Question about U-Line Icemaker
Our old RV U-Line Icemaker, model 45A has stopped making ice and does not get cold. What does it need?
  • 286 Answers
You need to check to see if the compressor is running and the fan is running. If both are then you need a new unit. The 45A has the r12 refrigerant in it and you wont be able to get parts for a r12 system. U-line makes a BI95 to replace that model. If the fan isnt running then I would replace the fan. If nothing is running then it could be a bad thermostat but first make sure the ejector blade on the icemaker is at the 12 oclock position.
Posted on Jul 20, 2009
U-Line Icemaker is cold, but no water in resesrvoir for the ice.
Your water valve may hay a drip like a faucet. Causing the spout to freeze up.
Jul 08, 2012 | U-Line Icemaker
Is there a shut off valve on the ice maker?
There should be a shut off valve at the beginning of the water line that the installer tapped into when installing your icemaker. Mine runs down through my kitchen floor into my laundry room and is tapped into a copper cold waterline with a small handle attached to it.
To stop icemaker from making ice simply raise the lever to the up position that is attached and hangs next to your icemaker tray. This works on most models.
Aug 24, 2010 | Kenmore 53642 / 53644 Side by Side...
Free standing uline icemaker in rv still freezes but does not make ice
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Aug 24, 2010 | U-Line Icemaker
No water to ice maker
It will only call for water when the thermostat is satisfied. Now if you advance the icemaker when the ejector blade reaches 10 oclock thats when it should call for water. If you dont here the valve humming then it would be in the water switch inside the icemaker.Also make sure the thermostat is not set too cold. if its too cold it will never satisfy your control.
Manually advance : remove the cover on icemaker then turn the small gear counter clockwise
Oct 04, 2009 | U-Line Icemaker
GE Icemaker stopped making ice. everything else
Try these steps
  1. Check the shutoff arm
  2. Check the supply valve
  3. Inspect the water supply line
  4. Test the shutoff switch
  5. Check the freezer temperature
  6. Inspect the ejector gear
  7. Test the ejector motor
  8. Test the ice mold heater
  9. Test the holding switch
  10. Test the water inlet switch
  11. Test the thermostat
  12. Test the water inlet valve
pls rate my suggestion.......
Jul 25, 2009 | GE Monogram ZDI15C Automatic Icemaker
Whirlpool refrigerator stopped making ice.
If there are ice cubes in the icemaker sitting there waiting to be dumped then the problem is in the icemaker. If the icemaker is dry then you have a water supply problem, even if you have a water in the door working.
1.Check the fill line inside the freezer at the icemaker, if it is clogged with ice then remove this ice and replace the water valve.
2. Check the water supply. Turn the water supply off, disconnect the water line from the Ref, turn the water back on an fill a small glass. If the water supply is good the solenoid on the water valve should be checked. This is done with an OHM meter.
If you got this far and need more info to DIY - ronbuice.com
Dec 13, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
U-Line BI-45A won't run
check the wiring diagram at the back panel. trace each component.
you could have disconnected one or two wires while replacing the fan, check the thermostat control. see if there is continuity. check the wirings also that went there.
tnx 4 using fixya,
drcool
Oct 19, 2008 | U-Line Icemaker
U-Line Icemaker Logo
416 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
