Question about Microsoft Xbox 360 Console
X BOX 360
  • 6 more comments
  • Myuz Nov 19, 2007
    I have the same problem!!! Don;t know if it's the TV or XBox?
  • Anonymous Nov 19, 2007
    I have the same problem also.....
  • bigd4ddy Nov 19, 2007
    same problem, have tried different tv's and cables.
  • david daniel Nov 19, 2007
    bought new av cable
    checked wires are plugged in.
  • BigKahunaC Nov 19, 2007
    It just happened to me this morning too! I was playing online and my screen went blank and my tv said "No input". I checked my cables and the console was still on and had normal green lights. Please help!
  • timends Dec 05, 2007
    the problem is i turn the console on.
    i get no picture but i do get sound
    it all started like when i was playing halo 3 then the screen turned green. so i shut it off then played again later and it did it again.
    then i tried to play but now the picture wont even turn on when i turn the xbox 360 on.
    i bout a new cable and it still wont work for some reason, i need to figure out what this problem is bc my warranty is up.
  • Anonymous Dec 05, 2007
    i have connected my cables correctly i have sound but no picture!
It has nothing to do with your cables 99% of the time anyway. The prob lies internally. It has somthing to do with the solder on the connections. Look up the "towel trick" This is to be used as a last ditch effort. If you have a warranty still send it back. The towel trick works. I did it last night to mine has the exact same problem as you are describing. But be careful it does have the potential to damage more componants such as the processors. Thats why its the last ditch effort. But so far so good with mine.
Posted on Dec 05, 2007
Light is on and green but no video coming out to television what might be the problem.
Typically, this problem occurs if the audio/video (A/V) cable is not connected correctly, or if the A/V cable is faulty.
Solution 1: Set the television or monitor to the correct input
Make sure that the TV or monitor is set to the correct input for the console. Check the TV or monitor's manual to see how to configure the video inputs, or try to use the console on a different TV or monitor.
Solution 2: Connect the A/V cable securely
Sometimes, you can insert the A/V cable far enough to prevent any red lights from flashing on the Xbox 360 console but not far enough for the console to transmit images or sounds to the screen.
Solution 3: Switch the Xbox 360 Component HD AV Cable to the correct setting
Make sure that the TV/HDTV switch on the cable is set correctly.
  • For standard-definition TVs with only the yellow connector plugged in, set the switch to TV.
  • For high-definition TV or monitors with the red, blue, and green connectors plugged in, set the switch to HDTV.
For more solutions, check this web page.
Oct 09, 2010 | Microsoft Xbox 360 Console
My x-box 360 will turn on but the ring will not light up.
If the centre green light comes on, but your controllers won't sync, this could be the hdmi cable, it could be damaged or has come loose,make sure the cable is pushed into the console and tv correctly.
Let us know if this helps.
Jan 18, 2010 | Microsoft Xbox 360 Console
My x-box 360 has no picture when turned on.
Your XBOX 360 has a video problem. A different cable will not fix this. It needs to be reflowed. Look online on how to reflow an XBOX360 or send it in for repair.
May 28, 2009 | Microsoft Xbox 360 Console
Xbox 360 with no picture
Follow the steps below, Hope this helps
1. Try another Av cable ( Audio video Cable )
2. Try another television
3. If the steps dont work, call xbox customer support to have your xbox serviced. Good Luck! hope your console still has warranty
The main reason why its acting that way its possible that the AV PORT is faulty or its your cables..
Apr 07, 2009 | Microsoft Xbox 360 Console
My xbox 360 turns on with 4 green lights but i can not see any picture or sound
it sounds as if you have a connection unhooked or loose somewhere. Double check all audio and video cables are secure and in the correct position. If that doesn't work try troubleshooting by trying a different tv or removing all connections from tv and xbox and re-hooking everything back up.
Feb 19, 2009 | Microsoft Xbox 360 Console
No picture or sound on the tv
where you put the cables for the sound and picture if you look on the end where you plug it into the xbox 360 you will see a little switch it has HD and TV on it depending on what your tv supports (HD ready TV) (normal TV) switch that switch to what TV you have (e.g. HD TV, switch the switch to HD) if that doesnt work then try checking that you have all the cables in the right ports if you have pluged the HD cables into a normal TV then this is not going to work, check cables and check the switch!
Jun 05, 2008 | Microsoft Xbox 360 Console
Sound works but no image
This means the AV cable is not detected, try one of these...
1. Make sure that the AV cable is correctly connected to the Xbox 360 console.
2. Disconnect the AV cable from the Xbox 360 console, and then reconnect the AV cable to the Xbox 360 console.
3. If the four flashing red lights continue to flash, try wiping the metal area of the AV pack with a dry cloth. The metal area is the end that plugs into the console. Wipe the metal area thoroughly, and then try the AV Pack again.
4. If the AV cable is correctly connected but the four red lights are still flashing, substitute a different AV cable if you have one available.
If this is helpful at all, please rate, thanks!
Nov 24, 2007 | Microsoft Xbox 360 Console
No picture or sound
perhaps the xbox is causing the tvs to malfunction. i would get a new one. remember that xbox is giving everyone a 3 year extended warranty on the xbox 360
Jul 31, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
