Question about Brother LS-1217 Mechanical Sewing Machine
Skipped stitches my brother ls-1217 keeps skipping stitches, especially when I zig-zag the stitches.
  • 46 Answers
Change the needle first and make sure it is inserted correctly. Use good thread i.e.: Guterman or Metler are some. If you are using a stretch material then put a stretch needle in the machine. If you do all this and it still skips then you may have a mechanical problem with the machine. The machine is "out of timing". Have a good tech. look at it. This happens quite frequently on "inexpensive" machines. Sorry.
Posted on Jul 28, 2009
How do i check if the timing is correct
Put in a new needle. Thread machine with same thread top and bottom. Set upper tension to default (4/5 usually) and sew in straight stitch with needle in default position (usually centre) some times left. Turn hadwheel by hand towards you for the first two stitches to ensure needle not hitting hook or driver. If machine sews find, then try the zig zag. If both these are good, timing is good. If not, and stitches are skipping or not forming, it could be a timing issue and you should take it to a tech
Machine Tech
Oct 21, 2013 | Brother LS-1217 Mechanical Sewing Machine
My machine sews straight when set to zig zag and skips stitches sometimes. It zig zags but only gets half the stitch.
If your using a stretch fabric, youll need to sew in a stiffner tape. if the fabric "flags" i.e moves up and down with the needle it spoils the loop needed to form a stitch. If your having problems with a stiffer fabric it could be just a bad or too thin a needle. Check threading, needle condition and setting.
Dec 12, 2010 | Brother LS-2125 Mechanical Sewing Machine
I used the zig zag stitch for a project but now I am unable to return to a straight stitch.
make sure that the needle is in the UP position, and then try that, say if you have a 0 to 5 then set it back to o
Aug 11, 2010 | Brother LS-1217 Mechanical Sewing Machine
MC4400 skips on the zig zag stitch when sewing
You must buse an anti static needle otherwise yoiu will miss stitches.
Jul 13, 2010 | Janome Sewing Machines
Skipping stitches on zig zag pattern
Bent needle will do this or a dirty grip advance wheel
Mar 30, 2010 | Brother LS-2125 Mechanical Sewing Machine
Skipping stitches while zig-zagging
If you have put a new needle in then the chances are the machine has gone out of time, you can either take it in to the repair shop or you can contact me and I will attach timing instructions drivewithken@blueyonder.co.uk
May 01, 2009 | Singer 5050 Mechanical Sewing Machine
Brother vx790, my stitches are reversed ( top is on botom & bottom is on top )
It sounds like your tensions are out of adjustment. Your upper tension should be between 3-5 and make sure the tension in your bobbin case is not too tight as well. Pull the thread through the bobbin case and make sure it comes out with a small amount of resistance. If no resistance, tighten the tension just a bit, if too much resistance, loosen it just a small bit at a time.
Sep 10, 2008 | Brother LS-1217 Mechanical Sewing Machine
Brother LS-1217 Mechanical Sewing Machine Logo
265 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
