Question about Gateway 400SD4 Notebook
My screen won't come on. It remains black. I can hook the notebook up to another screen and it works fine
Samsung TV won't turn on. Red light is solid, won't blink when pressed. All capacitors seem fine (none swollen or vented).
That model is covered under a class actions lawsuit settlement over bad power supply boards. You need to contact Samsung about this and get a warranty claim started, even if the original warranty is over the settlement terms will cover parts and labor. You can get additional information about this along with contact information here: http://www.ccl-la.com/blog/index.php/samsung-has-reached-a-settlement-in-class-action-lawsuit-over-faulty-tv-power-supplies/
Sep 24, 2012 | Samsung LN32A330 32 in. LCD TV
Black screen on hp G56-122US notebook
Hold down the fn key and press F4 to switch the display. You may have to do this a couple of times before the display comes up.
Sep 14, 2012 | HEWLETT-PACKARD HP G56-122US Notebook
Hp dv5020us won't boot. upon power up I get some brief hard drive activity and fan noise. No blinking LED error codes. Caps and/or Num lock LED's do not light. Power LED will glow and HD...
step one, big battery out? skipped that?
step 2, a good power pack , that means 19vdc on those 2 pins.
bingo BIOS screen now work ,yes?
step 3, try an external VGA screen at the P15 VGA jack there
screens work now (BIOS first) yes/no?
remove DVD, drive
and all USB devices
there booting with only 1 memory stick. (got more?, try each 1 by 1)
black screens of *****'.
the lack of flash codes, Implies Power pack is dead. or CPU overheated, and selfshuts down. that fan going dead tells
me the power park is dead.
http://pcdied.com/#black-screens
May 01, 2017 | HP Pavilion dv5020us Notebook
All the lights turn on on the hp pavilion dv1000, but the screen remains black. Almost as if there was no power going to the screen. I have tried reseating the RAM and the HD. Problem still remains. ...
Hook a external monitor to the video output on the back of the laptop, if okay! there is a LCD problem with the laptop screen, causes! bad inverter board, or back light. If both show black! causes are Video Graphics Card that is part of the motherboard.
Jan 10, 2011 | HP Pavilion dv1000 Notebook
Hi! I have HP pavilion dv1000 that works fine until just this Thanksgiving (Nov.2th) when i turned the computer the screen is just blank or black but it is still working. I am able to use the computer now...
Unfortuntly sounds like your screen went bad.
Sorry I can't give you any better help with this one, it can be fixed, just going to cost you around $100.. for new screen.
Sorry
Nov 27, 2010 | HP Pavilion dv1000 Notebook
Black screen but there is power?
try to remove the battery and connect power supply then  power on ...if not worked then u should try to change the RAM
Jun 20, 2009 | IBM ThinkPad T40 2373 Notebook
Black Screen
The first thing I would do after turning the computer on is check to see if the video output is being directed to the LCD screen. The output can be directed using the Fn key along with the key with the picture of the 2 monitors on the Function keys at the top of the keyboard. Hold down the Fn key and tap the other key once or twice,
Next, hook the computer up to an external monitor. Do the same thing with the Fn key to see if it's the LCD screen.
If the external monitor works, then you haven't correctly hooked up the LCD screen or it's bad.
Feb 05, 2009 | Averatec 3200 Notebook
Black Screen
sir,u replace ur camera CCD
Apr 06, 2008 | Nikon COOLPIX S5 Digital Camera
My monitor does'nt work, computer boots up but the monitor is black. What can I do?
when i start up my computer i can hear the sound of the welcome screen and desktop but the monitor remains black with stand by orange light but when i make restart it works normal.
Jan 27, 2008 | Compaq Presario R3000Z Notebook
Gateway 400SD4 Notebook Logo
89 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
