Hello James Waligora,
I've had a lot more trouble trying to decipher what we are talking about "rv" jacks ...
and since you provided ABSOLUTELY NO CLUE about the
"TV" ... I'm just going to BULLDOZE ahead with
my OWN conclusions... "
TYPICALLY" will be used a lot.
ASTAK 2.4GHz cameras are a pretty straight forward
set-up ... with the receiver POSITIONING being your only challenge... Two REGULAR Twin LEAD RCA jack ended
cords should be sufficient... LEAD LENGTH is for your ease of adjusting for best reception.
If you already have ECHO, ALEXA... x10 devices (etc.) you
can TYPICALLY expect interference
The yellow is all you need for "video" the OTHER
you can stick in the red or white audio input of your "TV"
for sound (red
typically means right side
(Left being what's left... again
typically white)
STAY AWAY from the
RED, BLUE GREEN inputs...
While they are
VIDEO... they are called
"composite"
and
ARE NOT COMPATIBLE with your single lead
Yellow corded RCA PLUG...!!
** Don't even try:
Not compatible... not.
TYPICALLY 2.4 GHz is low power straight line
(easily interrupted radio signal that is over used)...
ASTAK instructions:
(ah... ) they do come with manuals... but the FIRST SITE
I attempted to access for you set off EVERY internet security protection I have...
EXERCISE CAUTION THERE...!!!
Audio Video Cables ShowMeCables com
Astak 811T Wireless DIY Mini Spy Surveillance Hidden Pinhole Color Video...
