Question about LG Goldstar WG6005R Wall/Window Air Conditioner
Compressosr stays on for only 4-5 minutes but room is still hot
  • 30 Answers
What do you what for 99.00 dollars ( kidding)
It sound like the stat is defected or the unit is short cycling ( air returning to the Unit ) will shut the unit off. Try running the Unit on a lower speed and sett the stat at the highest.
Posted on Jul 18, 2009
Is it possible to find the two copasitors that go in a 125 gallon upwright air compressosr?
You need the specs off them and then go online to an electronics parts supplier and order them.
Jan 27, 2017 | Air Tools & Compressors
Why does the unit keep on switching off after running for 2 minutes
Do not know what brand or model your aircon unit is? Sounds as if the temperature you want your unit to run at has already been reached. You need to follow these steps:
- select the temperature you want
- select the icicle icon for cool or thermometer icon for hot.
- select "auto" for your unit to cut in, or to cut off to keep your desired room temp.
For example - hot day 26 degrees and you want the temp in the room to drop to 19 degrees - the unit will shut off once it reaches 19 degrees if it is set to "Auto". Hope this gives you some clues to get it working. Please tick my this helped me box if my tips work. Good luck Gerri.
Nov 27, 2015 | Heating & Cooling
Engine runs hot check engine light
could be thermostat stuck close,could be bad wire #4.plug or coil,last module.
Jun 14, 2013 | Cars & Trucks
My side side frige is warm to the touch in the middle
Getting warm around the door is OK but getting hot around door indicates a restriction of the airflow below your refrigerator. The compressor produces hot Freon that is pumped out the discharge side of compressor. On many refrigerators the gas goes to the yoder Condenser Loop first and then cooled by the condenser fan motor before going to the freezer section as a liquid.
Anything restricting that airflow will cause the yoder loop to get hotter. Example a defective condenser fan, dusty conditions below refrigerator or room temperatures way above normal for a kitchen or room inside your home. Insure fan stays on when compressor runs because a defective condenser fan does not always stop when defective. Most refrigerators work best with room temperatures in mid 70's to middle 80's. Making sure that airflow is good, fan's stay on with compressor and room temperatures stay in the normal range is important to keep those temperatures lower in the yoder loop. If helpful please rate this solution, Thanks Sea Breeze
Jun 28, 2011 | Kenmore 53642 / 53644 Side by Side...
My Kenmore side by side is hot around the door frame. How can I reset or rebot it, if possible. Model #10657943700
Anything restricting that airflow will cause the yoder loop to get hotter. Example a defective condenser fan, dusty conditions below refrigerator or room temperatures way above normal for a kitchen or room inside your home. Insure fan stays on when compressor runs because a defective condenser fan does not always stop when defective. Most refrigerators work best with room temperatures in mid 70's to middle 80's. In this case rebooting may not change much but unplugging for 10 minutes and then replugging the power is the same as rebooting. Making sure that airflow is good, fan's stay on with compressor and room temperatures stay in the normal range. If helpful please rate this solution, Thanks Sea Breeze
Jun 14, 2011 | Kenmore Refrigerators
I have a glow warm 20000 btu natural gas unvented heater. The unit is wall mounted. It won't stay on for more than 15 minutes, then shuts itself off. Its in a corner if that makes a difference... but has...
well, these heaters are typically thermostat-bound, and I have found that they simply will not burn continuously, like a blue-flame heater. Try turning up the setting--this will make it come on/off more often, effectively heating at least one med-lg room, and partially for adjoining areas. Keep in mind that these only rated for 700-1500 SF--that is NOT the floor measurements, but square feet of airspace; eg., a 10' x 15' room has 10' x 15' x 8' (8 foot ceiling) =1200 sf. That said, My 15k btu wall unit had been the sole heating source for my entire home for 5 years, until last year, when I acquired another smaller unit. However, I typically only use a few rooms, and shut off unused areas (ya, was 'cool' in unused back room areas).
Dec 16, 2010 | Desa International GWP20T GLOWARM Wall...
The heater does not stay on long enough to heat my garage. it will come on for 3 to 5 minutes and shut off. it comes on again in 5 to 10 minutes for 3 to 5 minutes again. the heat is good when it runs....
You could tripping the high temp limit this will be located near the heat exchanger When it shuts how long does the blower motor stay running? Do you have a meter?
Dec 15, 2010 | Fahrenheat FUH5-4 Heater
Picture stays on for approx. 20 minutes then goes black sound stays on. After turnign off for 5-10 minutes picture will again stay on for 20 minutes.
could be bulb.try removing and then replacing lamp.clean vent holes and allow room for ventilation.check for loose fitting wall plug
Feb 18, 2010 | LG RU-52SZ30 52" Rear Projection...
32" Insignia (Model IS-LCD32) Temporary Solution!
Hi there! Sounds like loose connections or cold solder on either PSU or main board. May also be control board if you mention the fact that menu screen pops in and out. If still under warranty I would return it to the supplier or else refer to a repairer. Best Wishes and Good Luck, JUS004
Aug 23, 2009 | Insignia IS-LCDTV32 32 in. Television
LG Goldstar WG6005R Wall/Window Air Conditioner Logo
88 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
