Question about Creative Labs Zen V MP3 Player
WONT TURN ON
When power slide down pop up creative logo on screen but it frozen. No menu or any thing. creative logo frozen. no buttons work. cant turn off. when i touch reset button hole again pop up creative logo screen and frozen. please help thanx
SOURCE:
SOURCE: Zen sleek frozen after trying to delete songs
Why does technology make you work for what you already paid good money for? Have you tried going into Recovery Mode? You do this by holding down the Play/Pause button while triggering the Reset button. Once there, you have four options. Try selecting Disk Cleanup and then Reboot. You might need to re-Sync a few things but it's worth a shot. Good luck.
Posted on Feb 13, 2007
SOURCE: Creative zen sleek frozen!
Try inserting a pin into the tiny 'reset' hole on the bottom of the device.
Posted on Nov 05, 2007
SOURCE: Creative Zen Nano Plus FROZEN!!!
here is a fix if your creative zen nano plus just hang on the creative logo when you turn your player on.
download, Creative ZEN Nano Plus firmware.
you can find it at the creative website, download section.
double click the file you just dl'ed, now make sure your
zen nano player is already connected to your pc when you run the file. it may take a bit of time before your pc can detect your zen nano be patient, a window prompt will soon appear asking if you want to update your firmware with the one youve just dl'ed.
now, dont worry if the firmware is the same as the one already
installed in your zen nano, just continue with the update.
you can also check the box in which there is the option of also formatting the drive. ( note: all files in your zen nano will be lost)
after the firmware is flashed you can now play and transfer files to your zen nano plus.
Posted on May 09, 2008
SOURCE: Creative Logo frozen on Screen
Mine did the same thing, and this helped. I took out the battery, and then slid the power switch toward the power icon and held it there while putting the battery back in. This turned on the Recovery Mode. I selected "cleanup," and after that was done, I selected reboot. Once that was finished, the Zen started rebuilding the library. After that, the Zen turned to the menu screen and I was able to listen to music like normal. Hope that helps!
Posted on Aug 03, 2008
SOURCE: creative zen 8gb wont switch on or recharge
I had the same problem. Tried recharging from both PC and mains recharger. Tried re-setting and re-charging. All I got was the blue charging light pulsing on and off. The ZEN would not charge. Eventually I tried a Software re-set. (Slide the on/off button to the On position and hold it there whilst hitting the re-set button). I then tried re-charging and everything was fine. (It did take about 10 - 15 mins recharing from the PC before the device did actually respond, but that is normal after it is fully discharged)
Cannot guarantee the above will work every time or for everyone, but it saved me returning it to Creative and an eight week wait.
Posted on Jan 24, 2009
How to reboot an iPad, a video clip is stuck on running
Rebooting is easy. It is called a hard reboot. Just hold both buttons down until you see a red slider, and then slide it to shut down. It will restart, and you will see the Apple logo.
Oct 30, 2014 | Apple iPad 64 GB WiFi
How to unfreeze my nokia lumia 900
Mine just done the same thing all you need to do is hold down the off/lock button for at least 15-20 seconds then the screen should turn black which means you can turn t back on again and It should work.
Jul 27, 2012 | Cell Phones
Won't let me slide to unlock my itouch
Allow the iPods battery to completely die and then fully recharge it. If it wont unlock then your displays touch sensitivity is not working and you may need to replace the display or it may be cheaper just to replace the iPod Touch
Jul 21, 2009 | Apple iPhone Smartphone
Creative Zen frozen and Reset has not worked
You probably shouldnt play with any of the buttons really but i know how to fix it. You hold down the slide power for about 5 seconds and poke the reset button with a pen tip or w.e for about another 5 seconds till it restarts itself.
Mar 28, 2009 | Creative Labs Zen Digital Media Player
Ipod nano 8gb
First thing to try is a reset
To reset your iPod:
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
Oct 21, 2008 | Apple iPod nano
Jul 28, 2008 | Creative Labs Zen Micro MP3 Player
Creative Zen V Plus Frozen on the product title screen
this helped me as after it rebuilds the libary then it always froze on a song let the battery run out!
this worked for me straight away and i had tried loads of other ideas this actually came from the tech guys !!!
  1. Detach the player from the PC if it is connected, and turn off the player.
  2. Press and hold the Play button while powering on the player.
  3. When the player displays the Creative logo, release the Play button
  4. Select Format (All) and select Yes to format the player.
  5. After the player has finished formatting, select Reboot.
  6. Re-transfer the tracks to the player.
Feb 16, 2008 | Creative Labs ZEN V Plus MP3 Player
Apple ipod nano 4gb sliver third gen
First make sure your hold switch isn't on. It's on the top and slides back and forth. It needs to be switched to the left. If it is to the left, here's how you reset:
You can reset your ipod by holding down the menu and select (round button in the center) buttons down for at least 10 seconds. You'll see an apple logo flash, that's when you stop pressing the buttons. It will shut off, then back on.
Dec 26, 2007 | Apple iPod nano 3rd Generation
Ipod nano
Dec 13, 2007 | Apple iPod 3rd generation MP3 Player
Stuck with my creative zen
There's a little area at the bottom that says, reset, you take a thumbtack, and just pop it in! It will be back to working condition without losing files with no problems!
Feb 06, 2007 | Creative Labs ZEN Vision:M Digital Media...
Creative Labs Zen V MP3 Player Logo
50 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Marvin
Marvin
Peter Dragonetti
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
