Our heat pump air was working fine, then I smelled a burning odor that I could not find. I noticed shortly after that the air did not kick back on anymore. I looked at the outside unit and it was still running, but the pipes were iced over.
Sounds like your blower motor in your furnace or air handler has burned up. shut the unit down and replace the motor. make sure the ice is melted and the unit is dry before you turn it back on.
Was this helpful?
Yes
No
Popular Solutions for Sharp CV-P09FX Air Conditioner
drained unit still nothin, seem like compressor is not working
how exspensive is this part
unit...
(More)
unit turns on fan works exhaust works just no ac this thing is only few yrs old wtf
My Sharp CV 10 portable AC is not cooling. The fan works fine but even 'mega cooling' function does...
(More)
My Sharp CV 10 portable AC is not cooling. The fan works fine but even 'mega cooling' function does not produce cold air. I 'inherited' the unit and don't have a manual to troubleshoot it. Help!
I live in NYC and have a small room ( about 200 ) with 1 computer server, 2APCs and few work...
(More)
I live in NYC and have a small room ( about 200 ) with 1 computer server, 2APCs and few work stations running. So during the hot summer hours it is pretty impossible to stay inside. I'm doing my research for portable air condinioner and finally got lost completely with specs and suggestions and reviews. I do not want to get in the window air conditioner because it would block the sunlight from the window. From what I understand 9K BTU should be enough just to keep the conditions sane ( I do not need 50 degrees, a reasonable 75-80 would be enough when 90+ is outside). I also got mixed reviews about dual hose vs single hose. I purchased Royal Sovereign 12K BTU with 1500W and eats up too much electricity while barely making it 80 degrees. Also since I have a server and 4-5 PCs running my amperage goes ceiling high and 15Amps air conditioner is just too much. 9K Haier does not cool at all and did shut down twice because of the drainage. Please let me know what is the reasonable balance between single/dual hose setup, continues run without drainage and efficiency in cooling. Any unit you can recommend. Finally I set my mind on SHARP CV-P10MC, but even that unit has negative reviews because of drain issues. Besides Sharp, I was looking at Delongi models and Royal Sovereign 10K Btu. I'd like to stay within 9-10K btu, 10-12 Amps and $$300-400. Any suggestion would be greatly appreciated.
