Question about ARC Welding Tools
Welder not welding motor work perfect - ARC Welding Tools
  • granite172 Jul 17, 2009
    mulchamp whisper weld 300 amp dc welder model dc1-300ssi
  • 33 Answers
Have you checked your brushes?
Posted on Jul 21, 2009
Lincoln electric ac/dc arc welder will not arc
Check the dial indicator. Sometimes if someone changes the amps while welding, there will be a break in the coil. It will work at a different setting as long as you are away from the break.
Jul 17, 2014 | Lincoln Electric K1297 AC/DC 225/125 Stick...
I have a bulldog diesle arc welder generator with unstable arc burns in to metal but wont keep stable flo but 110 and 240 work perfect please help
If you are welding dc you may need a rectifier assembly, at least diodes, if it is ac it may be your voltage selector switch
Aug 21, 2011 | Welding Tools
I own a Lincoln 305gas powered welder I recently purchased a Lincoln 25M suitcase and wanted to know if the two were compatible before I tried them together and if I can weld aluminum with them hooked up
Hi:
Yes your 25M feeder will work perfectly with ANY engine drive welder. Regarding the aluminum welding that's a no, sorry but suitcase feeder and gun are specialty made for mild and SS welding. For the aluminum you will require a spool gun and N adapter for your engine drive. Check you onwer's manual for more details.
If this was useful to you, please vote. Thanks.
Mar 27, 2011 | Lincoln Welding Tools
The wire feed on my welder will not work.
Maybe you can get lucky like I did . Some times the acr volt selector switch gets corrosion in it and wont let the circuit board know to send power to the wire feed motor. You can cycle this arc volt. switch in my case it is the a,b,c,d,e, switch back and fourth a few times and this will brake the corrosion and your wire might feed again as mine did . This corrosion build up happens from not using and or sollecting the switch much usually on a welder at hm that gets very little use. it is common good luck .
Jul 24, 2009 | Lincoln Electric LINK2400-+2 CV-305 MIG...
How do i weld thin metal with out burnning holes
First make sure your work area is out of the wind
Get some of the same thin metal to practice with.
Use the thinnest wire you can get. Start on the lowest
Volt setting and wire speed start welding and increase
Your wire speed till it sounds frying bacon and use
Stitch welds about ½ long wait a few seconds then lay down
The next weld start at where you left off that way the metal
Has time to cool some dial it in and practice.
Mar 03, 2009 | Campbell Hausfeld RBWG202000 NA 70 Amp....
My welding machine will not weld?
Hi, put the setting on 150 amps, and see if the welder welds. do you have a gas or electric welder?
some welders have a reset botton in front. tell me how many amps your welder produces.
If this doesn’t work for you please write back. Thanks,
Nov 22, 2008 | Welding Tools
Mig problem
For certain type of work TIG is required, like welding chrome moly for some racing organizations. Intricate work, like gunsmithing is also well suited to TIG. TIG is used by many auto restorers who prefer a more precise, perfect finish that requires little to no finish work. TIG is most similar to gas welding in technique, so if you've done oxy-fuel welding, TIG should be a natural transition. MIG is required by law and by insurance companies in many localities for structural repair of automotive frames. MIG is also much easier to learn and faster to weld. For doing other types of welding, like sheet metal, it can be a matter of personal preference. For an auto body repair shop or a novice welder, a MIG is a good, practical all-around welder.
Aug 27, 2008 | Troy MIG100 90-Amp. Wire Feed Welder
TIG MIG Difference
Aug 27, 2008 | Radnor A35HP 350A Water Cooled 25' TIG...
Sparks from motor when turned on
there's a short circuit on the motor armature.. needs replacement but it can be repaired depending on the problem.
Apr 15, 2008 | Vacuums
Welding Tools Logo
55 people viewed this question
Top ARC Welding Tools Experts
Lou Michaud
Lou Michaud
Level 1 Expert
 steve
steve
Are you an ARC Welding Tool Expert? Answer questions, earn points and help others
