Question about Garmin nuvi 250 GPS Receiver
It just says its looking for signal, but never finds one. . Just stopped all of a sudden while travelling. Has a red X by the signal bo.
    President:
  • 1,111 Answers
Take the unit outside so that it has a clear view to the open sky, turn the unit on, then push the reset onthe side(you need a paper clip). let in sit outside to Aguire the satellites. this may take upto 30 minutes. if that does not work, you can try the latest update. bill
Posted on Jul 18, 2009
HDMI out showing on rceiver
as best to my knowledge sound doesn't travel thru the hdmi cable (only video), but travels thru another cable that is connected to the back of the receiver , some of the receivers even use a optical fiber (tos) for the sound to travel in
Dec 03, 2015 | Audio Players & Recorders
My Genius Traveler 6000x wireless mouse suddenly stopped working
Double check the batteries, although the lights work and the computer sees it, the voltage could drop low enough to stop the sensors.
next, try another USB device in that plug. USB port can go bad.
If the port works, it could be the wireless USB connector starting to fail, if they are bumped to hard sideways it can cause loose connections internally.
then, you might just need to update drivers. Computer update s can conflict with drivers cause devices toss top working.
May 20, 2014 | Genius "Wireless Mouse - Traveler 6000X,...
My John Deere 4010j traveling sprinkler which is about one year old all of a sudden stopped travelling. What might be the problem? John H. Pensacola, FL
Here is a tip about how to get parts for your traveling lawn sprinkler and also a great article about how traveling lawn sprinklers work.
Traveling Lawn Sprinklers
heatman101
May 09, 2011 | John Deere Gilmour Traveling Sprinkler -...
My 2001 C180 has recently on four separate occasions while in transit suddenly revved to the red levels without warning. On one occasion I was travelling at 90 km/hr when it suddenly revved to the red...
Hello! The Pedal Value Sensor (PVS), a device that sends gas pedal positioning to the Electronic Control Module (ECM) is the most likely intermittent component...It is located under the hood...Drivers side...Next to the brake booster...The Throttle cable connects to it...It has a 5 wire plug with the following wire colors...Brown/White...Violet/Yellow...Violet/Green...Brown/Yellow...And Blue/Brown...
Check the connector for loose, frayed, or broken wires...Radio Shack sells a product called DeOxit...Cost $15...It is a "no touch" electronic contact cleaner...Two spray cans...Pull connector and spray Cleaner into both female/male ends...Wait 10 seconds and re-connect...If the problem continues replace the sensor...
Guru....Saailer
Jan 27, 2011 | Mercedes-Benz C-Class Cars & Trucks
LG DLP Flat screen suddenly lost its red color
The Lamp would not cause this problem. If you are using Componet Input only, I would look to see if the Red Signal Cable has pulled off the Input Jack or is bad. If you have no Red in any input and also do not have Red on the User Menue, It would probably be the Opical Engine.
I hope this helps,
Skyassoc
Aug 25, 2009 | Televison & Video
MU203 mouse not working
Replace the batteries and try this.
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it to Reset/Connect the mouse to the receiver and work properly.
If not, try pressing the receiver button and then press the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Nov 12, 2008 | ViewSonic MU203 Optical Travel Mouse
Remote or Reciever?
It could be the receiver LED. But I would try cleaning the remote pads first and infrared LED.
Sep 08, 2007 | Kenwood VR-506 Receiver
Garmin nuvi 250 GPS Receiver Logo
133 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
