Question about Garden
Chain Brake won't unlock - Garden
  • 154 Answers
Remove cover and clean out
Posted on Aug 01, 2009
  • Dennis Sharp Aug 01, 2009
    remove cover and clean out
Model 137. How do I assemble the brake spring?
Husqvarna Chain Brake - YouTube
? 7:13
https://www.youtube.com/watch?v=gK7eKakMCz8
Feb 13, 2011 - Uploaded by thoughtfulace
... brake assembly and install the spring in the cover of ahusqvarna saw. ... Next time I will try to remember to disengage the brake first. .... How to Remove a Chainsaw Clutch Cover and Reset the Chain ... Restricted Mode: Off.
husqvarna chain brake is stuck. easy fix - YouTube
? 6:31
https://www.youtube.com/watch?v=usP5XaXO7-8
Dec 19, 2012 - Uploaded by Plotnikoff Nate
How to fix your chain brake from being stuck locked to unlocked the easy way. ... BTW, I will NEVER sharpen a chainsaw again. This new chain ...
How to assemble the brake spring on a 137 husqvarna ...
www.fixya.com/.../t26010777-assemble_brake_spring_137_husqvarna
Dec 16, 2015 | Husqvarna Garden
I put the bar & chain on, the three hole line up easily but how do i get the brake back on the clutch?
The proper sequence to installing the chain should be to first ensure the brake is in the 'unlocked' position then loosen the chain adjustment screw, slip the chain over the back of the sprocket, align the chain with the bar, slip the bar onto the bar mounting studs ensuring the adjustment pin slips into the appropriate hole in the bar. Then slip the outer chain cover over the bar studs, elevate the front end of the bar and tighten the bar mounting nuts to 'snug'. Adjust the chain tension to the desired setting ensuring the front of the guide bar remains elevated, then tighten the nuts to secure the bar.
Remember to unlock the brake BEFORE removing the bar and chain because it is so much easier to unlock it mounted on the saw if yours is the design that comes off with the cover. If yours stays on the block of the saw and the blade is removed you have to secure the saw on the workbench or on the ground and unlock the brake just like you would with the bar installed.
Keeping the front of the bar elevated during assembly and adjustment of the chain will keep the chain tension correct for a much longer period. I hope this helps.
Mar 03, 2015 | Garden
Chainsaw chain sprocket won,t turn
this seems to be a chain brake that's applied , try turning off chain brake by pulling back on hand guard till a click is felt
some folks moving up from an older saw to a more modern saw are not so familiar with chain brakes and don't understand them and how they work
May 25, 2014 | Ryobi Factory Reconditioned 18" 40cc...
I have a Husqvara 550 chainsaw. After chain popped and I put it back on, the chain won't move. It's on the gear and everything. Is there a brake or something preventing the chain from mov
There will be a chain brake, grab the brake handle and pull it firmly back to the top handle, this should didd engage the brake, if the chain has de railed the drive lonks will have burs on them which will make it tight in the bar, you need to file all these burs off.
May 05, 2012 | Husqvarna Garden
Cover won't go on.round metal strip won't fit on round spindle that turns chain.E-235.Do I need the break bar?It doesn't line up either. DB
Sounds like the chain brake was set when you took the cover off. You need to disengage the chain brake (release it) so the round spindle will fit inside. Look for the two parts (one on cover, one on saw) that match up at the base of the chain brake. You won't be able to fit the whole cover on, but if you can line up where the metal triangular gear engages the chain brake, you can give it a snap to disengage it. What I have done in the past is to line up the two parts and push down on the top of the cover where they meet so as much of the gear is in the chain brake release as possible ( I put a knee on it ) and then give a snap to release it. Be careful though, because the cover part is plastic and you don't want to strip that part of the chain brake assembly. Good luck.
Sep 04, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I can't unlock the blade.
Do you mean the chain won't move, or you can't get the blade off? The chain brake must be off to allow the chain to move. The chain brake handle has a housing that engages a gear attached to the chain brake inside the cover where the blade is attached. The brake must be off to remove the cover (usually held on by two nuts). The blade tension screw should be loosened to allow the blade to be removed, then retightened when replacing the blade. Tightening it pushes the blade out from the saw, so if it is tight, you won't be able to remove the blade. Hope this helps.
Aug 27, 2011 | Garden
Chain won't move when motor running
Sounds like the chain brake is on, grab the hand guard and pull it firmly back to the top handle to release the brake.
Aug 17, 2011 | Poulan P3416 16Inch 34cc 2Cycle Gas...
Chain won't move but when i take chain off yhe clutch will
The chain brake is activated, pull the hand guard fully back to the top handle until you hear the click of the brake loading
Jun 09, 2011 | Husqvarna ChainSaw 18 in Bar 32 HP Model...
Trying to fit bar and chain on a new 445.can not replace clutch cover after following instructions closely.it seems brake is on. WOULD REALLY APPRECIATE HELP. THANKS.
You'll definitely have to unlock the chain brake to get the cover back on. You should be able to unlock it by pushing the chain brake handle forward, toward the bar and chain when mounted on the saw.
Oct 20, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Garden Logo
221 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
