Question about Microsoft EXCEL 2004 for Mac
Doesn't remember there's a Header Row
I have a file with a header row that I use in Data/Sort. File suddenly no longer remembers there is a header row or what the previous sort was. How do I get it to "remember"?
    President:
  • 2,185 Answers
You can try to select all data (except for the entire row which contain your header) and try to sort thru columns. This can sorted in ascending or descending order.
Posted on Jul 21, 2009
Need emachines t3306 motherboard connection diagram
The eMachines T3306 desktop computer, uses the FIC K8M-800M motherboard.
First International Computer, (Inc)
http://www.fic.com.tw/product/motherboard/amd/ficimages/k8m-800m.jpg
http://www.fic.com.tw/product/motherboard/amd/k8m-800m.aspx
Here's the download page for the motherboard manual,
http://www.elhvb.com/mboards/OEM/eMachines/manuals/index.html
Column in middle, 3rd file from bottom.
This is a Zip file. A Zip file is a Compressed file. Used to send large amount of information more easily.
Has to be decompressed, or 'unzipped'.
After you click on the blue -> FIC K8M-800M file name, a small window will come up-
Opening K8M-800M_manual.zip
Make SURE there is a Green dot in the small circle, to the left of Save File.
IF not; click in the empty circle to the left of Save File.
No go below in the small window, and click on OK.
A small download window will come up.
Allow the file to fully download all the way, then DOUBLE-click right on the file name.
(Yellow folder icon with a zipper on it. K8M-800M_manual.zip is to the right)
In the next small window go to the far Left, and click on -
Extract all files.
At the bottom of the next 3 small windows click on Next, Next, and Finish.
In the last small window DOUBLE-click right on the file name ->
K8M-800M_manual
(Next to the red Adobe PDF icon)
There is your motherboard manual in PDF file form.
For an example;
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the Main wires from the Front Panel go to; is the Front Panel header.
Motherboard installed in computer case, the Front Panel header is at the Bottom/Right.
The Front Panel header is Orange in color. (Page 20)
Two rows of contact pins.
5 pins across the Top row.
4 pins across the Bottom row.
The Top row is numbered ODD.
The Bottom row is numbered EVEN.
Starting on the RIGHT side going across to the Left; Top row,
Pins 1, 3, 5, 7, and 9.
Starting on the RIGHT side going across to the Left; Bottom row,
Pins 2, 4, 6, and 8.
A) Pins 1 and 3 are for the HarDDrive activity LED light.
Pin 1 is for the Positive ( + ) wire.
If the HDD LED is dim when the Harddrive is active, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C. Not Connected.
Reserved for factory use. Probably a 5 Volt test point.
D) Pins 2 and 4 are for a Power On LED light.
These two pins are used for a Single color, Power On LED light.
Two wire LED light.
Pin 2 is for the Positive ( + ) wire.
If the PWR LED is dim when the computer is on, switch the wires around.
There is ALSO a jumper used for this LED light. More on it at the end.
E) Pins 6 and 8 are for a Power On switch.
To the Right of the Orange Front Panel header, (F_PNL), is the PW_LED header.
[Page 20 to right of Front Panel header. -> PW_LED
(Power LED, 2/3 Pins) ]
3-pin Black header. Sits Vertically.
(The Orange - Front Panel header, sits Horizontally)
This is used for a 3-wire Power On LED light.
Used for a Dual Color - Power On LED light.
One example is if the computer has Turbo Mode, and Normal Mode.
Green color usually for the Turbo Mode, Yellow color of the LED for the Normal Mode.
Starting from the BOTTOM going UP;
Pins 1, 2, and 3. (3 at the Top)
A) Pin 1 is for the Positive ( + ) wire. [Signal]
B) Pins 2 and 3 are for the Ground wires.
Jumper block for the 2-wire Power On LED light, and 3-wire Power On LED light; Page 13 - Set System Jumpers
(Actually it starts on Page 12)
6-pin header to right, of 3-wire Power On LED header.
Has Blue jumper caps on it. Two of them.
(PL_LED1)
http://www.ebay.com/itm/NEW-FIC-uATX-Skt-754-AMD-Desktop-Motherboard-VIA-K8M800-AGP-4x-8x-DDR400-800FSB-/280923928691?pt=Motherboards&hash=item41685ef873
Two rows of 3 pins.
The bottom row is numbered EVEN.
Starting on the RIGHT side going towards the Left; Top row,
Pins 1, 3, and 5.
Starting on the RIGHT side going towards the Left; Bottom row,
Pins 2, 4, and 6.
A) With the jumper caps on Pins 3 and 5; plus 4 and 6; the Power On LED light works as a Single color LED.
B) With the jumper caps on Pins 1 and 3; plus 2 and 4; the Power On LED light works as a Dual color LED.
For additional questions please post in a Comment
Regards,
joecoolvette
Mar 07, 2013 | Computers & Internet
M4n68t-m with bad power switch need to jump pin but witch ones
Another one of life's mysteries, and we shall probably never know
OH WAIT! Silly me! I forgot you can go to ASUS SUPPORT, and download the USER MANUAL,
http://www.asus.com/Motherboard/M4N68TM
http://www.asus.com/Motherboard/M4N68TM#support
Click on the Download tab.
(Knowledge Base / Download / Memory/Device Support / etc)
To the right of the - Select OS - box, click on the blue Down Arrow
Click on WinXP. Doesn't matter what Operating System you choose, you are just going for the User Manual. (Motherboard manual)
Give it a few seconds to load.
Scroll down, click on the + sign to the left of - Manual (5)
Scroll down.
Version E5215 M4N68T-M user's manual - English
Click on the blue - Global
A small window will come up -
Opening E5215_M4N68T-M_manual.zip
Make sure the small circle to the left of - Save File, has a Green dot in it.
IF not; left-click in the small circle to the left of - Save File.
Now click on OK below.
A small download window will come up. Allow the file to Fully download, then DOUBLE-click right on the file name.
(E5215_M4N68T-M_manual.zip)
In the next window go to the left, and click on - Extract all files
At the bottom of the next 3 small windows, click on -
In the last window DOUBLE-click on the file name.
E5215_M4N68T-M to the right of the red Adobe PDF icon.
The area of contact pins on the motherboard, that the main wires go to, is the Front Panel header.
You need a Front Panel header pinout.
When I refer to a page in the manual, it will be for the Adobe Reader page number box, at the top.
Go to Page 1-7
1.5.3 Motherboard layout
Number 12 shows us the Front Panel header.
Motherboard mounted in computer case, the Front Panel header is the 3rd header from the Left; on the bottom of the motherboard.
(System panel connector (10-1 pin F_PANEL)
Go to Page 1-25
There are two rows of pins.
4 pins across the Top row; 5 pins across the Bottom row.
Not numbered, so I will;
Starting on the LEFT side, going across to the Right; Top row,
Pins 2, 4, 6, and 8. There is NO Pin 10
Starting on the Left side, going across to the Right; Bottom row,
A) Pins 2 and 4 are for the Power On LED. (Light Emitting Diode)
B) Pins 6 and 8 are for the Power On switch.
C) There is NO Pin 10.
D) Pins 1 and 3 are for the HarDDrive activity LED.
E) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
F) Pin 9 is N/C.
Not Connected.
Probably a 5 Volt (DC) point for the factory to test with.
(So it's Reserved for the factory)
Here is an example of an ATX power on switch, that is used in MANY desktop computers,
http://www.directron.com/atxswitch.html
Remember; the Power On switch is a Momentary Contact Switch.
This means the contact period you make across those two pins, shouldn't be more than 2 seconds.
Next time you do not know the Front Panel header pinout, of a motherboard;
Use an LED light with two wires.
Touch two pins at a time, going along the FP header.
Computer turns on? You have the Power On switch pins. Now you can continue on.
LED light stays on? You have the Power On LED pins.
LED light blinks? You have the HarDDrive activity LED pins.
Computer restarts? You have the Reset switch pins.
Power On LED winks at you seductively?
Put that left-handed cigarette down, and go get sum fresh air.
For additional questions please post in a Comment.
Regards,
joecoolvette
Jan 16, 2013 | VIA ASUS A7V8X-MX KM400 Chipset Ultra...
Location of the usb pins on the mainboard
http://www.matsonic.com/Computer-Desktop-Support/Models/ms9307c%2Bseries.php
Go to the small list on the left side, under the bold black subheading - Matsonic Motherboard Manuals (PDF)
Left-click on - MS9307C
When the small window comes up on the right, make SURE there is a Green dot, in the small circle to the left of - Save File.
IF not left-click in the small empty circle to the left of Save File.
Now go below, and click on OK.
A small window will come up on the left. Allow the file to fully download. Then DOUBLE-click right on the file name.
Go to the far left side, and click on Extract all files.
Then click on Next, Next, and Finish, at the bottom of the next three small windows.
In the last small window DOUBLE-click right on the file name, next to the red Adobe PDF icon.
There is the motherboard manual.
Go to Page 14 of the Adobe Reader page number. (Top header)
Actual manual page number is 10.
Motherboard installed in computer case, USB1 header is at the bottom right corner. It lays Parallel to the bottom of the motherboard.
5 pins across the Top row, 4 pins across the Bottom row.
USB2 header is right above the top white PCI slot. (PCI 1 slot)
5 pins across the Top row, 4 pins across the bottom row.
Pinout for the USB headers is on Page 22 of the Adobe Reader page number. Page 18 for the actual manual page.
Regards,
joecoolvette
http://pinouts.ru/Slots/USB_pinout.shtml
Oct 23, 2012 | Matsonic MS9307C+ (810884003185)...
MX46-633V CONNECTING FRONT USB
I believe you're referring to the AOpen MX46-533V
The Front Panel USB header is Blue in color, and located in-between the white No.3 PCI expansion slot, and bottom edge of the motherboard;
http://www.ebay.com/itm/AOpen-Model-MX46-533V-Socket-478-Desktop-System-Motherboard-/130774572519?pt=Motherboards&hash=item1e72c59de7
With the motherboard in the installed position;
Pins across the Top row are numbered EVEN
Pins across the Bottom row are numbered ODD
Starting on the Left side coming across to the Right, Top row;
Pins 2, 4, 6, 8, and 10
Bottom row;
Pins 1, 3, 5, and 7
There are TWO USB connectors supported off of this USB front panel header.
For one of the USB front panel connectors;
A) Pin 1 is USB PWR 0
Goes to the VCC contact pin on the USB connector.
B) Pin 3 is USB_FP_P0-
Goes to the D- pin on the USB connector.
(Data - )
C) Pin 5 is USB_FP_P0+
Goes to the D+ pin on the USB connector
(Data +)
D) Pin 7 is Ground (GND)
Goes to the Ground (GND) pin on the USB connector
E) No pin 9
F) Pin 2 is USB PWR 0
For the other Front Panel USB connector;
A) Pin 2 is USB PWR 0
Goes to the VCC pin on the USB connector
B) Pin 4 is USB_FP_P1-
C) Pin 6 is USB FP P1+
D) Pin 8 is GND
E) Pin 8 is USB_FP_OC0
Leave unconnected
This is more information on a standard USB connector pinout,
http://en.wikipedia.org/wiki/USB
( A USB connector, and a USB plug are not wired the same.
The plug is wired backwards from what a connector is.
Otherwise you would have power and signal going to the wrong pins, and burn the USB Front Panel header out on the motherboard )
AOpen MX46-533V motherboard manual, but it is in Japanese.
May be one in English out there.
The Front Panel header pinout, USB header pinout, etc, is easily cross identified,
http://global.aopen.com/products_download.aspx?sDropDownProd=52
Manual / Japanese manual for MX46533V / Japanese / 1/28/2006
Go to the far right, and click on the Floppy Drive icon above -
3701.1 KB
On the next page click on the mirror server website that is closest to your country.
This is a PDF file.
The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the country server name it may take up to 30 seconds, before the first page comes up.
(File is downloading in background)
Regards,
joecoolvette
Oct 19, 2012 | ASUS P5PE-VM Motherboard
Wiring Diagram For Usb flashdrive
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually ((red white green black)) make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
or
PRODUCT NAME
FRONTX USB Type A Internal
PRODUCT CODE
CPX101-2
BAY USAGE
Half of large bay
CONNECTORS
USB type A female
1x5 header connector female
CABLE
USB cable (UL 2725)
Length - 2.5 feet (762 mm)
WIRE ASSIGNMENTS
Red: + 5V / Voltage + / VCC
White: D - / Data - / USB -
Green: D + / Data + / USB +
Black: GND / Voltage - / Ground
Black: S-GND / Over Current / Shielding
The S-GND wire is fatter and can be easily recognized. The connection of S-GND wire to the header pin is optional.
HEADER CONNECTION GUIDES
Diagram 1: On most motherboards, the USB header/pin-out consists of 9 pins arranged in 2 rows, which allows for 2 USB connections (i.e. USB1 and USB2). Normally, the pins for USB1 and USB2 are in seperate rows.
Diagram 2: Simply plug the connector onto the 5-pins row, and make sure that the pin assignments and wire assignments are matched correctly.
Diagram 3: Alternatively, you can plug the connector onto the 4-pins row, and leave the S-GND wire unconnected.
You might have to rearrange the wires to match with the pin assignments, or change the header connector if necessary, depending on the layout of the USB header.
On some motherboards, there is a NC pin in the USB header. You can connect the S-GND wire onto this pin. NC simply means "no connection" and NC pin is an "empty" pin.
2X5 PINS HEADER
Refer to the diagram below, for 2x5 pins header, simply plug the connector onto one row of the pins, and always make sure that pin assignments and wire assignments are matched correctly. You might have to rearrange the wires if necessary.
2X4 PINS HEADER
Refer to the diagram below, for 2x4 pins header, simply plug the connector onto one row of the pins. Please note that there is no S-GND pin in this header. You can leave the S-GND wire unconnected. You might have to rearrange the wires if necessary, in such that the wire assignments and pins assignments are matched correctly.
ACTIVE PINS NOT IN THE SAME ROW
On some motherboards, the 4 active pins are not located in the same row, as shown in the example below:
To connect to this type of USB header, you need to change the header connector to 2x5. Simply rearrange the wires within the 2x5 connector to match with the pin assignments. If the green wire is connected to the USB2+ pin, the white wire must be connected to the USB2- pin. The red wire can be connected to any +5V pin, and the black (GND) wire to any GND pin. If there is no S-GND pin provided, you can leave the S-GND wire unconnected.
hope it helps
Sep 23, 2012 | Lexar Media Echo ZX 32 GB Flash Drive
Do you have any user manual for front panel usb
http://www.msi.com/product/mb/PM8M-V.html
(MSI PM8M-V H, is version 2.0 )
Hover your mouse cursor on the Download tab.
(Overview / Specification / Download / Support / etc.)
In the drop down list, click on - Manual
Under the subheading - Download, click on the blue -
M7104v1.0.zip
[ This is a Zip file. A Zip file is a file that is compressed, to send easier. The above manual is for the M7104v1.0
It will work for the version 2.0 also.
You need a program to 'Unzip' it. (Decompress)
If WinZip is not working on your computer, go to 7-Zip, and download for free.
If you need guidance in downloading, and unzipping, post back in a Comment ]
There are two USB headers on the motherboard for the Front Panel,
JUSB1 and JUSB2. (Junction USB 1 and Junction USB 2)
Looking along the bottom of the motherboard, FROM the Right going towards the Left;
JFP1 header; (Front Panel main wires)
Header with 4 pins on the Top row, and 5 pins on the Bottom row.
JFP2 header; (Dual color Power On LED, and Speaker)
Header with 4 pins on the Top row, {Speaker}, and 3 pins on the Bottom row.
JUSB2 header.
JUSB1 header.
EACH USB header will support TWO USB ports in the Front Panel.
JUSB1 supports two,
JUSB2 supports two.
For each USB header there are 5 pins across the Top, 4 pins across the Bottom.
The pins are numbered EVEN across the Top, and ODD across the Bottom.
Starting from the LEFT side going across to the RIGHT side;
on the TOP row for JUSB2 and JUSB1;
Pins 2, 4, 6, 8 and 10.
on the BOTTOM row for JUSB1 and JUSB2;
Pins 1, 3, 5, and 7. There is NO pin 9.
A) Pin 2 is VCC
B) Pin 4 is USB1-
C) Pin 6 is USB1+
D) Pin 8 is Ground
E) Pin 10 is USBOC
Pin 10 is N/C -> Not Connected.
It is there, and Pin 9 is not there, to key which way a connector can go on. Only ONE way.
F) Pin 1 is VCC
G) Pin 3 is USB0-
H) Pin 5 is USB0+
I) Pin 7 is Ground
There is NO pin 9.
(The USB technology used is USB 2.0)
Let's read together,
Under - USB pinout signals;
"USB is a serial bus. It uses 4 shielded wires: two for power (+5v & GND) and two for differential data signals (labeled as D+ and D- in pinout). NRZI (Non Return to Zero Invert) encoding scheme used to send data with a sync field to synchronise the host, and receiver clocks. In USB data cable Data+ and Data- signals are transmitted on a twisted pair. No termination needed. Half-duplex differential signaling helps to combat the effects of electromagnetic noise on longer lines. Contrary to popular belief, D+ and D- operate together; they are not separate simplex connections."
See the USB examples in the link above, where it labels the contact pins?
The MALE connectors are shown on the Left side.
The FEMALE connectors are shown on the Right side.
Your USB ports will be FEMALE, on the Front Panel.
They are also the A style. USB A style. The Top example to the Right.
Just noting the following in case for some reason, the wires coming from those contact pins in the female USB connector, are not color coded correctly;
Even after you have the wires sorted out, as to which contact pins they go to, DOUBLE-check again. Do NOT just go by the color code of the wires.
Why?
You do NOT want to accidentally connect the +5 Volts (VCC), to the Ground!
Explaining further;
You connect the VCC wire, (Red), of the USB port in the Front Panel, to the Ground pin on the USB header on the motherboard.
(Which means the Ground wire of the USB port, (Black), will probably also be connected to the VCC pin, on the USB header of the motherboard)
Zzzzzzap! There goes your front USB ports. Both USB front panel headers on the motherboard, will be DONE!
Make sure!
Going on;
1) VCC or Vcc, goes back relating to Transistor technology.
Just think of it as the Positive, or power wire.
It is.
It is 5 Volts DC.
2) GND is Ground. It's a DC circuit, and you have a Positive, and a Negative, or Ground.
3) USB1-
That is -> Data-
USB0 is for one USB port in the Front Panel.
USB1 is for another USB port in the Front Panel.
[ Each USB header on the motherboard can be connected, to TWO USB ports on the Front Panel.
Therefore for the two JUSB1 and JUSB2, you can connect Four USB ports in the Front Panel ]
Data- on one USB port in the Front Panel, goes to USB0-
Data- on the other USB port in the Front Panel, goes to USB1-
4) Data+
Same thing.
Data+ on one of the USB ports in the Front Panel, goes to USB0+
Data+ on the other USB port in the Front Panel, goes to USB1+
EACH side of JUSB1 and JUSB2, will support one USB port on the Front Panel.
Two sides per JUSB1 and JUSB2 = 4 USB ports on the Front Panel.
For additional questions, or clarification to anything I have stated above, please post in a Comment.
Regards,
joecoolvette
Jul 20, 2012 | MSI Computers & Internet
How to connect power swicth on MSI RS482M4-ILD Motherboard
http://www.xpcgear.com/msirs482m4.html
The area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
What you need is a Front Panel header pinout.
Looking at the photo in the link above, the Front Panel header is AT the bottom corner.
Motherboard mounted in the computer case, the header of pins all the way to the Right, and Bottom, is the JLPC1 header.
The JLPC1 header is used for board level debugging by MSI, and is not used by the consumer.
[Two rows of pins. Third one from right missing, Top row ]
The header to the left of JLPC1 is the JFP1 header.
Front Panel Header. {Junction Front Panel 1 }
Two rows of pins.
4 across the Top row, 5 across the Bottom row.
The pins are numbered EVEN across the Top row.
The pins are numbered ODD on the Bottom row.
Starting from the Left side of the motherboard going right;
on the Top row,
Pins 2, 4, 6, and 8. There is NO pin 10.
Starting from the Left side going to the right; on the Bottom row,
A) Pins 1 and 3 are for the HarDDrive activity LED. (Light)
If the HDD LED is dim when operating, switch the two wires around.
D) Pins 2 and 4 are for the Power On LED.
If the Power On LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
MSI Support > RS482M4-ILD > Manuals download page,
http://www.msi.com/product/mb/RS482M4-FD--ILD--IL--L.html#/?div=Manual
Scroll down
Under Download click on E7191v1.2.zip
Click on the country nearest yours
A small window will come up on the right -
Opening E7191v1.2.zip
Make sure there is a green dot, in the small circle to the left of - Save File.
If not, click in the small circle.
Now click on OK.
A small window will come up on the left. In the wording at the top, tells you where the file will download to.
It may have Desktop, or My Documents, or Downloads, in the wording.
[Or if you are using a version of Win Vista or Win 7:
Desktop, or Documents, or Downloads ]
Windows XP:
Desktop: The file will be on your desktop screen
My Documents: Click on Start, then on My Documents.
Downloads: Click on Start, then on My Documents. DOUBLE-click on Downloads.
Win Vista / Win 7:
Desktop: The file will be on your desktop screen.
Documents: Click on the Windows logo button, then on Documents.
Downloads: Click on the Windows logo button, then on Documents. Click on Downloads.
In the next window go all the way to the left, click on Extract all files.
At the bottom of the next three small windows, click on Next, next, and Finish.
In the last window DOUBLE-click right on - E7191v1.2, next to the red Adobe PDF icon.
There is your Motherboard Manual, in PDF file form.
Regards,
joecoolvette
Jul 18, 2012 | MSI RS482M4-ILD Motherboard
How to connect power to the front panel
Power to the Front Panel?
A) The plastic front of your computer is the Front Panel
B) The area of pins sticking up on the motherboard, that the wires from the Front Panel go to, is the Front Panel header.
I believe what you are requesting is the Front Panel header pinout.
AsRock Support > AsRock 775i65GV Motherboard > Main Support Page,
http://www.asrock.com/MB/overview.asp?Model=775i65GV
Go to the headings on the upper left side.
Products, Motherboard Series, 775i65GV, Overview and Specifications, and so on. Click on - Manual
On the next page go across from the heading - User Manual, and click on - Click Here, under the country nearest yours.
Disregard if you are aware;
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click it may take up to 30 seconds before the first page comes up.
At the top of the PDF file is the page number box. It is to the right of the Down Arrow.
You can use the Down Arrow to arrive at the page you want, or;
1) Put your mouse cursor in the page number box.
2) Left-click once. (Contents in page number box will be highlighted in blue)
3) Type the page number you want in the page number box.
4) Press the Enter key
Go to Page 10
This page shows an illustration of the motherboard, and as it sits in your computer case.
To the bottom Right corner is the Front Panel header. It is marked by the number - 16 [ System Panel Header ( PANEL_1) ]
{ It is the second header over from the Right side. It is Black in color. The first header is a USB header, and it is Blue }
Now go to Page 22. Front Panel Header Pinout. (System Panel Header pinout)
If you cannot download this motherboard manual, or if you do not understand the pinout;
There are 4 pins across the Top row.
There are 5 pins across the Bottom row.
The Top row of pins are numbered Even
The Bottom row of pins are numbered Odd.
Starting at the LEFT side going to the Right, on the Top row;
Starting at the LEFT side going to the Right, on the Bottom row;
A) Pins 1 and 3 are for the HarDDrive Activity LED light.
IF the LED light is dim when operating, switch the two wires around.
B) Pins 5 and 7 are for a Reset Switch, IF, a Reset switch is used.
Pin 5 is for Ground ( - )
C) Pin 9 is Not Connected. (N/C)
D) Pins 2 and 4 are for the Power On LED light.
If the LED light is dim, switch the two wires around.
Page 21 details out the USB front panel headers, (USB 2.0 Header, Shared USB 2.0 Header), and the Front Panel Audio Header.
Regards,
joecoolvette
Dec 26, 2011 | Asrock 775i65GV Motherboard
WERE DO LEADS GO FOM THE FRONT PANEL TO THE MBOARD FOR A EMACHINE E4904I DUNT KNW WERE THEY GO
The eMachines E4904 desktop computer uses an Intel D102GGC2 motherboard.
This is Intel Support, and the download page for the motherboard manual, for the Intel D102GGC2 motherboard,
http://www.intel.com/support/motherboards/desktop/d102ggc2/sb/CS-022441.htm
On this page I would like you to left-click right on -
English Product Guide [PDF]
May take a few seconds before you see the first page, and additional time for the PDF file to fully download.
Suggest you let the file fully download before looking through it.
[NOTE*
The computer you are using has Adobe Reader on it, which uses PDF files. If you do not have the latest version of Adobe Reader, 9.3.4., I would suggest downloading it. The new version will remove the old version.
This is the latest version of Adobe Reader download page,
http://get.adobe.com/reader/
I would uncheck the McAfee Security Scan Plus. Just MHO ]
The plastic front of your computer is the Front Panel.
The area on the motherboard that the cables (Wires), from the Front Panel go to, is the Front Panel header.
(Series of pins sticking up from the motherboard)
In the top header of the PDF file is a Zoom Tool icon.
The + sign is the Zoom In tool icon.
The - sign is the Zoom Out tool icon.
I would click on the Zoom Out tool icon, and reduce the view to 100% (100 percent)
At the top of the PDF file in the header is also the page number box.
To the right of the blue Down Arrow.
Go to Page 11.
There are two ways to get to Page 11.
Slow way;
Click on the blue Down Arrow until you get to Page 11.
Fast way;
Left-click once.
Type 11.
Press the Enter key.
Page 11 shows you an illustration of the motherboard.
Processor to the Top, Ram Memory slots to the Right, the Front Panel header is to the very bottom Right corner of the motherboard.
(R in the illustration points to the Front Panel header)
You can see that the Front Panel header consists of 2 rows of pins.
These 2 rows of pins run parallel to the outside edge of the motherboard.
Go to Page 38.
This page shows a color illustration of the Front Panel header, and where the cables (Wires) attach to.
There are Four pins on the Top row.
There are Five pins on the bottom row.
Processor to the Top, Ram Memory slots to the Right, the Top row of pins are numbered from the Left side of the motherboard, going towards the Right side.
Top row numbering going from the Left side of the motherboard, towards the Right side,
Bottom row numbering going from the Left side of the motherboard, towards the Right side,
1) Pins 1 and 3 are for the Harddrive Activity LED light.
(HD LED)
Pin 1 is for the Positive wire. ( + )
(Orange)
2) Pins 5 and 7 are for the Reset switch, (Reset button), IF used.
(Blue)
3) Pins 2 and 4 are for the Power On LED light.
Pin 2 is for the Positive wire. ( + )
(Green)
4) Pins 6 and 8 are for the Power On switch. (Power On button)
(Red)
5) Pin 9 is for a 5 Volt wire.
Doubt it will be used.
NOTE*
Remember computer unplugged from power, AND observe Anti-Static Precautions BEFORE you reach inside your computer.
For any questions please post in a Comment.
Regards,
joecoolvette
Sep 13, 2010 | E-Machines eMachines Desktop PC
Emachine W3410,the main three wire from the motherboard to the power botton on and off switch was remove and iam not sure wish pin they go to .power led, power sw, H.D.D.led,
The eMachines W3410 uses an MSI ms-7145 motherboard.
Also known as RS480M
This is MSI Support, and the download page for the motherboard manual, for the RS480M motherboard,
http://www.msi.com/index.php?func=proddesc&maincat_no=1&prod_no=204
To the Right of the photo of the motherboard, you will see a gray bar with, BIOS, Driver, Utility, Manual, and RSS.
Left-click on Manual.
On the next page look under the heading to the right - Document.
Left-click on the blue - E7145v2.1.zip
On the final page click on the country nearest yours.
A small window will come up with the heading -
Opening E7145v2.1.zip
Be sure that Save File has a green dot, in the empty circle to the left.
[If not, Left-click on the empty circle to the left of Save File]
Now click on OK, below.
Where this file will go.
If you Do Not, have your documents set to save to your My Documents folder (Documents for Vista), the file will go to your desktop screen.
In either place Double-click on the file. Now go up to the left, and click on - Extract All Files.
Click on Next, and Finish.
You will now see a PDF icon. Double-click on this icon.
Go to Page 15.
The plastic panel on the front of your computer is the Front Panel.
This is where the Power On switch, Power On LED, and HDD LED are located.
The connector on the motherboard where the cables (Wires) attach to, is the Front Panel header.
The front panel header is a series of pins, sticking up out of the motherboard.
The MSI ms-7145 motherboard, (RS480M) has the Front Panel header separated into two headers.
JFP1, and JFP2
Looking at the motherboard with the Processor socket to the top, and the Ram Memory slots to the right, the JFP1, and JFP2 front panel headers are located at the extreme bottom Right, of the motherboard.
[Use the Zoom In feature (+ at top of file) to enlarge the motherboard layout on Page 15]
Now go to Page 38.
Page 38 shows the connections for the JFP1, and JFP2 headers.
The JFP1 header, and the JFP2 header, consists of two rows of pins in a horizontal column.
The pins are arranged parallel, to the bottom edge of the motherboard.
Right above the JFP1, and JFP2 header may be three pins, with two of the pins have a jumper. We will not concern ourselves with this jumper header (BIOS with Protect Jumper)
The JFP1, and JFP2 headers are close together. There is no separation in-between them.
The JFP2 header is for an internal speaker.
The JFP1 header is for the Front Panel cables.
The JFP1 header pins start from the right side of the motherboard, and go towards the left.
There are 5 pins across the Bottom. (Going from right to left)
There is NO pin, then there are 4 pins across the Top.
(Again, going from Right towards the left)
The top row of pins are numbered Evenly.
The bottom row of pins are numbered Odd.
Starting on the Right side, going towards the left for the Top row of pins, the pins are numbered,
10 (NO pin for 10), 8, 6, 4, and 2.
Starting on the Right side, going towards the left for the Bottom row of pins, the pins are numbered,
9, 7, 5, 3, and 1.
1) Pins 2 and 4 are for the Power On LED.
2) Pins 6 and 8 are for the Power On switch
3) Pins 1 and 3 are for the HarDDrive activity LED
4) Pins 5 and 7 are used for a Reset switch. (If applicable)
5) Pin 9 is not used.
Apr 30, 2010 | E-Machines T3958 (827103050974) PC Desktop
Microsoft EXCEL 2004 for Mac Logo
67 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
