Question about Panasonic Audio Players & Recorders
Code F61 pops up on my home theater sound system
It is a panasonic and I turn it up loud and the code will pop up on the screen on the 5 disk changer and then it will shutoff and there is also a plug on the back of the subwoffer that is all staticky and it is for the right front speakr
  • 691 Answers
Make sure you watch your polarity when hooking up speakers wires, the unit its very sensitive and will short out and cause that code to appear also. your power module is going out and need replacing. the parts it very hard difficult to find. your local electronics repairs has more access to get hard to find parts and they should be able to fix it for 120 to 150 bucks including parts and get warranty with that if you not electronic incline. the parts you may have to replace is power module IC-501 or power amp module, is going to be one of those. hope that help some
Posted on Jul 17, 2009
5 CD changer, model sa-ak600. What does code f61 indicate?
F61 means that the power amp has something wrong with it.
It could mean the IC501 has failed or that there is something wrong to the power supply to it.
The good news is the service manual is free online. You can get it by simply putting the model number into google and searching for the PDF of it.
Jan 02, 2016 | Panasonic Audio Players & Recorders
Error Code F61. Do I need a new fan?
it is fault of cooling system, and sound output error, if fan is disconnected or not running F61 comes on screen then nothing happends, power sound ic is the main cause of the device, not only cleaning works, may need to change the the power sound out put ic.
Nov 02, 2015 | Panasonic Sa-pt750 Multi 5 Dvd Player...
Error f61 on my panasonic sa-ak330
The f61 code is believed to be an amplifier circuit fault, but in reality it more often than not turns out to be a problem with a jammed up motor elsewhere(fan, cd changer motor, cassette motor). For me it was a jammed up cd changer. I simply disconnected the control for the changer and operation resumed as normal.
Mar 30, 2013 | Audio Players & Recorders
F61 Error message on screen. We can't get the player to even turn on.
Most likly needs an output or voltage IC. Could be other things like a bad fan or other componant. With Panasonic models F61 is a bad voltage code.
Feb 01, 2010 | Panasonic Home Theater System System
Panasonic home theatre keeps making a popping
try cleaning all your connections for your speakers with isopropyl alcohol and a q-tip, if no luck it could be an internal problem
Jan 09, 2010 | Panasonic Home Theater System System
Repeated F61 fault code on Panasonic Home cinema system Model: SC-HT990 Is it the fan in the sub woofer?
Hello
F 61 error means the failure of FAN
most probably dust in the fan made it to stop working so clean the dust and connect the fan to an external supply of 12v(using red and black wire) for 5 minutes and reconnect it to the unit otherwise replace the fan with new one.
Surely this will solve the problem.
Kind regards
Andrea
Dec 12, 2009 | Panasonic Home Theater System System
F61 code what do i do?
From Panasonic:
≥Check and correct the speaker cord connections.
If this does not fix the problem, there is a power supply problem. Consult the dealer.
Heres the link....see page 47
http://service.us.panasonic.com/OPERMANPDF/SAHT830V.PDF#page=45
Apr 19, 2009 | Panasonic SC-HT830V System
F61 Error then the system goes dead
The battery might have broken so you might want to try buying a new one or charge it up fully.
Dec 01, 2008 | Panasonic Home Theater System System
Error61 code
thats a "protect" mode..your audio outputs are stressed and overheating..will need to be replaced soon
Aug 26, 2008 | Panasonic sa-ht800V Home Theater Audio...
Panasonic Dvd Home Sound system SC-PT950 code f61
The F61 is the coded "protect mode" indication. The internal amp chip has failed. It sounds like this system should still be under warranty. Return it for warranty service. The amp chip will be replaced.
Sorry about hte delayed response. I was away in business for a few days.
Dan
Aug 03, 2008 | Panasonic Home Theater System System
231 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
