Question about Canon PIXMA MP600 all-In-One InkJet Printer
Machine flashing load paper message even though paper is loaded
Canon Laser Class 2050P. Machine keeps flashing the load paper message even though we have paper in the machine. I have powered on and off, but same results. I believe it has to do with the paper tray not connecting with something. When I pull the tray out and back in and hold it, it will print only 1 page in memory. When I let go of the tray the load paper message begin to blink again.
  • contactces Jul 17, 2009
    It appears you are giving me instructions for another machine, not the Canon Laser Class 2050P fax machine. The items you refer to don't exist on the 2050P
  • 92 Answers
Hi ...
Most of the time this problem comes when the paper is not loaded correctly. Follow the below instructions to load papers to the cassette and I am sure this will resolve your problem. I will keep monitoring your responce and if required, i'll look for a work arround.
Follow this procedure to load paper / envelope in the cassette:
  1. Pull out the cassette from the machine.
  2. Remove the cover from the cassette.
  3. Fan out the sheets of paper so that they do not stick together.
  4. Align the edges of the paper.
  5. If the cassette is not yet extended, use your thumb to press the tab (indicated by the pink circular outline) and release the latch.
  6. After the latch is released, remove your thumb from the tab. Then extend the casseMachine flashing load paper message even though pa - 05sj00149_02.jpgk is heard.
  7. Load paper on the upper-right corner of the cassette with the print side facing down.
    Note:
    * Since the Credit Card sized paper, Canon Photo Stickers, and Legal sized paper cannot be fed from the cassette, load them in the auto sheet feeder (ASF).
    * When loading A5 or larger sized paper (nonstandard-size paper: 203mm / 8inches or more in length), extend the cassette by pinching the tab.
  8. Grasp the paper guide (A) and align it to the long edge of the enMachine flashing load paper message even though pa - loadenvcass780.gifAlign the front edge of the paper stack in the same way (3).
  9. Close the lid and push the cassette all the way into the printer.
  10. Press the <Open> button and pull oMachine flashing load paper message even though pa - 05sj00149_04.jpg completely.
  11. Press the <Feed Switch> button to turn on the Cassette light.
    *MP500 shown.
    Note:
    If the Auto Sheet Feeder lamp lights, press the Feed Switch button to light the Cassette lamp.
    If the Cassette lamp does not light even after pressing the Feed Switch button, Paper Source in the printer driver may be set to the setting other than the Feed Switch button.
Loading on envelopes
Paper Type
Precaution
Envelope (DL / #10 )
Set paper with the flap closed.
  1. Press down firmly on the edges of the envelopes to make the folds crisp. AMachine flashing load paper message even though pa - envprep360.gifmly on the area that corresponds to the edges of the back flap.
  2. Remove any curling by holding the edges diagonally and bending them gently.
  3. If the edges of the envelope are inflated or are curling, place the envelope on a flat surface. With a pen, press down while moving it from the center toward the edMachine flashing load paper message even though pa - 05sj00149_05_te.jpg.
  4. Ensure that no curl or puff exceeds 1/8 in. (3 mm).
  5. Load envelopes in the cassette with the print side facing down and the flap towards the left.
  6. Press the <Open> button and pull out the extension completely.
  7. Press the <Feed Switch> button to turn on the Cassette light.
    Note:
Don't forget to vote if this helps ... Cheers :)
Posted on Jul 17, 2009
Does anyone have a link to download software for my canon laser class 2050p? Lost CD
here it is http://www.usa.canon.com/cusa/support/office/laser_facsimile/laser_class_2050_2050p_2060_2060p/laser_class_2050p#DriversAndSoftware
Feb 05, 2014 | Canon LASER CLASS 2050P
When recieving faxes on our canon laser class 2050p, the machine has a loud squeak
Your rollers will need to be replaces. Rollers feed the paper through the tray. You can find paper feed rollers for your device here:
http://www.precisionroller.com/paper-feed-components-for-canon-laser-class-2050p/products.html
They are very straight forward to install and instructions should be in your manual.
Mar 07, 2011 | Canon LASER CLASS 2050P
Problems with Canon 7500 Laser Class fax
I have Canon 7000 Laser with Error message #330 which said
SET DOCUMENT??? HELP?
Dec 03, 2008 | Canon LaserCLASS 7500 Plain Paper Fax
CANON FAX MODEL L220
Hi Greg.
Press the red STOP button.After loading paper.
Nov 07, 2008 | Office Equipment & Supplies
Re: Canon Laser Class 2050P fax machine - the 'check cover' message is flashing despite changing the toner (twice) Help, please
check cover has to do with the door.
either the switch is not being activated or there is a problem with the door
Aug 12, 2008 | Canon Office Equipment & Supplies
Exactly the same as BerniceMc described (Canon L220). Powering off and on again eliminates the problem as it does all faxes in memory. Greg
May 23, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Error message on Canon Fax Machine 2050P check cover/cart
there are a couple of things did you buy genuine or reman cartridges and check if they are seated properly.
some remans dont work properly so you have to be sure and always get a money back guarantee from the seller
Feb 26, 2008 | Canon FAX-L350 Plain Paper Laser
Canon PIXMA MP600 all-In-One InkJet Printer Logo
796 people viewed this question
old marine
old marine
