Question about Smart Pool Inc Dolphin Diagnostic Automatic Pool Cleaner Ne250
Runs forward and will not reverse?
My cleaner just runs forward. It clinbs walls etc. but will not reverse itself. Took it to a repair facility and they want over $600 to repair. I should just buy a new one, I am sure that is what they want?
MOTOR UNIT ASSY -DIAG. 1/3H 1.00 ea $ 445.00 $ 445.00 9991279 RETROFIT FOR CABLE CONN.-3 PIN 1.00 ea $ 4.73 $ 4.73 9995173 OC -DIAG TURQU & MAGENTA 1.00 ea $ 86.09 $ 86.09 Total Price
Overall Disc. (0.00%) 600.82
0.00 After Discount
Tax (6.00%) 600.82
32.15 TOTAL $ 632.97
  • 640 Answers
With these pool cleaners, there are a few things that you can check before you consider purchasing a new one. Make sure that you do not have any dirt or debris stuck in the drive system. If your track is worn or stretched, you can replace it and it will be much cheaper than getting a new cleaner (or the quote listed above). If you have checked for any kind of obstruction or problem with the drive system, it is probably an electrical problem.
Posted on Oct 11, 2010
Only runs in reverse, why?
Polar Express only runs in reverse ' O Gauge Railroading ...
ogrforum.ogaugerr.com/topic/polar-express-only-runs-in-reverse
Dec 7, 2011 - Polar Express only runs in reverse ... At this time of the year all Polar Express trains are programmed to run North only. ... This would not be so bad on the Strasburg set because half the time, the prototype runs in reverse.
both trains only go backward - Classic Toy Trains Magazine
cs.trains.com > ... > Forums > Toy train operating and collecting
... trains that i set up around Christmas. The first train, according to the box, is a k-line 0/027 gauge dual motor mp-15. For a long time it has only run backwards.
no forward only reverse - Model Train Forum - the complete model ...
www.modeltrainforum.com > Scale Specific Model Train Forum > O Scale
Oct 18, 2009 - 10 posts - ‎3 authors
There are two switches under the cab; they have no effect on forward motion. This setis 2 or 3 years old and has been run maybe 1 hour total. New Athearn HO Locomotive won't go in reverse ...
Mar 5, 2015
Lionel Rio Grande 8213 only runs in reverse - Model ...
Nov 18, 2013
More results from www.modeltrainforum.com
Jan 01, 2016 | Crafts & Hobbies
Is there a solution for forward and reverse selector not functioning?
Make sure the trans axle free wheel lever is in the drive position
Oct 13, 2015 | Husqvarna Garden
Why will my Snapper riding mower NOT go into gear? forward or reverse?
what kind of snapper... RER ( rear engine rider ) tractor style, model number will help greatly here because snapper has made mowers since the dawn of time !!!
Aug 23, 2014 | Snapper Garden
Stalls in drive, runs grear in reverse
Engine stalling and rough run issue at low speeds
This problem is commonly caused by a dirty automatic idle speed control valve and throttle valve. Buy a can of throttle valve cleaner (do not use carburetor spray cleaner!) from NAPA or Carquest (made by CRC chemicals) and spray it into the air intake while the engine is running, use up about 1/2 the can, engine will try to stall hold the speed up, shut it down and let it soak for 30 minutes, restart and blow out the remaining fluid, shut it down and disconnect the negative battery cable for 5 Min's to reset the base idle control
Jul 06, 2012 | Cars & Trucks
My Jeep starts and runs fine going forward. When I put the transmission into reverse I blow the one fuse for the turn lights, back up lights etc. It drives forward and no fuse blows. I took out the...
Hello and welcome to FixYa....Sounds like you have a direct short in the NSS, (neutral safey switch) RLS (reverse light switch)--- if it's fuse # 11 that you are blowing, then it's the safety switch.
It's located on the transmission, passengers side, about half of the way up. It is a fan shaped switch with a big nut at the bottom, it is adjustable.
It has slider type contacts in it that slide and click into position to complete a circuit when the gear selector is moved. Depending on type of tranny, the switch serves as 2 purposes, neutral switch & backup lights. It's probably full of gunk. I have removed them, taken them apart by removing the phillips head screws, cleaned with electric contact cleaner, coated with dielectric grease, reinstalled & and got another year and a half of service.
Here is what the switch looks like....I hope this helps, good luck with your Jeep.
http://cgi.ebay.com/ebaymotors/Standard-Motor-Products-NS155-Neutral-Safety-Switch-/280649462826?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A1997%7CMake%3AJeep%7CModel%3ACherokee&hash=item415802f42a
Jul 12, 2011 | 1997 Jeep Grand Cherokee
Dolphin Interactive pool cleaner stops running
If the dolphin is falling backward when it meets the water line, there is an easy fix. The automatic pool cleaners often have this problem. The easiest solution is to remove the handle floats and attach an 8 oz weight to the bottom inlet cover.
May 23, 2010 | Smart Pool Inc Dolphin Diagnostic...
Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
May 14, 2009 | Mtd Garden
Hampton Bay ceiling fan - will not reverse
It sounds like the direction switch has a broken connection on the "reverse" side.  Should be an easy fix (but you might need a soldering iron).
Dec 07, 2008 | Kitchen Appliances - Others
No drive or reverse when put in those gears !
the fluid is fine its an auto by the way
the car runs fine its like someone took the gearbox out
its like its in netural in every gear it just revs
Nov 12, 2008 | 1994 Ford Aspire
Smart Pool Inc Dolphin Diagnostic Automatic Pool Cleaner Ne250 Logo
151 people viewed this question
Top Smart Pool & Spa Experts
Thomas Perkins
Thomas Perkins
Robco Water
Robco Water
Bill Boyd
Are you a Smart Pool and Spa Expert? Answer questions, earn points and help others
