Question about Quasar VHQ840 VHS VCR
How to enter code to control TV
After literally searching all morning online...I am desperate, lol! My Quasar VCR manual is lost VHQ830 (not 840), and I just need to refresh my mind on how to enter codes to control a TV! We just got a Samsung TV (used- 3 yr old), and I'd like to control it like I did our old TV with my Quasar VCR remote. I got some codes online to try...BUT my problem is I have no idea what buttons on the remote to press to enter them! Any help would be greatly appreciated!
THANK YOU for your time.
Re: how to enter code to control TV
I need the instructions for a tv remote samsung model bp5900125a to enter codes.
Posted on Jul 12, 2008
I cant find my quazar set up code 4 head vhq40hm?to put in to my one for all universal remote
Posted on Dec 11, 2007
0 characters
3 Points
Need the code to program my universal remote to my jvc tv the serial# to my remote is rc24922-c1122 model jc024
Do a code search method as follows.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Dec 26, 2014 | GE 24926 Glow Keys Universal Remote...
Download the manual here:<br><br><br>
May 17, 2010 | Quasar VHQ940 VHS VCR
I'm looking for the manual for a Mitsubishi VCR HSU447 with the remote control RM75502 so I can program my TV to it. Thanks
1.- Turn off your TV
2.- On the remote control, set the VCR/TV slide switch to TV position.
3.- While holding in SP/EP button, press the code button listed below that corresponds to the brand of your TV
4.- Press TV POWER on the remote control. Once your TV has turned on, your remote is set up to operate your brand
Brand of TV Brand Code Button
Mitsubishi 1,2,3
Fisher 0
Goldstar 2,9
Hitachi 8
Magnavox 4
NEC 2,9
Pioneer 6
Philips 4
Sanyo 0
Sharp 3,5
Toshiba 7
Zenith INPUT
I finnaly found my VCR Manual, and I'm glad to share this info with you, because I was looking for the manual all
over the web and FOUND NOTHING!. Bye!
Mar 15, 2009 | Mitsubishi VCRs
Remote control codes
RCA Universal Remote Control Programming Codes
The remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes:
  • TV-000
  • VCR-000
  • Cable Box-000
  • AUX is programmed with VCR code 037
Programming a Device using Code Search:
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists:
Find codes for device and brand below.
  1. Press and "HOLD" CODE SEARCH.
  2. Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
  3. Enter the three digit code from the TV, VCR or Cable Box code lists.
  5. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
RCA Codes for VCR
Nov 04, 2008 | RCA VR557 VHS VCR
hold down the stop/eject button for 7 seconds this will lock and unlock the feature
here you can find the manual for your vcr
Oct 09, 2008 | Quasar VHQ451 VCR
Manual for Quasar VHQ-940
I need to find out how to record on theVHQ940. I bought a used VHQ940 without a manual or remote. My son used a universal remote to turn it on to my Magnavox TV, but don't know how to program it to record. I need a manual.
Mar 24, 2008 | Quasar VHQ940 VHS VCR
Lost manual to program remote for Toshiba M-68C VCR
-Push "TV" and release.
-hold prog and enter the two digit code. (Try 10 for a phillips) release the prog button and see if it worked.
If not try experimenting with other two digit codes as I don't think there is an auto search for this remote. At worst it'll take 99 attemts to work ;-)
Feb 03, 2008 | Philips VR330 VHS VCR
I need remote control code
Order a replacement owners manual for the unit or whatever unit you are trying to make work with this one from one of the many service manual sources such as the ones displayed on this site.
Dec 25, 2007 | Quasar VHQ840 VHS VCR
Quasar VHQ41M
I am not conversant with VCRs sold in the United states, but - a VCR is a VCR is a VCR. So, can i suggest an alternate solution to your problem? Why not use the AV out sockets of your VCR and hook them to the AV IN sockets of your TV? In this manner, you you also get a better image. And of course, you feed In the signal source (Antenna, cable Box, etc) directly to the TV, and use your remote to switch to AV mode whenever you desire to watch movies or Tape.
Aug 01, 2007 | Quasar VHQ401 VHS VCR
No remote - need code, and can only get one channel
sorry bad link heres the right one search the page for a manual under product details 590kb pdf
Apr 02, 2007 | RCA VR552 VHS VCR
VCRs Logo
876 people viewed this question
Top Quasar VCRs Experts
alexander woolfolk
alexander woolfolk
Josh Whitehead
Josh Whitehead
Are you a Quasar VCR Expert? Answer questions, earn points and help others
