Question about Mitsubishi WS-55807 TV
When you turn the tv on it stays on about 5 secounds and turns back off.
  • 3 more comments
  • stephens7357 Jul 17, 2009
    I was wondering. I purchased the tv some years ago, I have never used the hd componets until yesterday. And this morning this power problem accured, could they be related?
    -Also are you suggesting unplug the tv for an hour to see if that solves the problem?
    My Mitsubishi hd 55807, the power comes on then goes off.
    Would this accur if you just used the hd componet of the tv. I have had it for years, I just switched to an hd box last night and this morning the problem accured.
    How much would it be to replace it?
  • stephens7357 Jul 18, 2009
    Thanks got it repaired, now I am dealing with the red colore coverage, the allingment of the colors the only one that wont move is red any ideas
    President:
  • 1,776 Answers
Have you tried resetting the TV to factory settings? In the case of color inaccuracies, the TV's PerfectColor/PerfectTint capabilities can be reset by pressing the Menu button and using the right arrow key to highlight "PerfectColor." Press "Enter," then "Reset" to restore the factory settings. For issues with the audio or video of an incoming signal (DVD player or VCR), press "Menu" and use the right arrow key to highlight "Reset." This will restore the original factory settings for all incoming signals.
Reset the television controls. If the component settings do not fix the problem, there are two other methods of resetting the television. Press "Menu" and type "1, 2, 3" to bring up the Reset menu. By pressing "Enter," all of the settings of the television will be reset to the original manufacturer's specifications. If the television will not turn on or off, a full system reset should be performed. On the control panel of the television, press the System Reset button. The television will turn off and the green LED light will flash quickly for about a minute. When the light stops flashing, the TV should turn on.
Hope this helps you. Good luck and good watching!
Posted on Jul 19, 2009
    President:
  • 2,777 Answers
It is going to cost more than it's worth at this point since the TV is about 10 years old and the parts are very expensive and hard to come by. You may want to see if a local TV repair person can do a free evaluation on the unit to estimate the repair, but most likely it will be much more cost effective to replace the unit.
So sorry to be the bearer of bad news =(
Thanks for your time,
Tim
Posted on Jul 18, 2009
    Top Expert:
  • Mitsubishi Master
  • 78,919 Answers
THIS PROBLEM IS CAUSED BY A SHORTED HIGH VOLTAGE SECTION ON THE CIRCUIT BOARD THAT SUPPLIES POWER TO THE CATHODE RAY TUBE ELECTRON GUNS, IT IS BETTER TO JUST REPLACE THE TV THAN FIX IT WITH THE HIGH PARTS AND LABOR TO FIX JAPANESE TV'S.
Posted on Jul 17, 2009
  • 3,230 Answers
By unplugging the TV for an hour or more you did a power reset. If this power reset does not allow the TV to turn on component failure is indicated. These sets are assembled using the wave soldering process they are known for having cold solder connections. Power supply failure is common. The safety circuitry shuts the TV set down or will keep it from turning on when it detects a problem. This model of TV has over 2,000 parts, which includes millions of transistors inside the integrated circuits. The capacitors will change value, leak and become defective. Resistors will change value and burn. Diodes and IC can go bad. This may have a domino effect and cause other parts to fail. Replacing one defective part may make the TV operate for a short time but the part will fail again if the parts that caused the failure to begin with are not replaced. The only way to know for sure which parts that are no longer within factory specs and for a proper repair all the electronics must be diagnosed by someone with the correct electronic test equipment specifically designed for TV service and the skills to use the test equipment. I wish I could tell you there was a quick fix or button to push that would fix the TV but that is not the case or the solution needed to get the TV operating correctly.
Good Luck!!
Thanks
  • Mukesh Kumar Jul 17, 2009
    Yes sure... unplugging the TV for an hour will do a hard reset.....
    and many time it works......
I have a 17" lcd
Good for you. I don't own a TV. and don't want one.
Jun 29, 2017 | Envision G175 Monitor
When ever I turn on the TV,pic comes only for one secound and audio stay on..
Hello: We had the same problem on our Toshiba 32" flat panel TV. We found that if you try turning on the TV first, wait until the "snowy" / blank screen comes up. Then turn on your satellite receiver. It's worked for us, hopefully it will work for you. If not, I've been told that it can be an expensive repair. Good luck.
Jan 06, 2011 | Televison & Video
When i turn the tv on it comes up the main screen like,tv, hdmi,1 exc.then with in secounds it goes to a black screen it will not let medo anything unless i turn off and does the same thing i need help...
You have a power supply problem. Within about 32 seconds the picture drops out because the backlite transformers shutdown. Yoy will have to find a new power supply or have some one fix yours.
Mar 20, 2010 | Element Electronics FLX-3211B 32 in. LCD...
Cannot turn tv on
Check power supplly make sure its not the fault in wht this will not turn on.
Unplug tv from wall wait 30 secounds and plug back in.
If that does not work you will need to have someone look at the powersupply.
Jul 01, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Tv turns off after being on for 1 minute.
I assume its Sony DLP TV and symptom shows it is new lamp time.
Let me know exact model number to help you more info.
May 11, 2009 | Sony Grand WEGA KF50XBR800 50" Rear...
I hooked up a Jacuzzi bathtub and pump won't stay on
I bought a new house and I have a jacuzzi bathtube . and all the sudden stopped working .. where or how I can locate the pumpe ? the only thing I see is the button to turn it on or off and now it does'nt go on ?!! I checked the circute praker and everything seems okay to me.... help please.
Mar 08, 2009 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
There is a blinking light in front of my tv blinks 8times turns off for 4seconds and starts again
Check C514 next to flyback xformer.If shorted,burnt,replace
with part # 1-161-754-00 102K / 3KV capacitor.May also have open
2 amp pico fuse in power supply......T
Oct 25, 2007 | Sony KP-53S70 53" Rear Projection...
Shuts off about 5 sec. after i turn it on
The power amp module ( s) have probably "bought the farm"
Post what part numbers you find on them.
Jan 05, 2007 | Harman Kardon AVR 510 Receiver
Mitsubishi WS-55807 TV Logo
125 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
