Question about Bosch Nexxt 500 WFMC3301 Front Load Washer
Leaking from cold water valve inside rear panel. how do i get access to fix/
  • 3 more comments
  • carobins Jul 17, 2009
    there are no directions inside my machine. i have removed the back i need to remove the top.
    i have removed the top. The leaking part is E-07 5070000240 255474. appears to be a valve with a solonoid on top. how do i remove this?
    2 screws and the top slid off. the leaking valve is described in earlier email.
    my part looks like the first choice.
    it,s fixed, thanks
  • 15,935 Answers
Behind the lower access panel, there is a service manual that will tell you the steps to remove the outer shell.
If it is not there, let me know, and I will give you step-by-steps.
Once the top and shell are off - turn off the water and disconnect the hoses.
2 Screws hold it in place.
Very easy - should take you about an hour.
Thanks
Posted on Jul 17, 2009
  • 2 more comments
  • blueextc3221
    blueextc3221 Jul 17, 2009
    in the front corners there are clips.
    you will need a putty knive to pop the top.
    Stick in the putty knife on the side, in the corner. push in and pull up.
    it may take some time if you have never done it before.
    I will try and find a video or pictures online for better detail for you.
  • blueextc3221
    Looks like this?? CLICK HERE
  • blueextc3221
    Or this one?? CLICK HERE
  • blueextc3221
    OK - thats the cold water inlet valve.
    Shut off the water and remove all the hoses.
    The hose clamps will come off by squeezing the tabs together with a pliers.
    Then remove the wire harness.
    2 tabbed prongs hold the valve in place. push them in and move the valve in the slot until it frees up.
    Thats it.
Sylvania SE80094-1 hot/cold water dispenser faucets leaks.
It could be a build up of minerals from the water holding them both open. You will need to gain access to the water valves to clean their surfaces.
Jan 24, 2014 | Freezers
Cold water leaks into tub when machine is off
Try to identify roughly the area the leak is coming from. This will eleminate some of the following
Hose Connections
Check the rubber washers or replace if the hoses are leaking at the WATER INLET valve
Door Seal
This is a common place for leaks. Carefully check by partially pulling seal inside out and check for punctures, pens, pencils... Additionaly if the door is not closing properly it may need a door adjustment. This can easily be done by loosening the hinge bolts on the front panel, adjusting and retighten. The seal is also known to get lightly snagged by zippers or rub by heavy items when close are being removed. This tends to cause the seal to get damaged at the six o'clock position. This is sometimes hardly noticeable but if it is leaking from the bottom of the door replace door seal.
Water Inlet Valve
If the hose connections are good to the water inlet valve check that water is not leaking from the valve itself it is replace inlet water valve
Drain Pump
Check the drain pump housing and all hose connections. The drain pump is behind the lower panel, behind the back panel, and sometimes removal of the front panel. Hoses can be tightened. If hoses or pump housing is leaking replace pump .
Outer Drum
The outer drum is 2 halves bolted together some washers have a seal between others do not. If the washer is leaking between the seems disassembly of the washer will be necessary. The top panel, console, front panel, door seal, struts. 9696d86e-1b8b-4b2e-af2c-6f3a3ae921dc.jpg
May 23, 2013 | Siemens WK61420GB Front Load Washer /...
Will not go through rinse cycle. Just hums.
Try putting unit on cold water wash///just to see if cold water is coming in to machine.... You see the rinse cycle uses only cold water the hum you here is most likely cold water valve..to fix turn water of remove water inlet line (cold) clean water inlet screens( there is also screens inside the valves) hook back up turn water on check for leaks test .If this helped you please vote/// need more help please ask....
Feb 02, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Turned off the hot water to fix a leaking tap. now the tap has no hot or cold water and the hot water tank valve is leaking?
It sounds like two problems.
Problem 1) Clog inside faucet or clog inside pipes at faucet
Remove supply tubes leading to faucet and see if problem is inside pipes or inside faucet.
My bet is clog inside faucet.
If you have galvanized pipe that meets copper pipe, this can be trouble spot.
Article on clogged water pipes at Inspectapedia:
http://www.inspectapedia.com/water/Water_Pipe_Clog_Repair_Guide.htm
Article on clogged pipes:
http://www.waterheaterrescue.com/pages/WHRpages/English/Troubleshooting/Tanklets/backflushing.html
Problem 2) Water heater leak ... you say tank valve is leaking? Is that cold-water shut-off valve? Or tank drain valve? Or TP valve?
If cold water shut-off is leaking, then replace shut off.
If tank drain valve is leaking, then check if plastic valve is cracked. If drain valve is cracked, then replace with a brass valve from Home Depot. If plastic valve breaks off, then use hammer and screwdriver to gently chip out the broken plastic valve. New valve threads need teflon tape to seal pipe. If valve is just dripping, then put garden-hose cap over end of valve and screw down tight.
If TP valve is leaking, then replace with same temperature and pressure rating.
New TP valve threads need teflon tape to seal pipe.
Problem 3) If pressure is low all over house:
Buy pressure gauge at hardware store that screws onto hose connection.
Test pressure on outdoor spigot.
Open faucet and check if pressure drops. This says if problem is inside pipes that enter house.
Test pressure on water heater drain valve.
This says if pressure problem is before -or- after water heater.
If problem is before the water heater, then shut-off valve located on cold water line is suspect.
If problem is after water heater, it could be in hot water outflow pipe on top of water heater, or a nearby elbow.
Remove hot water line leading from water heater and check pressure. This says if problem is where hot water leaves tank.
Read articles above about clogs inside water lines.
Nov 16, 2010 | Rheem Water Heater Pressure Relief Valve
Hi I have an AEGL16850 washer dryer and it is filling up with water when it is not in use. It is outside warranty and on a Scottish Island so getting and engineer to visit is near impossible. Help!
Inside of the washer there are water valves. These valves are provided with power to open and allow water in, then power is release to have them closed. The water valve is in the machine and connects the external water lines to the internal water lines. Chances are the valves are leaking and not stopping the water flow. If you remove the rear panel of the machine you can access the valves.
Sep 04, 2010 | AEG Washing Machines
Kenmore 24632 leaks water from right rear corner
The problem may be attributed to either a leaking water inlet valve, or the associated internal hoses that run from the valve to the dispenser. The following link explains how to access the inside of the washer and/or replace the valve (if required):
http://www.fixya.com/support/r600647-replacing_water_inlet_valve_kenmore
If parts are required, you can purchase from any of the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
All these sites offer great service with competitive pricing, so shop all of them for the best deals.
If you have any questions abou this repair, or require additional assistance, please let me know. I hope you find this helpful.
Jul 30, 2009 | Kenmore 24632 Top Load Washer
I have the valve for the water now how do i change it
If you are talking about replacing the water inlet valve, follow these steps:
1. UNPLUG washer and turn off water supply.
2. Disconnect water inlet hoses from the back of the washer.
3. Remove the washer top panel by removing the three screws in the back of the washer. With the screws removed, the panel will slide back, then lift off.
4. The inlet valve will be located in the left-rear of the washer (as viewed from the front). Remove the dispenser hose and electrical connections from the water inlet valve, followed by the mounting screw(s). The valve should easily come out of the washer. NOTE: Accessing the valve from the rear or left side of the washer access easier.
5. Install new valve in the reverse order of the steps I provided. Make sure you get the dispenser hose connected correctly so it does not leak AND make sure the electrical connections are not crossed (they should be marked HOT or COLD - if not, label them BEFORE removing.)
6. Connect water supply lines making sure they are not crossed. If you have the original manufacturer's hoses, they will be marked RED for hot and BLUE for COLD. It's also printed on the back of the washer.
Read through the instructions and let me know if you have any questions. I hope this answers your question.
Jun 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet washing machine - no cold water comes in when I put it on cold cycle
Check the tap is turned on
if not fix
turn off taps, check the lint screen inside the hose end (tap connector end) is not blocked
if not fix
check cable connections on cold water solenoid valve inside rear of case
if not fix
replace cold water solenoid.
cold water solenoid valve fails more often than hot, is used on every cycle so bnurns out first.
unplug washer and turn off water before checking cables or replacing solenoid.
solenoid is cheap, common to many washers local parts guy will have one that fits even if it is labelled ge frigidaire kenmore
Sep 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Admiral Leaking
Possibly rinsing with cold water, washing with hot.
Check inlet valves for leaks, especially cold (rinse)
Lift the top panel by inserting a flat blade approx 4" from each side at the front to release clips, then top will hinge backwards.
You can see the valves at the rear behind the drum..
You can run the machine with top lifted to see any more leaks.
Also remove front panel via 2 small screws to gain better view.
Jul 12, 2008 | Admiral AW22 Top Load Washer
Kenmore 110.92274100 Rear Panel Access - Cold Water Problem
the top panel comes off via 2 screws that hold control panel on
once this done yuo can lift the whole hob and front and side panel to expose the workings
the cold water valve has a filter inside the water entry so to check this just take off the hose to the machine and look inside hole
if this is ok then you may need to replace water inlet valves
i presume you have high pressure water if not buy valve that is for low water pressure
Mar 14, 2008 | Kenmore 24032\24036 Top Load Washer
Bosch Nexxt 500 WFMC3301 Front Load Washer Logo
601 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
