Question about Dishwashers
Do you use only hot water for portable dishwasher?
  • 297 Answers
Yes all dishwashers should use hot water.
Posted on Jul 17, 2009
My GE Portable dishwasher won't fill.
Possibilities:
Water off.
Blocked water filter
Water solenoid valve not actuating
Water solenoid not getting power
Not getting power could be:
Stuck pressure switch,
Programmer not working
Broken lead
Feb 13, 2015 | GE GSC3500RWW Portable Dishwasher
Won't let water in
Hello.
The Hotpoint is a portable dishwasher that has pump guard, overflow protector,rack bumper to prevent the rack from falling out of the dishwasher duringmovement, and temperature and wash options. When the dishwasher is properlyconnected to a water and power supply, it should work well in general. However,if something goes wrong, such as if the dishwasher will not fill with water,some troubleshooting methods may be beneficial in finding a solution to theproblem.
Instructions.
1 Ensure the water faucet is turned on and the connection between the water andthe dishwasher is secure. The hose connector should be snapped into placebetween the water faucet and the water hose.
2 Straighten the water hose and check for possible obstructions in the waterhose, the water faucet and the hose connector. Clean as necessary. Turn on thefaucet hot water slowly until it is all the way on to ensure proper water flowto the dishwasher.
3 Open and close the dishwasher door firmly. The dishwasher will not start awash cycle if the door is ajar. Verify that the dishwasher is plugged in to aworking power supply and that a wash cycle has been selected.
4 Avoid running other appliances that use water, such as a clothes washer,while the dishwasher is running, to avoid improper water pressure. This mayresult in a lack of water flow to the dishwasher.
5 Check to make sure large dishes, such as cookie sheets, pots or pans, are notblocking the spray jets. Avoid overloading the dishwasher.
Thanks.
Sep 15, 2011 | Hotpoint Dishwashers
My dishwasher does not start up when the dial reaches wash. I open the door and water is in but it never washes. never had the problem before. It is an old portable, but did work so good! What happened? Do...
It sounds like it could be caused by the fact that the heating element has failed so that the washer will not proceed with the wash program until the water is up to the correct temperature. You should be able to tell if the element is getting hot. You could try manually putting in hot water before the washer fills up with cold to see if the wash then proceeds.
Sep 22, 2010 | Whirlpool DP1040XTX Portable Dishwasher
Asko dishwasher d3530. The water in the dishwasher is not hot.
Generally speaking, dishwashers don't heat cold water on their own. Be sure the dishwasher is connected to a hot water supply and that hot water is available to the dishwasher at the START of the cycle.
Often it takes hot water several seconds for house plumbing to deliver hot water to an outlet. If the dishwasher is connected to the kitchen hot water supply, run the water in the sink until the water runs hot before you start the dishwasher.
Dishwashers often have heaters to heat the water even hotter than most home water heaters, but they are not intended to heat cool or cold water. You MUST furnish hot water to the dishwasher from the time the cycle is started.
I've seen houses that take so long for hot water to reach a faucet, the dishwasher is already full (of cold water) before the first drop of hot water reaches it.
Good luck. Hope this helps.
Sep 11, 2009 | Asko 24 in. D3530FI Built-in Dishwasher
Need portable DW but have low hot water pressure in apartment
all dishwashers i am aware off have their own heater and are better connected to cold not hot water
Jun 26, 2008 | Dishwashers
Older portable dishwasher
nothing it needs a switching kit or drain solenoid kit rather
Dec 30, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Dishwasher will not spray water from arms
Check for utensils or pot handles that may be hanging below the bottom rack and interfering with motion of spray head.
Clean holes with toothpick.
Check temperature at hot water faucet with meat thermometer. If below 120°F (49°C), turn up thermostat on hot water heater.
Oct 19, 2007 | Dishwashers
Dishwashers Logo
Top Dishwashers Experts
