Check this reference guide...
2002 Hyundai Accent Car Lightbulb Size Guide
Low Beam Headlight Bulb Size: 9003/HB2
High Beam Headlamp Light Bulb Size: 9003/HB2
Parking Light Bulb Size: 2357A
Front Turn Signal Light Bulb Size: 2357A
Rear Turn Signal Light Bulb Size: 1156
Tail Light Bulb Size: 1157
Stop Light Bulb Size: 1157
High Mount Stop Light Bulb Size: 921
License Plate Light Bulb Size: 168
Back Up Light Bulb Size: 1156
Front Side Marker Light Bulb Size: 2357A
Rear Sidemarker Light Bulb Size: 168
Map Light Bulb Size: DE3175
Dome Light Bulb Size: DE3175
Step/Courtesy Light Bulb Size: DE3022
Trunk/Cargo Area Light Bulb Size: DE3022
From
Sylvania Lamp Replacement GuideLicense plate
168
168LL Long Life Upgrade: Up to twice the life of the standard lamp.I hope help you with this. Good luck (remember rated this help).
no separate fuses
i will check power at switch and thanks
could it be bad pcm?
I was just pulled over by a policeman because my both lamps in my license plate light were out. What would cause this and what's the easiest possible fix?
