How to open a LG LW60 express?
How to open up the case of a LG LW60 express?
The Power connector needs replacing, how to get to it?
Can I change the graphics card on a Compaq Presario CQ71-402sa Laptop?
The use of multiple video cards is possible thanks to SLI by Nvidia and CrossfireX by ATI, two proprietary technologies created for that purpose.
The technology has matured and is now a viable option for anyone looking to build a computer capable of running the most graphically intense games at extremely high resolutions.
Both SLI and CrossfireX have requirements that must be met to use two video cards.
Depending on your motherboard, some computers may be compatible with dual video cards and some may not.
When purchasing a new video card, check for compatibility issues. In some cases, purchasing two of the same video card can ensure compatibility.
Open the computer case by unscrewing the screws at the rear of it and sliding or swinging the case door open. Find the PCI Express slots.
They are located directly below the processor. If no video cards are already installed, it might be necessary to move other PCI cards, power leads and other case clutter out of the way to fully reveal the PCI slots.
It will also be necessary to remove the PCI slot blanking plates that keep the back of the case sealed when no card is installed.
They are secured by one screw and will slide or swing out once that screw is removed.
Line up the long, thin connectors on each card with the PCI Express slot and firmly press down on the card. If the card is properly inserted there will be little play in it.
The PCI Express slots will also have a snap that secures the video cards.
This snap would have to be opened to remove any prior PCI Express card.
It should at this point be fully closed. Secure the cards using the blanking plate screw removed in step 1.
Link the cards together using the proper SLI or CrossfireX connection.
Both systems typically use an internal bridge that comes packaged with the video cards.
This bridge connects to the outside edge of each card inside the case, linking them together. However, some older versions of SLI and Crossfire use different methods of connecting.
Refer to the user manual for more details about these connection methods.
Connect the video cards to the power supply using the appropriate PCI Express power connector, which is a small black connector with six pins.
If your power supply does not have enough PCI Express power connectors to connect to both video cards, use Molex-to-PCI Express adapters instead.
A Molex connector is white or black and has four pins.
The adapter has two Molex connectors on one end and a PCI Express connector on the opposite end, thus allowing the Molex connectors to power a video card.
Activate the dual card setup on the motherboard, if required.
Motherboards have various ways of handling this, and not all of them require it.
Those that do require it usually need a jumper to be re-positioned or a DIP switch to be activated.
The manual of the motherboard will detail the specific steps required to complete this process.
Install the drivers for the video cards using either the installation disc supplied with them or the installer available for download from the websites of Nvidia and ATI.
Run the installer and follow the onscreen instructions.
The process will probably require multiple reboots.
Once the installation is complete, open the driver software.
Nvidia's is called nForce and ATI's is called the Catalyst Control Center.
Enable the dual card setup by activating the option in the driver software.
This is done by clicking on a check box in the software under the CrossfireX or SLI menu in the driver software. The computer's screen will likely flash or blink while the setting is activated.
hope this helps
Sep 29, 2012 | Compaq Presario CQ71 Series Laptop Charger...
Keyboard not working. spilt coffee. how do i fix? LG LW60
Take it to an authorised service centre dont try over it by your self. Keyboard may require replacement.
Sep 15, 2011 | LG Computers & Internet
Need help finding a lg lw60 audio driver for windows 7
Hi
You could try this link www.realtek.com they do AC.97 and HD Audio drivers
Jan 25, 2011 | LG Computers & Internet
Gtx+ shorts out powersupply
1.Power supply doesn't have enough Amps for the 12 volt voltage rail.
2.Power supply doesn't have the required power cables/connectors required.
You NEED TWO 6-pin PCI Express power cables.
If you use just one, you will burn up the connectors down in the PCI Express x16 slot, and the power cable connection on the GTX card, and/or fry the power supply.
3.Cheap power supply that came in a deal when buying a computer case. Cheap case? Cheap power supply.
Aug 16, 2009 | Pine Technology XFX GeForce 9800 GTX+...
LG Instant On Player will not Install
Hi I am Mehdi
I have LG LW60, I know How it make Better:
This is a download link for the instant on cd http://rapidshare.com/files/13902078...er-II.iso.html
Instant on needs to be installed onto unpartitioned disk space.
Preferably before the Operating System is installed.
Another way to do it is to create some unpartitioned space on your HDD (shrink your partition) with Partition Magic
400mb of unpartitioned space is enough to install InstantOn.
To install, boot your computer from the cd and follow the prompts.
Good Luck,
If you have another question Mail me :
Mehdi10_2@yahoo.com
Take care
Dec 23, 2008 | Computers & Internet
Random keyboard failure
hi,
contact your LG technical support, the keyboard might just require just reseating of the keyboard cable on the mother board.
Further queries are welcome
Sep 26, 2008 | LG X-Note LM50 Notebook
Fit power supply plug into lg lw60 laptop
buy the universal power supply for your laptop
May 07, 2008 | Computers & Internet
Computers & Internet Logo
984 people viewed this question
David Payne
David Payne
