Question about Garmin Nuvi 255 GPS Receiver
My 255 wont come on - Garmin Nuvi 255 GPS Receiver
  • SHARCNET-USA
    SHARCNET-USA May 11, 2010
    Is the unit fully charged? Have you tried moving the on/off switch to the left and holding it for at least 30 seconds? - Jim SHARCNET-USA
I had the same issue today with my Garmin 255. I found the answer on another site. The reset button is a tiny little tab that is hidden under the serial sticker at the bottom of the unit. Pressing down on the tab with a paper clip had my Garmin up and running again. I will keep a paper clip in the carrying case pocket. I hope this helps.
Posted on Aug 02, 2009
Garmin 255 wont do anything turn it on wont leave main screen
The best thing to do here to point your browser at Garmin's site - simply click:
http://www8.garmin.com/products/webupdater/howtoinstall.jsp
Follow the 2 steps of instructions on the page to update the firmware.
If you still have trouble, contact Garmin Support to review your options.
I hope this helps & good luck!
Oct 20, 2011 | Garmin Nuvi 255 Car GPS Receiver
Tip
How to reset nokia mobiles life timer to ''0''
Nokia life timer is a counter that keeps track of the Total call time of your phone. It will show how much the phone has been used, and it?s the best thing to check if you?re planning to buy a used Nokia Mobile.
To see the Total Call Time or the life timer counter, On the standby screen type the following code *#92702689# (Easy way to remember this is ? *#war0anty#). And it will pop up a message that shows the life timer in hours and minutes.
Here is a detailed procedure to make this life timer zero.
REQUIREMENTS:
The following files are required to reset the life timer:
  1. Nemesis service suite link: Download from Here
  2. lifetimer.pm file: Download Here
PROCEDURE:
1. Download and Extract the lifetimer.pm file, and Download Nemesis Service Suite.
2. Install Nemesis Service Suite on your Computer, It won?t take much time.(select the first option)
3. Install Nokia Cable Drivers (No need to install, if you have Nokia PC Suite already installed)
4. Connect The Phone in ?PC Suite? Mode to the PC
5. Open Nemesis Service Software
6. Click on ?Scan for new Device? Button on Top right Corner
7. It Will take a few seconds to scan, and it will load up the software interface after communicating with the Phone.
8. Click the ?Phone Info? Button.
9. On the Bottom, Select and open the ?Permanent Memory? Tab, which is next to the Fbus info.
10. Click the ?Write? button on Below right, and open the Extracted lifetimer.pm file on your PC.
11. After the lifetimer.pm file is opened , it will immediately start writing it to the Phone?s EEPROM Area.
12. The Procedure will end when the progress bar reaches 20%. This is normal , and on the bottom right side, it will display its done.
13. Unplug the Phone, and Restart it.
14. After boot up, Check the life timer .
Note: This method has been tested on following devices: Nokia 6630, 6670, 6680, 5500 sport, 5700XM, 6110 Navigator, 6120 Classic, N70, N72, N73,N76, E50, E51, E61i, E65, N80, N91, N95, N95 8GB, 5800XM Mobile devices. If you want to try it on other S60v3 or S60v5 mobiles, do it at your own risk.
Caution:
  • Power Failure During Writing will cause damage to the Phone, And there is a chance that it might brick the phone as well.
  • Loose, worn out Data Cables Might fail the Writing process, and there are chances of damage to the EEPROM area of the phone.
  • Do not attempt this with phones that are not included in the confirmed list.
By:- Mohammed Abdulhadi
on Jun 21, 2010 | Cell Phones
Tip
How to setup your EPSON FAX
1. Connect the supplied phone cord with one end to a phone jack and the other end to the LINE port of the unit. Make sure that the phone jack has a dial tone.
Note: Nowadays a lot of people are using a VOIP Service, keep in mind that the FAX was invented to work on an analog phone system (yeah the regular phone) and this new phone system might result in FAX transmission failures.
2. Default FAX settings works fine. The only time you need to configure it is if you have a phone or an answering machine connected to the unit.
3. To test if you can receive fax, go to http://www.faxzero.com (a free fax service) and send yourself a fax message.
4. To test if you can send fax, a friend's fax number is recommended.
on Nov 06, 2008 | Epson Stylus Multifunction Printer/...
I need to know if there is a program that can decode ANSI code to readable english Here is a sample of the code úÿÿÿC   x x ...
yes here is the link its from Microsoft http://www.microsoft.com/downloads/en/details.aspx?familyid=048DC840-14E1-467D-8DCA-19D2A8FD7485&displaylang=en         hope this helps and please vote
Nov 29, 2010 | Computers & Internet
How can i traslate this; i have a file with similar information from my date book ej Pague gym ÿÿÿÿ Qß ...
it's in spanish. it means, literaly, Pay gym ÿÿÿÿ eg ÿÿÿ QA C ~ Ă Ă Ă ˛ C ÿÿÿÿ Australia Day
Jul 02, 2010 | Palm Zire 71 Handheld
The 255 wont do anything when charging. How can
when it is charging u just slide the on/off switch to the left, it is spring loaded, hold to the far left for a second then release, if the unit doesn't turn on it is defective.
May 04, 2010 | Garmin Nuvi 255 GPS Receiver
My 255 wont come on,per Jim SHARCNET-USA I tried moving the on/off switch to the left and holding it for at least 30 seconds and it still wont come on,any other suggestions?
Peel off the serial code sticker on the bottom. There is a tiny tab, pressing it in with a paper clip will reset your 255 and it will be good to go. I hope this helps.
Jul 19, 2009 | Garmin Nuvi 255 GPS Receiver
No picture - 65535 shows on screen
My 42" Dynex just did the same thing. 65535 NO SIGNAL.
The channel label for this said "ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ"
I went to menu... Channels .... Set for Cable TV... Scan Channels.
It rescanned. It took twice as long as normal to scan.
After the scan completed it worked fine except of one thing.
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ stuck on the screen.
I shut the TV off, then things returned to normal.
Hope this helps.
Notes:
This TV is only 6 weeks old.
Cable hook up.
It is -plugged into a brand new UPS power supply.
I used the sleep timer to shut off TV. The 65535 problem occured the next time the TV was powered up.
Nov 22, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
Garmin Nuvi 255 GPS Receiver Logo
200 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
