Question about SanDisk Sansa e260 MP3 Player
Sansa e260 When I plug in my sansa e260 theComputer says found new hardware but will not complete instalation then I tried tofind out what was wrong it says "Code 10 may not work properly".When I go to device manager to locate the mtp device there is a yellowcircle with an ! in it. Also, when I get to that screen the on the top is anicon of a computer with "YOUR-YN89P66B" beside it. The drop down menuappears and disapears repeatedly without stopping. I have tried to find a new driver on my computer but it says the one I have is OK ,but and this is when I get the code 10 message.
  • rob_7_lax Jan 18, 2009
    i have the same problem and i have windows vista and windows media player 11
  • 626 Answers
Code 10 means it cannot find the correct Driver for the device.
You PC needs to have XP / SP 2 and Windows Media Player 10 or higher.
If you do not have these programs then the driver is not on your PC.
Update these components and try connecting the device again.
Best of Luck.
Posted on Nov 18, 2007
I connect sansae260 to PC, Nothing apears on Sansa's Screen
You may need to now reset the player, that may have been a bit much for it.
To reset your Sansa Mp3 player.
  1. Slide and hold the Power switch up for approximately 20 seconds.
  2. Release the Power switch.
  3. To turn the player on, slide the Power switch up then release instantly.
If that does not get your player working again, try and Format to clear any corrupt files that may be present.
http://www.fixya.com/support/r3962743-sansa_mp3_player_frozen_reset_format
Mar 15, 2010 | SanDisk Sansa e260 MP3 Player
Sansa e260 player not recognized by window
(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) . download and install Copy and paste click run to install follow instructions make sure your sansa is in msc usb mod in the settings in the sansa
Jun 07, 2009 | SanDisk Sansa e260 MP3 Player
Sansa e260 will not connect to computer
Unplug the Sansa from the computer. Turn it off. Hold in the REC button. Reconnect the Sansa to the computer while holding in the REC button. After 10-15 seconds of continuing to hold in the REC button, a window should pop up saying "Found New Hardware Wizard." Complete the Wizard.
-Tha Mp3 Doctor
Dec 27, 2008 | SanDisk Sansa e260 MP3 Player
My Sansa e260 MP3 player is not working properly.
try changing to msc mode. go to settings and then usb mode
it has to be on msc mode to show up as a removable hardware
Jun 30, 2008 | SanDisk Sansa e260 MP3 Player
Sansa media converter problems
Besides the Media Converter, you will need other software which is available for download on the Sansa website - the media converter is just one part of the total package.
If that still fails,
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 24, 2008 | SanDisk Sansa e260 MP3 Player
How do I get my Sansa e260 to appear in Windows Media Player (v. 11; Vista)?
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 12, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e-260
May 04, 2008 | SanDisk Sansa e260 MP3 Player
MY sansa e260 MP3 player
Try to add the device manually.
Plug the player in while it’s set to "MTP" mode. (This selection is in the Settings area)
On your computer, open Device Manager, and select: Add Hardware.
Choose the "already connected the hardware" option.
From list, choose "Add a new hardware device".
Select: "Install the hardware that I manually select from a list."
Select: Portable Devices, then MTP device.
Hope it works for you.
Dec 31, 2007 | SanDisk Sansa e250 MP3 Player
Sansa e260 not being read by the system?
Does it show up in your windows explorer as another drive letter ?
Nov 26, 2007 | SanDisk Sansa e260 MP3 Player
Won't turn on at all
May 19, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
53 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
