All blue screen no pix no sound Menu comes up but is now missing the tv setup line.....
  • 19,396 Answers
Unplug the power cable and let the tv rest, so to drain power.
This basic reset can fix minor problems.
Try first unplugging for ten minutes, then eventually leave it few hours.
Test also all cables at the back, possibly do first test on tv restarting it with no device attached.
If you still get all blue screen after that then there is a fault.
The lamp or crts, and ballast board are to exclude, the PSU is also unlikely the problem, the TV would have detected the fault and started protect mode.
It is probably a fault concerning main digital control board, or depending on model, DMD board or light engine.
If the TV does not restart and stays in standby, that is because the fault had been detected, and TV is on protect mode.
In that case you may need a technician to test and replace parts.
Try unplugging the TV for a while first.
G.
Posted on Jul 17, 2009
Rca 32" lcd tv.vertical lines on entire screen,no pix.
LG LCD TV REPAIR - NO PICTURE SCREEN FIX REVIEW ...
? 5:29
www.youtube.com/watch?v=PWoz_-3OHIMJan 25, 2013 - Uploaded by Tampatec I have a LG 42PM4700-UB plasma tv that just went black. The red power .... I have a RCA 32 inch it has no sound or picture !Just a light blue ...
Sep 09, 2015 | RCA L32HD31 32 in. LCD HDTV
Removed TV from cable,connected a antenna.Changed setting to antenna.All I get is a Blue screen like no signal is coming through.Connections are good. It seems like a setting is missing. Help
Hi, is the tv set to analogue broadcast, should it not be set to digital. I have a Grundig that does the same thing on analogue.If your tv is and/digi this might be the issue.
Jun 16, 2015 | Apex Digital Apex At2002 Color Tvs
Flickers after 5min of use. Perfect sound, turns on fine and excellent picture quality when in blue screen menu mode. Why?
This intermittent problem is very difficult to rectify. Just contact the authorised service center for Hitachi at your town. The work is really a skilled one, that a user cannot do it with ease.
Jul 13, 2012 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
My screen is red blue and green lines one on top of the other you can still see the shows they just look funny
sounds like the auto convergence feature is missing from the setup menu. Thats usually the case with the ITC222 series. You can get the repair by that same name from www.tvrepairworld.com
Jun 12, 2011 | RCA HD52W56 52" Rear Projection HDTV
A red blue and green line comes across both the top and bottom of my tv . alignment is also off
Sounds like the classic convergence option symptom. If you press menu and scroll to the set up screen see if the auto convergence feature is still listed. If its no longer there the rca repair kit called ITC222 and ITC222A convergence option missing repair kit from www.tvrepairworld.com will usually repair that problem. The kit contains the parts and the CD with repair instructions.
Aug 03, 2010 | RCA D52W23 52" HDTV CRT TV
Redness
prob. pix tubes or fluid needs changing take off screen and look into tubes while set is running see if pix is present in green and blue tubes if it looks cloudy fluid needs changing if its dark with a pix you can try to adj. green and blue g2 if not you will need green and blue pix tube
Jul 23, 2009 | Hitachi 51F59 51" HDTV Projection...
Mitsubishi cs-26ex1
This sound like the standard Mitshubisi PIP board problem. There are two ways to adress this one is to repair the board, this involves replacing surface mounted capacitor and is about %80.00 sucsessful. The other is to simply bypass this board. this option is the way to go, it involves installing two capacitor on the main board and fixes the main pix but kills the Picture in Picture (PIP) I will send off both these repairs to your E-mail
Feb 13, 2008 | Proton MM2701VT 27" TV
I cant get back to s-video mode.....:(
To change from p-scan back to i-scan with no video picture, mu1 model: 1.turn dvd on with no disc, wait 10 sec. 2.press "setup" 3.press "down arrow"(selects audio/video) 4.press "enter" (selects audio/video menu) 5.press "down arrow" 4 times (selects scan mode) 6.press "right arrow" (selects scan menu) 7.press "up arrow" (selects interlace mode) 8.press "enter" (should see picture) Or find a tv with p-scan capability
Sep 23, 2006 | iLO DVDR05 DVD Recorder
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
