Question about Dishwashers
Diswasher My dishwasher leaks only after the dry cycle finshes can you tell me why
  • 76 Answers
The chances are its leaking all the way through the cycle although you are unable to see it as it has a solid bottom. If you tip it back slightly and water come out then that will prove it.
Posted on Nov 18, 2007
Run a service test for kitchenaid dishwasher
Did you check behind the toe-kick panel for the tech data sheet? Assuming that you have checked and that it is missing, there here is the "secret keystrokes" that will make most Whirlpool/ KitchenAid/Kenmore/Maytag diswashers enter the diagnostic cycle:
Heated Dry - Normal - Heated Dry - Normal; or
High Temp - Air Dry - High Temp - Air Dry; or
Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry; or
High Temp Wash, Heated Dry, High Temp Wash, Heated Dry.
Note: On some of the newer Whirlpool, Kenmore, KitchenAid dishwashers, you start the diagnostic cycle by rapidly pressing the 3 left-most keys in the following sequence: 1 2 3, 1 2 3, 1 2 3.
Oct 18, 2014 | KitchenAid KUDS30IXSS Builtin Dishwasher
My diswasher won't dry my dishes. It leaves them
if no rinse agent is present it doesnt matter how hot the water gets they will still not dry check unit make sure it is full. rinse agent is only to aid the drying process the machine will wash happily without it but not dry.
Feb 15, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Electrolux dishwasher error code 01
I found the error codes in the owners manual, (01) is a leak. I called customer service (no wait time) and they said there is pan under the tub that will contain and detect water if it leaks. They said I could wait for it to dry out. They said there could be a hose that became loose or had a pin hole in it. After I hung up with customer service I did my own problem solving. The diswasher washing cycle was just started. Then then the door was opened 5 to 6 times to add more utensils and dishes while the the machine was running. Then the error code came on. this was the first time this had happened. I beleive water seeped doen through the hinges and the seal into the pan. I unpluged the dishwasher and disconnected the water line and pulled it from under the counter. Then lifted the diswasher onto 4 inch blocks of wood placed under the feet. This made it easier to access the pan. It had 2 screws inthe front and 1 in the rear with 3 clips. I removed the pan and dried it. Inspected the hoses under the unit and determined none of them had appeared to be leaking. I positioned a fan to blow under the unit to speed up the dry time, about 1/2 an hour. Put everything back together and ran a high pressure hot water cycle and found no leakes, so far.
Jan 11, 2010 | Electrolux Dishwashers
The clean light is blinking diswasher won't start
Push these buttons in this order High temp wash > Heated dry>High temp wash >Heated dry all the lights will come on and this will reset the board and run it through a short test cycle but more than likely it will come up again,It's a failure in the heating cycle either the heater itself or the turbidity sensor which sits mounted up into the tub right behind the drain pump...hope this helps
Sep 13, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Kud101 diswasher heater element
The dishwasher will heat the water to a temp of aprox 140deg if the heater is not working then the dishwasher will not shut off because it has to heat the water to a point where a thermostat will close during the heating time the dishwasher time stops advancing, also heater is used to heat the air for dry cycle
Sep 07, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Ge dishwasher not drying
1 make sure heated dry is on.
2 run your cycle and when it says drying open the dishwasher. see if it has steam coming out.
3 give me your whole model number.
4. if heater is not turning on then you may have one of three issues.
1. Bad door switch
2. Wire off element or bad thermistat
3. No power going through the control. to the heating circuit.
Jan 07, 2009 | GE ADW1100N Built-in Dishwasher
My Kenmore diswasher gets stuck between the quick rinse and drying cycle
I am having the same issue as described above. I think it is either the timer, thermostat (temp assure), or thermostat (temp boost) that needs replacing. The dial gets stucks in both the wash temp boost cycle and rinse temp boost cycle. However, I don't have a picture of the temp assure or boost part. Does anyone know how to fix this? Thanks. -Bill
Aug 31, 2006 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwashers Logo
89 people viewed this question
Top Dishwashers Experts
