Tablets & eReaders Logo
G
Glenn Posted on May 25, 2016
Download keeps gathering info and doesn't load
When I press download it continuously circles gathering information and does not start the download
yamen kayyal
Level 1:
New Friend:
Problem Solver:
  • Contributor 6 Answers
  • Posted on May 25, 2016
yamen kayyal
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
6
Questions
0
Helped
563
Points
13
Hi there glen there are a lot of conditions for that the most important one is that you are connected to a network the second one is the link might be broken or the peers or seeders no longer uploading the information of the app for you to download , i think maybe trying another link will work for you
i hope this answer was helpful
How do I register when I do all I am asked and it does not accept info...HELP
You need to double check that you are entering all your information correctly. If you already have an account be sure you can log into that account online away from the tablet. If you have forgotten your password then choose 'I forgot' to have a reset form sent to you.
If the problem continues then contact Amazon support.
2answers
Want to download free Google play app ?? Keep going around in circles ??
U can download android apps from amazon app store.. Its an alternative for playstore..
Why does keyboard keeps hitting same key without touching
Heres a few ways to get around issues with keyboading.
What keyboard app are you using? You can download alternative keyboard apps as one way to get around bugs in the stock Nook Keyboard app. I love Swiftkey as it's now free. Google itself has has its own keyboard app. Both run circles around stock aspecially Swiftkey.
Are you using any of the accessibility features? Go Settings - Accessibility. Make sure the choices are all set to off.
Press the Switch Keyboard button. Press Set up input methods.
Be sure it shows your correct language, turn Auto capitalization to off. Turn auto correction to off.
Triple check your screen is really really clean and smooth to the touch.
Jul 09, 2014 • Nook HD+
Em543 tablet
You'll need to do a factory reset:
1. With the device off, press and hold Volume Up and Power.
2. Release the Power button when you see the logo, but continue to hold Volume Up until the recovery screen appears.
3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
4. Press Volume Up continue.
This will reset you device to factory settings, however anything on your SD card will still remain.
At this point you will need to start fresh as if you just bought the device -- register with your email address, etc.
1helpful
Update problem with lg v900
there are no official update for this Tablet. LG doesn't make any update for LG V900. Before, I also keep asking the LG customer service a few times until they answer "No UpDate"...:(
Why don't the AppsLib work
Watch this Video: http://www.youtube.com/watch?v=6BrWSC2uiAg
The model he's using is the 7022, but the same procedure works for the 7125. Download the APK files that are linked in the video description and then connect you 7125 to your computer to copy them over. Once you have them copied, use the APK Installer that came pre-installed on your 7125 to load them. Make sure you load them in the order given on the video! I loaded them in the wrong order the first time and had to do a factory reset because the Back button (silver circle) no longer functioned.
Once you do all this you will be able to load the typical Android Marketplace and ditch the AppLib that doesn't seem to work.
2answers
When turning n the cruz tablet, the word cruz pops up and goes away. then cruz flashes
First don't worry too much you're just stuck in a loop or have bad firmware (most likely). The fix is probably going to be easy but you have to do some things. Just follow the directions I give and that Velocity gives and you should have no problems in about half an hour.
Take out the top SD card. Put in in your computer or an adapter that goes to the computer.
Go to the cruz website and download the current firmware (http://cruzsupport.velocitymicro.com/ics/support/KBAnswer.asp?questionID=814).
Even if you have updated the ROM something could have happened and it could be corrupted so replace it. Put that firmware on your sd card. Do not extract the zip file. Do not change its name. If the name changed (like if it has (01) at the end) delete the old file you downloaded and change the new one back to the old name.
Eject your sd card when you finish and put it in your tablet.
Press the top power button and the up volume button at the same time. Continue holding. You will see cruz but dont stop.. it'll flash kinda and it'll still say cruz.. keep effin' holdin'...
the robot shows up: you win! let go relax give it some time to freshen up. Have a cup of coffee and let it finish. Everything will be tidy and new when it's done.
the robot doesn't show up and the same thing that's been happening happens again: try pressing reset when it turns on (paper clip in that hole youll feel a button when you get it right). Keep pressing it the whole time it has power to try and get a hard reset. Do it like 2 or 3 starts and fails just for good measure.
then try to flash again (power and volume up).
if that doesn't work pull the back, unplug the battery and wait 30 seconds to a minute. plug it back in and try flashing the first time you start up. like don't press power hoping its going to turn on now. It won't. You have given it a clear quick access memory which may let you get to the point where you can flash without failing.
IMPORTANT: On the first time after the battery is plugged in hold power and up volume together and keep holding. This is important. If you press power it will recurrupt the RAM and you made the back lose and unplugged the battery for nothing.
If that doesn't work.. well it should. You're stuck in a loop that you should be able to pull out of. Go back the the beginning and make sure you have the new file you downloaded and the name is correct (its on the cruz support website).
If that's all done properly try the battery thing one more time. If it's still failing don't give up.. give it hell. I was stuck in a bad one going strait to white screen only being able to shut it off by pulling the battery and I was able to get it to flash (took about 30 tries). For the trying at this point you don't have to pull the battery just keep starting it with power and volume up pressed.
As long as you're not staring at a black screen you should be able to fix this.
Good-luck!
My hp pavilion tx1320us is not displaying any image, the screen comes up black
does it start....
if yes then press F8 before the Win screen comes...just after u press the power on button...
can u get the option to load in Safe mode...if yes chose Safe Mode
in Safe Mode if u get Desktop and can download from net
go to my website
www.sureshayyar.110mb.com
go to Download page and get Tuneup Utility and crack downlaod install both the software and crack and run a registry clean
Shut down
remove all power source, power/battery etc
remove all power cables
keep pressing the power on button for some time say 2- 3 mins....do ON OFF for some time....
reconnect battery/cables power ON
c if it works now...let it boot in normal mode
Top Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
