Question about Sony Playstation 3 (PS3) Console
Infocus X10 reports "no signal" /connected to my Denon AVR3808A
I've tested the receiver in the store and it works on other projectors. But when I test it at home, I get the same problem. In fact, it blocks the sound signal in the receiver. If I put a dvd/blueray disc on and wait for the sound to come though the speakers.. then turn on infocus X10, it shuts down my sound and of course still no picture.
I've tried triggering the menu in the receiver, but nothing works.
3 Suggested Answers
  • 172 Answers
SOURCE: PS3 80Gb can not connect to Infocus X10 via HDMI
it is not your hard drive
you have to reset the video setting and it will work again Hdmi is different on each tv so you have set this up again ok let's do this with the unit off turn the main switch on the back of the unit connect your Hdmi cable to your tv now place your finger on the front on/off switch keep your finger there ok now turn the mainswitch on the back of the unit the playstation turns on but don't remove your finget yet wait about 4 seconds or until your heard another bip (not the one when the playstation turns on) once you heard this bip remove your finger before the playstation turns off if you let it turn off try again all of this but if you remove your finger on time just wait few more seconds and bingo you have picture again using Hdmi
Posted on Mar 13, 2009
  • 210 Answers
SOURCE: PS3 to Infocus LP 350 projector using HDMI
M1-DA is a type of DVI connection that produces both analogue and digital signals, the easiest and most quality source cable for you to get is a HDMI to M1-DA cable which is now widely available for purchase.
Infocus should have included this cable in with your projector, but instead the power at bee decided to put a M1-DA to DVI-D cable instead when most visual devices now support HDMI and not DVI nowadays.
Posted on Sep 05, 2009
Denon AVR-4806 HDMI problem
Check which port you have the HDMI cable connected to, then go into the menu on the TV, look for it on screen and Enable it .
Good luck
Nov 16, 2013 | Denon AVR-4800 Receiver
Infocus x10 overheating
I have had this problem a few times on the X10. The reason in my case has been to much dust on the air filter before the lamp. I usually clean it my self, but the X10 needs to be opened. If you don't feel skilled to do so, you can try use a vacume cleaner on all ventilation openings. If that doesn't help, take it to a skilled workshop. PS. This can also cause colour problems and stripes on the picture before it stops completely. The X10 should have had a changable filter in front of the lamp filter. Apart I'm very satisfied with the X10. Brg Tom
Aug 18, 2012 | InFocus X10 DLP Front Projector 1080p DLP...
The SP7205 will only show 480P. I have connected a DVD to the 7205 via composite cables however the unit only shows 480p. How can I get 720p or 1080i?
Unfortunately the highest video signal you'll receive through composite is 480p. To achieve anything higher than the said signal, you'll need to utilize either the component or DVI input of the projector. Those inputs will detect any HD signals.
Also if you've not done so already, you'll need to check the settings of your DVD player to make sure that it's outputting 720p and/or 1080i/p signal. Hope this helps you out.
Aug 09, 2011 | InFocus ScreenPlay 7205 Multimedia...
I just replaced the lamp on an Infocus X10 DLP projector. The left half of the screen is now darker than the right side. What can this be? Thanks.
This is seemingly a common issue on the IN82 (which I've also had) and is usually resolved by switching off the 'BrilliantColor' setting in the menu.
Nov 09, 2010 | InFocus X10 DLP Front Projector 1080p DLP...
Denon AVR 1610 hdmi to component video conversion missing?
hello i believe your problem is that you are trying to downconvert from hdmi to component connections and Denon receivers will not do that.
I have a 4310 and I know it will UPconvert from an analog signal to HDMI but won't do it the other way around.
you may have to use component inputs for all your equipment. You will also have to go into the receivers menu and designate which signal is being used for each component as it won't auto select between analog and digital signals when it comes to video.
hope that helps
Dec 30, 2009 | Denon AVR-1603 Receiver
Digital projector is shutting down as soon as dvd
Hi make sure that in the projector menu it doesn't have an option to cancel "control" as many tv's with hdmi have the capability to receive command signals through the hdmi cable.
Also make sure that your receiver is set for hdmi signal you must designate which input you are using on the receiver and then tell it what type of signal you want it to use.
you may have just pushed a button that changed these settings somewhere along the way.
hope that helps
Dec 30, 2009 | Denon AVR 3808Ci Receiver
The start up screen is on with no signal through
Try a firmware upgrade.
Oct 24, 2009 | InFocus Play Big IN76 Multimedia Projector
Can i connect my xbox to X10 projector
yes it does... and there is available input for HDMI, S-VIDEO,M1-DA, & Composet video.
Oct 08, 2009 | InFocus X10 DLP Front Projector 1080p DLP...
Hi' I have a Denon 3910 that is connected to an Infocus Projector via HDMI out on the Denon to DVI on the Infocus(One end of the lead is HDMI the other DVI) .problem has always been without the projector...
You can try this reset method, if it doesn't work it will probably need service by a professional. Remeber that all setting will be lost, make sure you know them so you can put them back in after you are finished.
At the player stop condition,
press 3 buttons for DVD operation
(“PLAY”,”OPEN/CLOSE”, and “ SKIP”) until
“INITIALIZE” appears and disappears in the display.
(“Initialized” appears and disappears on the TV screen.)
******All user setting will be lost and its factory setting will be
restored when this initialization is made. Be sure to memorize
your setting for restoring again after the initialization
Jul 03, 2008 | Denon Audio Players & Recorders
Sony Playstation 3 (PS3) Console Logo
105 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
