 30, 2015 | Husqvarna Garden
YTH2242 goes dead when i try to go frward,backwards or engage the blades
Make your Operator seat switch is connected securely. If it is loose or disconnected it will kill the engine if release the clutch/brake or try to engage the pto. The connector contains a shorting strip that shorts the wiring hasness when it is disconnected.
Mar 27, 2015 | Husqvarna Garden
Husqvarna yth2148 mower dies when clutch is released or deck is engaged. has new seat switch, clutch switch and pto switch whats my solution
Has the belt been replaced recently? A two small belt with kill the motor due to too much tension on the driveshaft. Also make sure blades spin relatively well. I'd be looking for excess tension.
Sep 12, 2013 | Garden
L130 John Deere PTO problems
you have a bad seat switch
Sep 21, 2012 | John Deere Garden
Cub cadet 2166 dies when I engage PTO or let brake peddal all the way up
replace that safety switch there is two switches built into one
Jun 11, 2012 | Cub Cadet Garden
Pto, electric clutch
check the wires they rub on sharp edges
Mar 23, 2012 | Husqvarna Garden
'91 oldsmobile cutlass ciera starts and runs fine but dies when driving short distance, restarts and runs fine but dies after another short distance.
Hello! I need the trouble code...The vehicle is an On Board Diagnostic 1 (OBD!)...You can not use a scanner on an OBD1...See drawing below of connector under the steering wheel...Short pins A to B...Turn on the key...Don't start the engine...Light on dash will flash the code ie...4 long blinks...pause... 1 short blink=code 41...each code, if more tan one, will flash 3 times...record the code # and send it to me and I'll fix the problem....codes are all two digit... guru...saailer
Dec 13, 2011 | 1991 Oldsmobile Cutlass Ciera
Bobcat ZTR new blade brake won't engage while engine is running
SOUDS LIKE THE CLUCH SAFTEY SWICH IS BAD OR THE SEAT SWICH MAY BE BAD CK THAT OUT AND LET ME KNOW OK THANKS
Aug 18, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
Husqvarna yth180
check the seat switch
Jun 09, 2009 | Husqvarna Garden
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
197 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
