Question about Vizio P2 42 in. HD-Ready Plasma Television
I've had my vizio 5o in. for about 1.5 years and it worked fine. All of a sudden I turned it on and the no signal sign appears on the screen. In AV1 and AV2 it seems the tv is not recognizing the inputs all of a sudden. Im getting the no signal sign from my direct tv box and from my dvd set.
  • 2,359 Answers
Please email me the model number. I can help you better if I have all the information.
Some Vizio has front and side signal input.
Try to plug in one or you equipment into the front or side jack(s) and use the remote to flip though the source selector.
I also need to know do you get sound on your NORMAL setup.
If everything goes well on the front and side just then it's a loss connection on the rear INTERNAL connection.
If you get the same result on front side jack then it's V board or backlight is out.
Posted on Jul 17, 2009
Benq FP737s - Not working suddenly - Black screen
Most like just burned out and needs repaired or replaced.
Nov 11, 2007 | BenQ FP737S-D 17" LCD Monitor
46in Vizio LCD HDTV distorted black picture when tv is turned on
Hi There are three things that can cause this problem. Your lcd screen, t-con board or the signal board. Most likelly in your case since you say it's only half the screen it's going to be your t-con board. You can try removing it and cleaning all the contacts and replacing it see if that helps. If that doesn't help then replace it. If that does not solve it then it's going to be your screen.
You can get parts at www.interliquidparts.com
Nov 28, 2011 | Vizio VW46LFHDTV10A 46 in. LCD TV
The tv had blue screen briefly showing "no signal" then turns off. ... and I am getting the same blue screen-no signal.
If your television is displaying a blue screen or no signal message and then turning off, your TV may be at an inactive input. Here's how you can get back to watching your TV:
1. Powering on your TV and press the INPUT button on the VIZIO remote control repeatedly until a picture re-appears.
2. If this does not work, try again but press the button slower this time.
I got this off the vizio website.
Feb 21, 2010 | Vizio GV42L 42 in. LCD Television
Have a Vizio VX37L that when it is turned the
HERE'S THE FIX: I just went through this with my Vizio VX37L. TV is stuck in RGB input. This is the fix.... TV is stuck in RGB input.
(option 1) Power on TV, and press the INPUT button repeatedly and rapidly until you can change to a different input, such as AV.
If that doesn't work, try:
(option 2) With the TV off, press and hold the INPUT button on the side of the TV for about 5 seconds. The TV should power on and the input list will appear. The TV will no longer be locked, and the INPUT button should function properly after that.
Option 2 worked for me!
Jan 24, 2010 | Vizio VX37L Television
My Vizio L37 keeps turning off!
change the main board will fix this problem
May 16, 2009 | Vizio L37 Television
My Vizio 32" Flat Screen suddenly turned blue and "no Signal"
Check the cable connector. If it is OK then the turner has gone bad. Replace main board will fix it.
Feb 06, 2009 | Vizio L32 32 in. LCD HDTV
Vizio P50HDTV10A 50 in. HDTV Plasma HDTV Tuner out
The HDTV tuner is out. Analog tuner, and video inputs work fine.
TV Model P50HDTV10A
Screen Size 50 in.
TV Manufactured Date Jan 1, 2007
Part Type MAIN UNIT
Alternate Part Type SIGNAL BOARD
Part Number 3850-0042-0150(3A)
Alternate Part Number 0171-2272-2163
Jan 08, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
42 in lcd vizio "no signal"
if the TV have a no signal sign which means most of the important part is missing. Try checking your connections. The best way is to hook up a dvd player using AV input (the yellow, red and white). make sure that you turn the device on and whatever input you connected the device to is selected. if your TV is a P50HDM model, the TV will shut itself off after a short period without and input connected.
Sep 08, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio P2 42 in. HD-Ready Plasma Television Logo
91 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
