Question about Craftsman 19.2V C3 DRILL/DRIVER
My Craftsman 19.2 drill's adjustable torque clutch want allow drilling in forward gear.
    President:
  • 1,273 Answers
Try with the drill chuck torque setting set to max. If no joy on that one, work tha low/high speed switch several times. If no luck there, you may need to open the drill and check for a loose linkage, or that something has slipped out of place. It's not difficult.
Regards, --W/D--
Posted on Jul 18, 2009
Drill disengages when spinning
Could be several things. If it is a reversible drill, the selector switch could be stuck between forward and reverse. If it is a variable torque (popular on battery drills) the torque setting could be real low. Also, I've had this problem with the gears inside the drill wear out. No easy fix for that. If it is an inexpensive drill it would be cheaper to replace it than to have it repaired.
Feb 18, 2016 | Drills
Gears slipping
Many of these have a torque clutch that is used in screwdriver mode that will slip when a certain torque is reached as set by the ring around the chuck area. If you want it to not slip, usually you set it on a symbol that looks like a twist drill.
Feb 01, 2012 | Hitachi DS18DFL 18V 1.5Ah Lithium Ion...
The clutch is slipping how do i fix
If its clutching out in drill mode the clutch pin is worn. This part is 635718-00 its only a couple bucks. not hard to repair either bout 5 min.
Sep 07, 2011 | Dewalt DC988kar XRP 3 - speed 1/2" 18v...
Dewalt D21810KS-XE is described as having a clutch. Is that clutch adjustable torque?
Yes, that would be to adjust the screw driving torque etc.
Feb 18, 2011 | Dewalt Drills
I have a 6337D which has 16 position torque settings. I do not have any torque measurement device. This said, what does each setting represent in terms of a torque value? Thanks for your help.
Good luck finding any actual documentation on this one. The only thing I could think of would be to put a rag in a vise and clamp the drill in the vise after chucking up a bolt. Set the wrench for your desired torque and adjust the clutch on the drill until the wrench indicates the clutch torque value is what you desire...just a thought.
Take care.
Dec 09, 2010 | Makita 6337DWDE Cordless Drill
Adj.clutch
those numbers have nothing to do with speed.
They are torque setting for the drill, so you don't overdrive the screw in....the smaller the number, the less torque.
Plz don't take you drill apart
Sep 26, 2009 | Drills
How is a driver different from a drill? What
Hello, W/D here.
A very good question......A drill holds a bit and rotates it at a given speed. This speed can be variable, allowing the speed of the drill bit to be better matched to the material being drilled. The output from the drill motor goes directly to the chuck, and the power is directly applied to the drill bit. Some drills can generate a tremendous amount of direct torque, due to the nature of their gearing. Most of the better drills have planetary gears in them.
A driver rotates like a drill, but is designed to apply torque to a driving bit, and cause a fastener to be placed by the driver. The main difference between a drill and a driver is that a driver has an adjustable clutch, allowing the amount of torque being applied to a fitting to be preset. A good example of this would be for driving wood screws. You would dial in the torque setting that you want the driver to quit driving the screw. You don't want to drive the screw to China, you want to drive it flush. A maximum torque setting "locks" the clutch, and the fitting will be driven as far as it can go (This is about as close to being called a drill as a driver will ever get). A clutch setting midway might be just right for driving the same fitting into oak, and a setting at less than that might be just right for pine. The torque clutch effectively sets a kick out torque for the driver. When the torque applied matches the torque set on the driver, the clutch "slips", and no further driving action can occur.
Most modern battery powered drills incorporate a torque clutch between the motor and the chuck so that the tool can be operated as a drill (with the torque setting at "max") or as a driver (with the torque setting at less than max) some electric tools are configured as both, but usually they are different. For the money, a good battery powered drill/driver with a clutch offers more versatility, in my opinion.
Best regards, --W/D--
Aug 19, 2009 | Dewalt Home Fencing
Clutch slipping
Try Rotating the bit holder head while holding torque adjuster or visa versa and turn the torque off in increments,test and adjust as desired.
Please rate Thanks
Mar 28, 2009 | Drills
Drill Turque
Torque, which is measured in foot-pounds, is the drill's maximum amount of turning force. Some drills have an adjustable clutch with different torque settings for different applications.
Aug 27, 2008 | kawasaki 19.2V 4 Piece Cordless Tool Kit
Craftsman 19.2V C3 DRILL/DRIVER Logo
962 people viewed this question
Top Craftsman Drills Experts
Gareth Cockram
Gareth Cockram
John Trevino
Are you a Craftsman Drill Expert? Answer questions, earn points and help others
