posted by Amoco on Nov 18, 2007
I am having trouble finding the right tension for sewing on knits. I recently had machine cleaned and the tensions were supposed to be set. The bottom thread keeps bunching up or not sewing straight and is loose. I am about ready to take it back to the sewing place to ask them what to do. Any suggestions?
Thanks,Lisa
Comment by Amoco, posted on Nov 20, 2007
Thanks for the ideas. I will pick up some needles specifically for knits and start there. I appreciate your fast response!
Amoco
Amoco
Best Solution
posted on Nov 19, 2007
WEhen the tensions are set after a service they are normally set for cotton fabrics, very rare will they be tested on knitted fabrics, make sure you have the correct needle for the fabric, you will need to lower the top tension so the fabric does not bunch up, with knitted fabric a little tip is to put a toilet roll on your lap and sewover the toilet roll onto the fabric the peel off the toilet roll, use a stitch length about 3 or 4, can be a bit of a nuisance sometimes getting the paper off the stitches but it does help
Rating Locked! (?) Amoco has rated this solution as Helpful
Suggest a new solution for this problem
Post a New problem for Necchi 6030 Mechanical Sewing Machine
Email this problem
Email this problem
Can you Help with these Sewing Machines problems?
Repair Service
Find Sewing Machine Repairman Near You:
