Question about Bosch HBL 442 / HBL 446 Electric Single Oven
Door Hinges for Bosch oven HBL 545
I need to replace the door hinges on my Bosch Oven and they are out of stock everyplace I have looked. I have had them on order from Sears for over two months and it doesn't look like Sears will be able to get them. Any ideas where I could purchase them??
Thanks
  • 491 Answers
CONTACT BOSCH FOR INFORMATION
Posted on Jul 18, 2009
Replace oven door seal
It will not be the door seal at fault. More likely is that the hinges are worn out or strained.
http://www.espares.co.uk/search/ma856pt1598/cookers-and-hobs/hinges/bosch
Try here.
Pete
Oct 03, 2013 | Bosch HBL 455 Stainless Steel Electric...
After changing the right door hinge on my bosch hbl455auc the door closes but the upper oven door is 1/8 lower at right top than left. How can I realign the door to level?
There are adjustment screws or bolts on the hinge attachments to the oven. Loosen them and adjust the door using wedges to hold the door in place.
Jan 12, 2013 | Bosch HBL 455 Stainless Steel Electric...
Bosch HBL 645 oven door won't close all the way
I am afraid that the door hinges are non adjustable, and the only solution is to replace them as a pair.
There should be some kind of latch mechanism at the end of the hinge
where it is fastened to the door to compress the hinge to enable you to remove them.
Hope this helps.
Jan 04, 2010 | Bosch Ovens
I need to remove oven door, cant figure out how
drop the door down as low as it will go look carefully at the hinges as they pass through into the oven chassis you will see a clip on each one that you lift up to lock the hinge you usually lift them up as far as they will go then this will lock the hinges as you close the door the hinges will come away from the oven complete with door.... reverse to refit.
May 06, 2009 | Bosch HBL 755 Stainless Steel Electric...
Bosch double oven, the bottom door won't close all the way
This requires door hinges to be replaced,relatively simple job & parts cheap.Best buy parts from Bosch direct .
Mar 15, 2009 | Bosch HBL 5056 Electric Double Oven
Bosch Oven Door Problem - doesn't close at top
On our oven (Bosch Evolution 700 Series HGS7152UC), the problem was getting worse and worse. I found it is was worsening simply because the hinges had started to come loose. I removed the door as suggested above, and although there are no adjustment screws on this model I tightened the now-loose hinge mounting screws. For each hinge there are three screws altogether: two (phillips heads) on the bottom of the door and one (torx head) on the inside wall of the door. After tightening those screws it is a lot better, only leaks as much heat as it did when it was new which is tolerable. Still a bad design.
Mar 02, 2009 | Bosch HBL 742 / HBL 746 Electric Single...
Bosch oven door does not close tightly, takes FOREVER to heat
All you need to do is replace the oven door hinges. as the springs are weak.
It is a fairly straight forward repair to do.
To obtain new hinges, got to:
www.bosch-spareparts.co.uk
or
www.espares.co.uk/bosch
Plz rate my solution.
Thankyou.
Jan 05, 2009 | Bosch HBL 745 Stainless Steel Electric...
Oven door not closing correctly
I had the same type of problem. I unhinged the door then disassembled the door (it's really quite easy)
after you take all the TORX screws out the everything comes apart! Don't worry about the screws putting them back is a snap! Now that you have the door apart take the door hinges out of the inner door plate.
If you look at then closely they will have a slight bend in them. Pay attention to how they would have been positioned on the door! Simply bend them slightly I used the edge of a step! My door now shuts completely! I hope this info helps many of you having the same problem! If you take the time it really is amazing how easy it is to solve the door issue! Thanks to my buddy RON.
Aug 06, 2008 | Bosch HBL 435 Stainless Steel Electric...
Oven door does'nt close fully
Heavy doors wear out the rollers on the hinge and the hinge itself. Need to replace them in a pair but the are expensive.
Apr 25, 2008 | Bosch HBL 5052 Electric Double Oven
Bosch HBL745A Oven door
My husband just figured this out.
- Follow Door removal instruction from the manual.
- There is a screw at the end of the hinge that can be adjusted.
- Adjust the screw to desired height.
- Secure lock nut.
Nov 14, 2007 | Bosch HBL 742 / HBL 746 Electric Single...
Bosch HBL 442 / HBL 446 Electric Single Oven Logo
602 people viewed this question
Top Bosch Ovens Experts
ashburton
paulcarew
Are you a Bosch Oven Expert? Answer questions, earn points and help others
