Question about Dryers
I have a maytag model 747g dryer. I dryer tumbles
I have a maytag model 747g dryer. I dryer tumbles but there is no heat. I have electricity to the unit. this just started. I could not find any loose wires at the connection in the back of the unit.
The heating element is burnt out. Unplug the dryer. Follow the wires from the control panel. They will go to the heating element. The element is probably held in by anywhere from 2 to 6 screws. Remove the screws and you should be able to pull out the element. The element is coiled wire that heats up when power is applied. If you look closely you can probably see a break in it. To get a replacement you will need the model number which will be on a metal plate either on the back of the dryer or inside the dryer door. Take the old part with you so you can do a comparison and make sure you get the right part.
Posted on Jul 17, 2009
What is the part number for a heating element for a 747g
That is an incomplete model number, do you have more information.
Feb 10, 2014 | Maytag Dryers
Dryer will turn on and count down but will not start to spin or heat up, model med6600tqo
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Apr 28, 2011 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Maytag-dryer\model number -- Ldg7304aae
This is the heating element. they are easy to replace by removing the back cover. UNPLUG it from the power source first!! The part is cheap to.
Apr 28, 2010 | Maytag HYE3657A Electric Dryer
Maytag Neptune Dryer Won't Heat up
these particular dryers have issues with the heat coils,
it probably has a bad element
Sep 30, 2009 | Maytag Neptune MDE5500AY Electric Dryer
MY MAYTAG DEPENSBLE CARE PLUS DRYER HAS HEAT IT JUST DOESN'T TUMBLE WHAT COULD THAT BE??
Nased on your description, MY MAYTAG DEPENSBLE CARE PLUS DRYER HAS HEAT IT JUST DOESN'T TUMBLE, I have provided some links that may help you diagnose your issue.
1. Drum Belt
2. Drum Belt and Roller kit
3. Parts breakdown and disassembly diagram
4. Belt installation diagram
You will need to provide the model number off the product ID tag located on your dryer to access the links information. Click link number 1 to begin.
1. http://www.repairclinic.com/SSPartDetail.aspx?s=b4a8i529597&PartID=529597
2. http://www.repairclinic.com/SSPartDetail.aspx?s=b4a8i587636&PartID=587636
3. http://www.repairclinic.com/Dryer-Electric-Maytag-Style-Appliance-Diagram
4. http://www.affordableappliance.com/Tips/beltdiagrams.htm
Aug 24, 2009 | Dryers
Maytag proforma gas dryer no heat
The model says electric and is listed as gas. If it is electric. Move all the settings (exercise the controls) If that does not work Turn both of the breakers off at your electric panel and back on. If one feels loose you know it may have tripped and you just reset it. Your drier will work fine now. Just turn it on.
Aug 12, 2009 | Maytag PYE2300AY Electric Dryer
Maytag pye2300ayw runs but does not heat.
hi..the reason to this problem is your heating
element might have gone bad.
check it out..
thank u..
kindly rate my response..
Jun 30, 2009 | Whirlpool LER5636P Electric Dryer
Need ohm readings for Maytag Performa Model PYE 3200AYW
Go to this site for info on your dryer type, you may find what you need there...
http://www.applianceaid.com/ww-and-mc.html
Jan 14, 2009 | Maytag PYE2300AY Electric Dryer
Maytag dryer sde305day won't heat
you may need to replace the heating coil from the back... i have the unit pulled apart as we speak :).... also make sure to check the connections on the back switch to the heat selector! if you need pictures i would be more than happy to get them for you please contact me a Admin ........ at .......WhyPayForHelp .... .... dot org ... the e-mail is "encrypted but you should be able to figure it out :)
~Lee
Mar 20, 2008 | Maytag HYE3657A Electric Dryer
Maytag model sde305dayw
Check your fuses or breaker...If you have fuses, replace both 30 amp fuses. If you have breakers, flip breaker to OFF then back to ON, then try your dryer to see if it heats.
Dryers Logo
546 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
