Question about Photography
Unloading my medium format camera
I don't know how to unload the film without exposing it. It's a Hasselblad and the first time I've used one, the instructions say the circle should be white before I open the magazine, but it's black and I can't figure out how to rewind the film before I take it out. Please help !
  • Ren D Oct 10, 2008
    i have a vivitar v3000 slr camera and i have reeled back the film but i cannot open the camera!! help....
  • 59 Answers
If i remember correctly there should be a button on the bottom of the camera opposite side of the film winder if you press that button it will release the tension on the film and allow you to reel the film back into the film canistor.BE CAREFUL when reeling it back in because you can reel the whole roll back into the film canistor, when you think your getting towards the end go SLOW you will feal the reel loosen up alot.that means that the film has let go of the other side STOP and you can open the case without exposong your film.GOOD LUCK if this helps rate me or leave some more info.Thanks.
Posted on Nov 18, 2007
I did by a canon a-1 that been alredy used the problem is that there is no rewind knob upwards so i can open the back of the camera help please
You'll need to find a shop and hope they've got a knob in their parts bin that they can install for you, as that'll be your only option. Without it, not only will you have no way to open the camera to load/unload film, but you'd also have no way to rewind it once you shot it.
Sep 04, 2011 | Canon AT-1 35mm Film Camera
How do i load or unload film?
Digital cameras don't have film.
Jul 06, 2011 | Cameras
I can't seem to get the knob for film advancing off the camera body
There should be a small slide-switch on the wind knob itself. If you slide it back, the knob will rotate backward slightly and pop off the body.
Jun 15, 2011 | Hasselblad 503CW Medium Format Camera
I don't know how to load or unload the film for my Minolta x700
You can download the manual from
There are illustrated instructions for loading/unloading film beginning on page 17.
Feb 22, 2011 | Minolta X-700 35mm SLR Camera
Removing the top cover on my pentax 645n
The Pentax 645N is not a modular camera it has interchangeable lenses and uses film inserts. Removing the "top cover" should only be done by an accomplished repair person. I doubt anyone here would talk you through the procegure of dismantling a 645n. The Pentax 645 series of cameras is unlike a Mamiya, Hasselblad or Bronica which are modular cameras.
Dec 13, 2010 | Pentax 645N Medium Format Camera
Hasselblad 500cm body frozen/jammed
Check the release button lock tab, it may be engaged, holding the release button in
Aug 17, 2009 | Hasselblad 503CX Medium Format Camera
I do not know how to load or unload the 35 mm film.
The cartridge will only go in one way. install and pull film to marked line (should have a few notches in the film strip past gear) close camera and either wind until it stops or if batt powered it will load itself then ready to roll
May 23, 2009 | Photography
Adapt a Hassie 500el/m to a Imacon ixpress back V 4.7
The Hasselblad ELM does not need adapting to use the Imacon or hasselblad digital back  the following backs fit on the ELM and can be triggered with a cable that should be supplied with the back.
Hasselblad V96c 16mp square format back  Hasselblad CFV 16mp square format back with CF slot Hasselblad CFVII 16mp square format back with CF slot + larger screen
the following backs will work but need to have a V adapter plate fitted to the back
96c 16mp square format back  132c 22mp 645 format back  528c 22mp 645 format back with Multishot option CF-22 22mp 645 format back with CF slot CF-22 MS 22mp 645 format back with CF slot & Multishot option CF-39 39mp 645 format back with CF slot CF-39 MS 39mp 645 format back with CF slot & Multishot option
When fitting and digital back to an older camera the best advice is to get the camera body serviced to ensure that the back mount is correct as the digital backs require a better fit than the film backs did. If the mount is off it will cause back or front focus.
Mar 16, 2009 | Hasselblad 503CW Medium Format Camera
Which Hasselblad?
There were several versions of the 500C/M as production was over many years. The 501C had all the latest revisions of the 500 C/M series to make it the better choice. You'll get more $ for the 501 for this reason. Later versions of the 500C/M had a much better coil spring to control the mirror for starters. Unless you are going to use this camera for daily professional use, either would be a reliable camera. A good way to check the amount of use on any Hasselblad is to look at the back of the camera where the film magazine mounts. A good solid black with no shiny spots on the plate would indicate little use. There are raised lines around the aux. shutter opening that will wear as film back are removed and replaced.
Nov 12, 2007 | Hasselblad 203FE Medium Format Camera
Photography Logo
281 people viewed this question
Top Photography Experts
Are you a Photography Expert? Answer questions, earn points and help others
