Question about Bunn B10 Coffee Maker
BT-10-B Bunn Thermofresh that will not heat or fill pot
I have a BT-10-B Bunn Thermofresh that will not heat or fill the entire pot. It was given to me and I don't have a instruction manual either.
    President:
  • 1,273 Answers
Lots of times minerals clooect on the heating element and inside the heating chamber. The easiest thing to try is to put white vinegar into the filler, displacing some of the water into the pot. Leave this to soak for about an hour, then flush with several pots of water until the vinegar smell cannot be detected in the water. Make sure that the switch on the side is "ON". You may have an indicator light. The switch on the upper front is for the warmer. The reason you only got a partial pot of water is that the reservoir wasn't completely full. Once you have filled it completely, you should fet a full pot out for every full pot in. If all of the above gives you no relief, you may need to test the heating element for voltage and continuity. If it tests 'open', you will need to replace it.
Good luck, --W/D--
Posted on Jul 17, 2009
Why my bunn thermofresh coffee maker makes cold coffee
time for a replacement . they do not sell heating elements
Oct 31, 2016 | Bunn Coffee Makers & Espresso Machines
Water leaking from my Bunn ThermoFresh
if it is under warranty contact bunn directly , if not throw it away . they are not fixable
Feb 12, 2014 | Bunn BTX-B ThermoFresh 10-Cup Home Thermal...
My Bunn Thermofresh quit heating the water.
The Bun BTX-B has a pair of thermal fuses located on top of the water heater storage unit. If the pot is left without use for a week or so, the thermal fuses will blow if the top of the tank gets too hot (about 150 degrees Fahrenheit) due to the evaporation of water in the storage tank. The operating directions state clearly that if the unit is not going to be used for a few days to turn off the pot. These are there to prevent a fire in case someone does not follow the direction. This is the "MOST" common form of electrical failure in these pots.
To access the thermal fuse
1. Unplug the pot and drain pot by inverting the pot in an empty sink.
2. Remove the two Phillips screws located under the water fill flipper door.
3. Gently insert a small flat blade screw driver into the front top of the lid and remove top cover.
4. Remove the 4 screws inside the water routing tank and remove routing tank simply by lifting off.
5. The thermal fuse is mounted to the top of the tank under a clip and is easily slid out from under the clip. There is a brown wire (goes to power cord neutral) and a black wire (goes into tank disk access hole). Simply measure with a multimeter at lowest ohm setting, the meter should read continuity between the black and brown wires, if it reads an open circuit, the part is bad.
A replacement thermal fuze assembly kit is available off e-bay for about $10. You can buy individual thermal fuzes and replace one of the two that is bad for about $3, but I recommend the kit for most consumers as it comes with wire crimps already mounted and far easier for the average person to simply install. Repair takes about 5-10 minutes.
Mar 03, 2013 | Bunn BTX-B ThermoFresh 10-Cup Home Thermal...
Unit leaks water from the rear
There is a recall on certain makes of pots for the gaskets. They have a pot repair program that costs money, or you can request the parts from the company they will send you the parts and instructions on how to replace defective part if your pot is part of the recall.
Nov 03, 2012 | Bunn BTX-B ThermoFresh 10-Cup Home Thermal...
My Bunn BTX-B coffee maker won't heat the water anymore. I do not hear the water heating either? I have tried emptying the water and staeting over but the heater is not coming on. Is this fixable
Aug 13, 2012 | Bunn BTX-B ThermoFresh 10-Cup Home Thermal...
My Bunn Thermofresh leaks near the top. In the side nd in the back.
If you will call Customer Service with the model and code date on the bottom. If your machine is 3 years old or less, we will replace it free of charge.
Sep 22, 2010 | Bunn BTX-B ThermoFresh 10-Cup Home Thermal...
Bunn VPR Series Coffee Maker will NOT dispense the water into the coffee pot?
This machine has a reservoir that holds about 2.5 pots and keeps them at brewing temperature. Therefore you should pour in 3 pots (with a pot in place under the filter basket) until water flows from the basket. Then, and ONLY then, it is safe to plug in the brewer. If you plug in the brewer BEFORE filling the reservoir you will burn up the heating element and will have to have it replaced.
After the initial filling and heat up (about 20 minutes) you are ready to pour through a pot of COLD water through and brew.
Sep 10, 2010 | Bunn VPR Coffee Maker
My bunn thermofresh coffee pot will no longer keep the coffee hot. I always put hot water in the pot for up to five minutes to heat it up. This still doesnt help.
Is the coffee coming out hot enough? If you measure the coffee as it comes into the carafe, it should register at 175-185 degrees. If it doesn't, then it is a problem with the machine and needs to be replaced. If it is that temperature, then the carafe needs to be replaced. Please contact customer service with the model and date code located on the bottom of the machine. If the machine is 3 years or less it can be replaced at no cost. If over 3 years, it can be replaced at a reduced cost.
Nov 29, 2009 | Bunn B10 Coffee Maker
Water over filling pot
There is a brew timer on the left side of your machine near the heater switch. you need to remove an access panel to access it. turn this down a little, let the water heat up, then try another brew. Adjust as needed, brewing another pot between each setting.
Jan 07, 2009 | Bunn-O-Matic Coffee Brewer GRW8
Bunn B10 Coffee Maker Logo
1,078 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
