Air conditioner doesn't turn on, believe its a blown fuse, where in the air conditioner is the fuse
Is this a split system? If it is then the fuse or breaker is in the disconnect box on the wall by the outside unit. You will see a grey flex conduit running from the unit to the box which is grey, it carries your 230 volt wires. Inside that box will either be fuses or a breaker.
If it's a window unit then it will be the breaker that supplies the power to that outlet.
