Question about Kenmore Heating & Cooling
Kenmore 12,000 BTU unit 60days old compressor dead
I have a brand new (60days old) Kenmore 12,000 BTU window A/C and yesterday the compressor died on me! First i removed the filter and cleaned it and ran water over it, that didn't help, then I tried to only run the fan for a while, that did not help, then i tried unplugging it for a half hour, that didn't work.. I packed it in my car and am looking to return it for a refund or exchange.. On my way to work this morning I called SEARS service and they offered to sched. an in-home repair service. being that the unit is only 60days old, i wish to try and return it first.. we'll see!
  • 30 Answers
  1. Sears or any firm that sells a Unit has to have a chance to look at the problem and repiar it, if you installed it WRONG that is Bad ! Sears will not be responsible for damge to the Unit, bring it to them, you might have to leave it for days - better to have a serviceman come to the home - Units are covered for 90 days all but Electrical ( ???) You better have the bill of sale ( date purchased ( not installed !! )
Posted on Jul 17, 2009
Can a Fujitsu compressor unit be connected to multiple inside evaporator units that have different tonnage ratings. 18,000 BTU compressor and 9,000 & 12,000 BTU evaporator units inside.
call fujitsu engineering division direct and ask them about what is connected and if it works ok
logically as each evaporator has it's own tx valve as long as the compressor is large enough to run all together it should work but get the right information from the fujitsu experts
Oct 11, 2016 | Fujitsu Heating & Cooling
A brand new keystone thru-wall air conditioner is installed and plugged in. The power is on but it doesn't work. What could be the problem?
The unit has a start time delay (3 to 5 minutes) to protect the compressor against starting under high after a short time power failure. Most people tend to turn the unit off when it doesn't start when turned on.
Jul 28, 2014 | Keystone 12,000 BTU Thru-the-Wall Air...
I bought an amcor 12,000 BTU portable AC two years ago. I used it for a month, never used it last year, and then tried to use it yesterday and it is dead. As in, there's no response when I push any...
When a sett is kep unused for sometime the possibility of faults can vary as when it is in regular use.The best way for a first hand info is to trace the line of power fromthe controller unit to the compressor.Check the line to the compressor, if the control panel is faulty, check compressor relay, check capacitor.
Since it is failure of power, it can also be a wire break.
Sep 01, 2010 | Amcor ALTL-12000E Portable Air Conditioner
Our 8yr old 14,000 BTU Friedrich
Check the stat or cap, but for the most part cheaper to replace it.
Jul 17, 2010 | Friedrich Heating & Cooling
Need window air conditioner to fit window 23" wide. Studio apartment main room is 13'X17' with kitchen 6'x17' and walk-in closet and bath 5'x17'. Would like a kenmore and quiet while in operation.
Hi; Try purchasing an up right portable ac unit. Then all you need to do is vent the hot air tube out a convienant window or dryer duct. Needs to be at least 12,OOO BTU. I size my installs to 400 sq. ft. per ton(12,000 btu)
Jan 18, 2010 | Kenmore 75085 Air Conditioner
Just put in a new ac unit and replaced a old one. old unit was 18000 btu and the new one is on 12,000 btu I used the same power outlet but the new ac unit starts up but then shuts down and seems like it is...
The 18,000 btu A/C is 230 volts, are you sure the 12,000 btu unit is 230 volts most are 120 volts.
Usually 12,000 btu is the biggest 120 volt A/C you can buy.
Jul 10, 2009 | Heating & Cooling
12,000 BTU Kenmore, almost new not cooling after non use
tray opening the a/c unit and see it there is a loose cable specially the real thin ones going to the control board i seen this problem before.
Jul 04, 2009 | Kenmore 75085 Air Conditioner
Heating & Cooling Logo
78 people viewed this question
Top Kenmore Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
1STHVACMAN
Bill Long
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
