Question about GE 21095GE2 Cordless Phone
I have not had a dial tone for several days. I have powered down all devices.
Contacted LINGO technical support and after several hours they got the problem taken care of. Thank you for your concern.
Posted on Jul 19, 2009
My phone dials too fast. The only way I can dial a number is by taking it off the hook and manually dialing after I hear the dial tone. If I use Caller ID, redial, directory, or putting in the number...
I had the same problem with a model 6325-4. Worked fine for the first week. Then, tone dial with redial, directory, etc was too fast for system to register the number.
Called Vtech support. After a 15 hold, 5 minute explanation and tech listening to a reproduction of problem over the phone, she asked that I perform a complete system reset (I called via my cell).
I unplugged power from base first, then removed battery from all hand sets. Powered down for ~3 minutes (with tech waiting on line the entire time).
I powered up base first and then reconnected all handsets. Selected a handset at random and performed the same dial from directory test I had done just before power down. The thing worked again. Call went through just fine. Tried several other selections in directory with same positive results. Now, if the system just stays stable and working.
Hope this helps..
Dec 19, 2010 | Vtech CS62192 Cordless Phone
Hello, I have a Remo-Con Tone Dialer but I cannot remember How to use it ! What is it meant for ? Kind regards.
That's not a brand I remember, but it's most likely a tone generator from the days when you still found phones with rotary (pulse) dials. Before tone dialing was the standard, if you wanted to use any kind of service (banking, alternate long-distance phone carriers, etc.) from a rotary phone, you needed a dialer to generate the tones. You held it up to the mouthpiece on the handset and pressed the numbers on the dialer keypad. Some of these dialers also allowed you to store some phone numbers so you could quickly dial them if you were using a tone dialing service. As tone dialing has almost completely replaced pulse phones, you seldom see these devices except maybe at yard sales. They have no practical use any more.
Nov 23, 2010 | Cell Phones
L7780 cannot get dial tone on 2-line outlet. Are there any work arounds to this problem?
There is a problem either with the Line Interface Unit (LIU, also known as the fax/phone line connector) or the fax hardware, because the unit is having problems sending or receiving faxes. The unit may hang on "Initializing." This document explains how to troubleshoot the LIU and fax hardware. SOLUTION: Please perform the following: Front panel hangs on "Initializing"
  1. Pull the power cord connector from the back of the base unit to recover from the error.
  2. Unplug the LIU from the back of the ADF. It is located on the left side (facing it), and is where you plug in the telephone lines.
  3. Plug the power cord back in, power it up, and see if it hangs without the LIU inserted.
  4. If it does not hang without the LIU inserted, power the unit down, plug the LIU back in, and power it back up. If it hangs, the LIU is faulty.
  5. If it does hang without the LIU attached, unplug the ADF from the base and see if it hangs. If it does, the base is faulty.
Testing the LIU The primary test for the LIU is whether or not you get a dial tone. Sometimes, you need to re-seat the phone line several times to get a good connection. If after trying the things below, there is still no dial tone, or initialization hangs, the LIU may need to be replaced.
  1. Verify that the phone line is connected directly from the wall jack to the plug in the LIU that says "To Wall Jack."
  2. Verify that the LIU is plugged securely into the product. If it is not, there will be a message at power-up saying the LIU is not connected. If it is, the date and time will display.
  3. If the LIU was re-seated, cycle the power on the unit. The unit should display the date and time.
  4. Unplug all other accessories, like a telephone answering machine or modem. If the LIU appears to work fine after unplugging them, these accessories may be interfering.
  5. Place a document in the Automatic Document Feeder (ADF). The display will flash "Document Loaded."
  6. Press Start Fax to verify there is a dial tone. If so, try sending a fax.
  7. If there is not a dial tone, unplug the product from the wall jack, and plug in a regular telephone to verify there is a dial tone at the wall jack.
  8. If there is no dial tone on the telephone, the wall jack or phone line may be faulty
Oct 26, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
MY LEXMARK X125 STOPPED RECIEVING AND SENDING FAXES. IT HAS ITS OWN LINE NOT CONNECTED TO COMPUTER. ALSO MY SPEAKER DIAL TONE IS NOT WORKING. WHEN CHECKING MY DRPD WONT SET UP EITHER. THIS JUST HAPPENED 2...
Hello. If everything else is working, printing and copying, unplug the printer from the power source. Check the telephone line from your phone company by unplugging the fax machine from the wall jack where it is connected to. Plug a telephone device straight to that wall jack and check for a dial tone. If there's no dial tone, contact your phone company. If there is, plug the fax machine back to that wall jack. You can also try replacing the telephone cable with a another known working cable. Plug the printer back to the power source. Check again. Hope this helps.
Mar 23, 2010 | Lexmark X125 All-In-One InkJet Printer
Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
Have dial tone but can't dial out
I just spoke to RCA and they said to unplug power and phone line and take out batteries, wait 5 minutes and plug everything back in, mine now works.
Apr 23, 2009 | RCA ViSYS 2-Line Speakerphone
No dial tone
Try connecting a regular phone to that jack and see if the phone works. If not, try a different cable. If the phone doesn't work, then the jack is either dead or miss wired.
Jul 10, 2008 | HP Officejet 7210 All-In-One InkJet...
GE 21095GE2 Cordless Phone Logo
43 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Dudeman321
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
