If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
SOURCE: PS3 not showing up anywhere.
yeah had the same prob when i wanted to play on a mates non hdmi telly.. but its simple really connect everything up then switch on hold the powers for 5 seconds this resets the connection settings from Hidef to standard ..easy peasy..... was workin fine. but mine is sayin cannot start, the correct hard disk was not found any 1 any ideas?
SOURCE: No input signal HDMI
turn on and hold down the on/off button for thirty seconds when it resets it will load up via hdmi lead this works both ways going from sd to hd, failing that have both connections plugged in both scart and hdmi lead then change the settings to hdmi when viewing through scart connector then flick to hdmi input and hey presto its worked.........
SOURCE: my xbox 360 turns on, no audio or video
Sounds like the Graphic processor needs to be reflowed and new thermal compound (artic silver 5) installed. Its basically the same problem as the RROD just without the lights.
SOURCE: Previously my video was not woking but the audio
it depends on your tv if hd tv theres a switch on one of the jacks switch that to hd if non hd then ull have to get a non HDMI lead
