Question about Linksys WRH54G Wireless Router
I have a same problem..
First, my laptop can't connect to switch wgh45r through wireless but my desktop can connect normal with cable. Then about 15 minute laptop can connect to switch but still can't use internet as desktop. And about 30 minute then laptop connect to internet but i see that IP laptop is 10.0.0.2 same subnetmask address's modem while ip address's switch is 192.168.1.1 255.255.255.0 class C.I think that IP laptop should be 192.168.1.X, Why?
  • 1 more comment
  • khoaboss1984 Jul 18, 2009
    Thank you for help but i'm sure fill right SSID because I only use wireless at my area.If I connect to internet normal, my problem won't be SSID or key. I think that the main problem is error hardware and now everything is normal.
    Yes, i sure fill correct SSID because only I use wireless in my area. If i connect to internet normal, my problem won't be SSID or key. I think that the main problem is error hardware because now everything become normal. Thank you for help.
  • That_Old_Guy May 11, 2010
    I would make sure that you are connecting to the Correct SSID when you are on the laptop. Remeber that SSID are case sensitive so you need to make sure that you spell it exactly the same. Also retyping the security key may help.
    Master:
    Sergeant:
  • 226 Answers
Check the router interface and make sure that is the ip and subnet you have set for it 10.0.0.2 but you are right if the routers ip is set for 192.168.1.1 the laptop should be also 192.168.1.X
Posted on Jul 20, 2009
Last night my motherboard burnt due to powersurge from the ISP provider switch. they are not believing that the power surge is from the switch, anyway. i have cable internet connection of 10mbps i dont...
If you have a wireless router and it is connected to the DSLor cable modem then - To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards in all the laptops/computers needs to be configured withthese router's wireless settings. Then the laptops/desktop computers cancommunicate with your wireless router and access the Internet via the DSL or cable modem.
Aug 12, 2011 | D-Link (DI-784) Wireless Router
Tip
Setting up Wireless on router and wireless security
For setting up any router you can follow the below simple steps
  1. Connect the router with a power cable and switch on the poser, reset the router with its reset button normally you can find the reset button on the rear side of the router for 30 seconds and then switch off and on the power
  2. After reset conenct the router to any laptop or desktop with a cable and also connect the router to the modem or the internet service provider cable
  3. after all connection lights will come on go to right hand side corner of the computer and check if the network connection is showing connected
  4. Once you are connected with a wired connection open a page of internet explorer and type in router addess normally it will be http://192.168.1.1 or http://192.168.0.1 and then type the username and password default usernames and passwords can be found in router manual.
  5. Once the router setup page is open you can confugure the router easily without the CD setup.
  6. The advantage is you do not have to run the setup CD and you can also do wirless settings for your wireless laptops or devices
  7. Go to the wirless settings page and you can select the wireless on and off or you can setup a wireless security to avoide your router with unauthorized acess
  8. I would recomend always keep the wireless network secured if you are using the router for a home or small office as there can be people who will be using your bandwidth for free without your permission
  9. one more tip i would like to give whenever any kind of setup is required on the router do it by a wired connection only and not thought a wireless pc or laptop as it can disconnect you from the router in between of your setup
  10. WEP is the kind of wireless security which is easy to setup and remember and most wireless cards of laptops and computers support it
All the best with your wireless router configuration and security setup
Regards
Vikram
on Dec 02, 2009 | Computers & Internet
Can we use MF6550 for wireless network?
If you use a wireless USB print server like this . Keep in mind that you may not get all functions such as scanning to work but it will allow for printing for sure. If the scanning works consider it a bonus.
Jun 11, 2011 | Canon imageCLASS MF6550 All-In-One Laser...
How do I connect my netgear router to my desktop internet to use with my laptop. Followed instructions but when cable is disconnect from my laptop I can't connect to the internet
First Connect the Desktop with Netgear Router with the Ethernet cable. Open the Netgear GUI and configure a Wireless Network. Once its configured, switch On the WiFi switch from your Laptop and try to connect your Laptop. Make sure your laptop has an in-built Wifi adapter, if it doesn't then you would need to buy an USB based Wifi Adapter.
Also if you want to use the Internet with your Desktop PC without being connected with the Netgear Router then make sure it has Wireless connection capability.
May 10, 2010 | Computers & Internet
I WOULD LIKE TO CONNECT MY LAP TOP TO TV WHAT CABLE AND HOW WOULD YOU DO IT ?
You will need
  • a PC or Mac laptop computer
  • a digital TV
  • a VGA 15-pin connector cable; or an S-Video cable and mini to RCA audio cable;
  • or a wireless converter
More information you can visit:http://www.videojug.com/film/how-to-connect-your-laptop-to-your-television.
If you need laptop accessories, such as Dell Latitude D620 Keyboard, toshiba a45 keyboard, gateway 450rog keyboard etc, you can visit www.udtek.com.
Apr 12, 2010 | Acer Aspire One AOA110-1588 Notebook
HAVE TATA INDICOM LG250 MODEM CONNECTED TO MY DESKTOP PC I WOULD LIKE TO CONNECT IT TO MY HP PRESARIO C700 LAPTOP. I HAVE LAN & TELEPHONE CABLE TOO. CAN I CONNECT IT AND ACCESS THE INTERNET?
as long as you have the ports for it yes, are you trying wireless, or a wired connection? depending on how old or new your laptop is you may be able to connect the telephone line right into your laptop, although that would be dial up and very slow so i would recommend using a cat5 cable aka normal internet cable
Apr 19, 2009 | Computers & Internet
Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
Apr 10, 2009 | D-Link AirPlus DI-524 Wireless Router
I need to know how to get the router to work on my new laptop and desktop
Normally you would connect your DSL or Cable Modem to the WAN or Internet port of your router. Then you will connect your Desktop and/or laptop to one of the available switch ports. They usually have 4 of them. You use standard ethernet cables for all of the connections.
Jan 05, 2009 | Linksys Wireless-G WRT54G Router
Connection issue
put the blue cable connection with the router and cable modem first.configure wireless setup.put the desktop rj45 connection to a free router rj45port.As u are getting internet on wireless check the desktop ip configuration.obtain auto ip configuration should be clicked.
Jun 28, 2008 | NetGear FS605 - 5-Port 10/100 Network...
Pc connection problems
Sounds like you are setup to use Internet Connection Sharing. don't do this. Have each computer connect to the internet via the router. If the router is wireless connect all computers wirelessly to the router that are wireless capable and any computers that are not wireless capable, connect them to the router via a cat5 cable to the cat5 ports on the router. This will solve your problem. BPCS
Dec 30, 2007 | Belkin (F5D5231-4) Router
Linksys WRH54G Wireless Router Logo
107 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
